[Official] Corsair Hydro Series Club - Page 5 - Overclock.net - An Overclocking Community
post #41 of 28489 (permalink) Old 11-21-2009, 06:37 PM
Killhouse's Avatar
Rep: 167 (Unique: 120)
I should add, it sticks out about 20mm on each end in the other direction that might interfere with the backplate for expansion slots. Since I'm using push/pull, the fan between the case and the radiator meant it could fit around without bending the slots with a hammer. I assume wherever you mount the Rad you already have a fan, so you can set up push/pull with that fan and the fan supplied and build the same setup I have. Good luck!
~ Killhouse's Worklogs ~
COMPLETE: Paroxysm :: Scratch ATX Acrylic Case Worklog
COMPLETE: Eyas :: Scratch mITX Acrylic HTPC Case Worklog
COMPLETE: Computer Desk :: Large Computer Desk
~ Clubs ~
Owner of The Official Corsair H50 Hydro Series Club
Killhouse is offline
post #42 of 28489 (permalink) Old 11-21-2009, 10:32 PM
elo820's Avatar
Rep: 6 (Unique: 4)
How do you guys make it push and pull? I cant figure it out =P
elo820 is offline
post #43 of 28489 (permalink) Old 11-21-2009, 11:34 PM
Rep: 212 (Unique: 186)
the radiator is basically sandwiched between two fans. the h50 only comes with 4 screws to mount the fan but the easiest way to mount two is just to use two diagonally on each side.
sexybastard is offline
post #44 of 28489 (permalink) Old 11-21-2009, 11:36 PM
ToxicAdam's Avatar
Rep: 48 (Unique: 46)
Got the Corsair H50!
Some pics;
Before: Stock AMD heatsink
After:
Temps; The wavy lines is do to my setup being below the ac vent in my room... when central air comes on my temps drops.
ToxicAdam is offline
post #45 of 28489 (permalink) Old 11-22-2009, 01:09 AM
mav2000's Avatar
Rep: 69 (Unique: 58)
I was wondering about that chart as I have never seen anything like that....but then I read ure comment.....Wow thats like 10 degrees drop with an AC...awesome....keep ure AC on while benching and u could get some good scores. I am running close to 57 degrees with my 965 on the same settings 1.425V and with a push pull...ofcourse my ambients are clsoe to 25-26.
mav2000 is offline
post #46 of 28489 (permalink) Old 11-22-2009, 01:14 AM
kyleax1's Avatar
Rep: 61 (Unique: 57)
you can add me
Push/Pull as exhaust
This is how I make sure I get fresh air into the rad
kyleax1 is offline
post #47 of 28489 (permalink) Old 11-22-2009, 03:50 AM
Not new to Overclock.net
Willhemmens's Avatar
Rep: 217 (Unique: 191)
Hi, got my H50 a few days ago, giving great temps at the moment, about 6'c less than my lapped S1283 was giving me. Man the pump is quite, the only way I can know its running is to check RPM. I origanally was running it on the back of my case as a intake push/pull, but as I run my case without either sides on, I have switched it over so im exhausting instead. I will upload some photo's later. What im interested in is, has anyone done any mods to a H50 like replacing the tubing or rad?
Willhemmens is offline
post #48 of 28489 (permalink) Old 11-22-2009, 06:21 AM
The viking's Avatar
Rep: 10 (Unique: 9)
Hey H50 owners!
Could one of you tell me about the temps your getting on your -not overclocked- i7 920's?
I hope some of you have such a system. Im thinking of buying the Lian li V351 case, and watercooling the cpu with this kit. Im still a bit on the fence though. Think anyone of you could change my mind by showing some awesome temps?
The viking is offline
post #49 of 28489 (permalink) Old 11-22-2009, 06:22 AM
Killhouse's Avatar
Can't really help with i7 temps, but expect to be about 10C lower than stock cooling temps for idle and load. Hopefully someone here can confirm.
~ Clubs ~
post #50 of 28489 (permalink) Old 11-22-2009, 06:38 AM
mav2000's Avatar
Whats the max pump rpm?
mav2000 is offline
