[Official] Corsair Hydro Series Club - Overclock.net - An Overclocking Community
post #1 of 28489 (permalink) Old 11-19-2009, 04:07 PM - Thread Starter
jameyscott's Avatar
Rep: 242 (Unique: 182)
Hello all! This is the Corsair Hydro Series Club.
Over the next few days I will be updating this thread as much as I possibly can.
H80i GT
More Pictures (Click to show)
Reviews (Click to show) Videos (Click to show)
H100i GTX
H110i GT
Current Products (Click to show)
H50 Rev2
H55
H60 Rev2
H75
H80i
H100i
H105
H110
EOL Products (Click to show)
H40
H50 Rev1
H60 Rev1
H70
H80
H100
When reporting testing results, the more information you provide ...
The more professional and "detailed" the responses will be biggrin.gif[/B]
Guide to Posting (Click to show)
Here are the basics ... and screenshots really help for quick/accurate diagnostics thumb.gif
1) CPU (model / @idle or load / stock or [email protected] ***GHz / AND CPU-Z vCore)
1a) Fill in your system specs (see my signature below smile.gif )
2) Stress Program (usually P95 [v27.9] Blend 30-60min)(IBT can also be useful)
2a) Temp monitoring program ... Real Temp / Core Temp / HWMonitor etc
3) Ambient temperature (usually room temp if your case isn't crammed into a cabinet)
4) Radiator Setup (open bench/ Push or Pull / Push/Pull / Case Intake or Exhaust)
5) Fans model (Stock or aftermarket) there rpm's and/or AIO setting (low/med/high)
Prime95 w/AVX latest version 27.9 [HERE]
CPU-Z v1.65 [HERE]
Real Temp v3.70 [HERE]
HWMonitor v1.23 [B [HERE]
Core Temp v1.0 RC5 [HERE]
IBT v2.54 [HERE]
Interesting thread [HERE]on stress monitoring. I don't necessarily agree with everything he says, but it's a very good discussion on stress programs! The main points I got out of it is Aida64 will heat your processor higher than P95 with Less Voltage .... hmmm. And it is very important to run the latest version of P95 [v27.9] as the instruction sets have changed significantly to where the load temps are getting very close to IBT/Aida64. The chart below, for those of you that don't know or ask where the heck is IBT in the chart, LinX and IBT are essentially the same program thumb.gif
This is why "screenshots" are so helpful ...
It's easier to confirm 100% Load / core temp vs CPU temp / vCore / Watts load etc.
Yes IBT is helpful if you understand the risks TDP95w IBT is pulling 126w redface.gif
More info on P95 and my quick favorite stability test, 1hr of custom setting with FFT set to 1344 and 1792 after an initial 20min Blend test ... See HERE /and HERE
There are currently two forms for the Owner's Club. One is from the previous owner and this new one was created by me. I am looking for a way to integrate the old Owner's list into mine, but due to time constraints, I'm not sure when if I will be able to. I cannot take the time to manually add the old Owner's list.
If you need your infomration update or have more than one cooler. Please let me know in a PM and I will be happy to update your information. Please do not add more submissions as that does increase the work for me.
The new form is for all coolers, not just the current series.
The H-series Owners - Add Yourself!
Old Form
Current Form
FAQ (Click to show)
Frequently Asked Questions (Click to show)
What is the fluid inside the unit?
Originally Posted by Corsair
The liquid inside the H50 and H70 is distilled water with Propylene Glycol
Should I mount my radiator in an exhaust of intake configuration?
Originally Posted by Killhouse
Basically, running your fan/radiator setup as intake will give you lower temperatures than an exhaust setup - this is because the radiator is being fed cool air from outside the case.
However, the H-series are very good at sending a lot of heat out of that radiator, and if you run it as an intake then you will be sending a lot of hot air into your case - this might be detrimental, especially if you have graphics cards with struggling stock coolers.
Personally, I prefer to run my unit in exhaust for better health of my system - and if you have a good amount of intake into your case somewhere near your radiator, you'll see very little temperature difference between intake and exhaust.
Here is a blog directly from Corsair; it includes some of the testing they did on Push/Pull setups.
I don't like the idea of all that water near my components, what if it leaks?
I should stress that your H-series is incredibly unlikely to leak, if this was a problem you would have heard much more about it. Of the few leaks that have been reported, Corsair have replaced all the damaged components in the system!
What is the thermal tape that comes with the H50?
The stock piece of thermal tape on the back of the H-series is Shin Etsu, this is a very good TIM (Thermal Interface Material) and normally ranks above your normal cheaper candidates.
What speed does the pump run at?
The H50 pump runs at about 1400 RPM, you can check this in a variety of programs such as speedfan.
If you think you have an answer to a commonly asked question, please PM me with the question and answer and it will be added here. And, of course, you'll be acknowledged for the input.
Due to the massive size of this thread I've given up updating it manually, just fill in this quick form. Note this is for the H60,H80,H100. For the new Corsair units (h60i,80i,100i ) fill out thisform.
Owners List: Click Here
New Series Owners List:Click Here
Links
Put links to your mod guides and testing in here. The spreadsheet is publicly editable so please add any links that you feel deserve a mention. Click "Edit This Page" at the bottom of the spreadsheet.
Click Here
NEW
H80 / H80i & H100 / H100i Case Compatibility Thread
Thanks to Mattyd893 we now have this link posted. Go here to check cases and compatibility. Also go help him out and submit yours so we can get the list bigger!
Popular Fans List
Because I don't own this spreadsheet we can no longer add. Still view the list. I'll be making a new one for people to add to.
Big thanks to Sethy who originally started this one, a good resource for anyone looking to upgrade their stock fans. As with the other community pages, please add fans that you feel deserve a mention. Click "Edit This Page" at the bottom of the spreadsheet.
Click HereNo Longer Works. You can view. No adding.
So add the fans using this form: Click Here
Fans List #2 ( Can Add )
Warning: Old OP (Click to show)
Well, kudos to this fantastic brand - this thread is now possibly the biggest and most viewed thread on OCN. It represents a massive wealth of knowledge on the H40, H50, H60, H80, H100,H60i,H80i,H100i
How To Join:
Scroll down and fill out the form and your entered! Have Fun! Frequently Asked Questions (Click to show)
Links
Click Here
NEW
Popular Fans List
Sig:
[URL=https://www.overclock.net/t/612436/official-corsair-hydro-series-club] :Snorkle: Official Corsair Hydro Series Club :Snorkle: [/URL]
jameyscott is offline
post #2 of 28489 (permalink) Old 11-19-2009, 04:08 PM
Rep: 212 (Unique: 186)
sexybastard is offline
post #3 of 28489 (permalink) Old 11-19-2009, 04:11 PM
Killhouse's Avatar
Rep: 167 (Unique: 120)
Nice setup! Added.
~ Killhouse's Worklogs ~
COMPLETE: Paroxysm :: Scratch ATX Acrylic Case Worklog
COMPLETE: Eyas :: Scratch mITX Acrylic HTPC Case Worklog
COMPLETE: Computer Desk :: Large Computer Desk
~ Clubs ~
Owner of The Official Corsair H50 Hydro Series Club
Killhouse is offline
post #4 of 28489 (permalink) Old 11-19-2009, 04:12 PM
Retired Staff
kevingreenbmx's Avatar
Rep: 568 (Unique: 425)
hey, I'll join. :-)
everyone who joins this thread should also join the water cooling club in my sig. :-)
kevingreenbmx is offline
post #5 of 28489 (permalink) Old 11-19-2009, 04:15 PM
Ragsters's Avatar
Rep: 220 (Unique: 204)
Im in! Here is my rig.
http://www.techpowerup.com/gallery/2274.html
Tiny Dancer
(19 items)
Son's Build
(16 items)
White Noise (R.I.P)
(31 items)
i7 6800k
Asrock X99e-itx
RX Vega 56
Corsair Vengence LPX
SAMSUNG 960 EVO M.2 500GB NVMe
Corsair SF600w
Corsair H75
NF-F12 industrialPPC-2000 PWM
Ncase M1 V5 (Silver)
Operating System
Windows 10
BenQ 32" IPS 4K (BL3201PH)
Keyboard
Vortex Poker 3 (White with White LED)
Mouse
Logitech G102 Prodigy (Matte White)
Mouse
Glorious PC Gaming Race XXL Extended
Audio
Soundblaster Omni 5.1
Audio
Sennheiser HD 598
Audio
kanto Yu2 Desktop Speakers (Gloss White)
Audio
Kanto Sub 6 (Gloss White)
AMD Phenom II X6 1055T
Gigabyte 880GMA-UD2H
Asus GTX 660 Ti
Corsair Vengeance Pro
PNY SSD CS1311
Samsung SSD 830
Samsung Spinpoit F3
Antec Neo Eco 520C
Corsair H50
Silverstone FT03B
Operating System
Windows 7 Home Premium 64bit
Samsung SyncMaster 220wm
Keyboard
Coolermaster Quickfire Rapid
Mouse
Steelseries QcK
Mouse
Zowie Mico
Audio
Logitech LS21 2.1 Stereo Speakers
i7-3770K
Asus Maximus V Formula
VisionTek Reference 7970
Diamond Reference 7970
Corsair Dominator-GT 16GB (4x4GB)
SanDisk Extreme Pro
Western Digital Black 640GB
Seasonic X650 (Custom MDPC Sleeve)
Swiftech MCP35X DDC Pump - White Top
XSPC AX360 Triple 120mm Radiator - White
EK-Supremacy Clean CSQ - Nickel Plexi
Bitspower Silver Shining Fittings
7 x Scythe Gentle Typhoons D1225C12B4AP-15
Bitspower Acrylic DDC Pump Top
Bitspower DDC Top Upgrade Kit
Bitspower DDC / MCP35x Pump Heatsink - White (BP-DDCPC-WH)
2 X EK-FC7970 Nickel CSQ GPU Block
2 X EK-FC7970 Backplate - Black CSQ
EK-FB KIT ASUS M5F Nickel Motherboard Block
XSPC AX480 Quad 120mm Radiator - White
EK-Ram Monarch X4 CSQ - (EN) Nickel Plexi
CaseLabs Merlin SM8 (All White)
Operating System
Windows 7 64bit Home Premium Upgrade
Achieva Shimian Lite "Perfect Pixels"
Keyboard
Das Keyboard Model S Professional
Mouse
Mionix Avior 7000
Mouse
SteelSeries QCK Mini
Audio
Klipsch Pro Media 2.1
Audio
Sennheiser 598
Audio
Creative Soundblaster Z
Other
NZXT LED Kit - 2 Meter - White (CB-LED20-WH)
Ragsters is offline
post #6 of 28489 (permalink) Old 11-19-2009, 04:44 PM
Killhouse's Avatar
Some very sexy rigs there, I'll try and get my pics up tomorrow.
~ Clubs ~
post #7 of 28489 (permalink) Old 11-19-2009, 06:08 PM
Rep: 1 (Unique: 1)
here's mine.. just put it in today and I've realized about a 20C drop in temps over the Arctic Cooling Freezer 7 Pro Rev 2 HS/F.. I'm impressed!
Attachment 129888
With 4 instances of World Community Grid running I went from 59c to 38c. Nice..
unixwizzrd is offline
post #8 of 28489 (permalink) Old 11-19-2009, 09:20 PM
mav2000's Avatar
Rep: 69 (Unique: 58)
Im here tooo. Please add me....just a quick question guys...how much tim is required for this setup to work optimally. I am using mx2 with the spread method, so a very thin layer...but looking at the copper plate and the finish on it, I would think more would be required.
mav2000 is offline
post #9 of 28489 (permalink) Old 11-20-2009, 04:15 AM
Killhouse's Avatar
I tried applying the MX2 a few times before I was happy. I ended up putting 5 small dots on the chip and then mounting H50. Seemed to give the best result (by observation), if you're not hitting stupid temperatures then you probably did it fine.
~ Clubs ~
post #10 of 28489 (permalink) Old 11-20-2009, 04:25 AM
fraudbrand's Avatar
Rep: 48 (Unique: 45)
In my Obsidian
sneaky.gif: : The Official Corsair H50 Hydro Series Club : : sneaky.gif
fraudbrand is offline
