"Water Cooling Does Not Leak" Club - Overclock.net - An Overclocking Community
post #1 of 305 (permalink) Old 12-30-2009, 05:09 AM - Thread Starter
Well, We see all these threads about peoples loops leaking and horro stories, but we never see anyone create a thread saying "Hey my water cooling didnt leak".So here it is. The rules are simple, Simply post a list of your water cooling gear and post your experience with the products. To join the Club simply post your loop and your experience with it and I will add you to the list.
I want this thread to be for 1 purpose. To show people who are considering/never used watercooling how water cooling doesnt leak as much as the horror stories on the net.
Members
Fallen Angel -X
CM690
Vuxdu
Open1Your1Eyes0
Runeazn
GAMERIG
PizzaMan
VWgti
88EVGAFTW
Samster25
SporkOfDoom
cky2k6
dreadlord369
Sickened1
pewpewlazer
G|F.E.A.D|Killa
richardbb85
BANDIT_COROLLA
Lieutenant_Dan
USFORCES
nckid4u
Deagle50ae
Sistum Id
strangeclouds_over_moscow
urgrandpasdog
tat2monsta
CaptnBB
Syrillian
ShortySmalls
ira-k
Mr-Nibbles
henrys
10acjed
motoray
Capwn
Videoman5
krs1
spiderm0nkey
MeeksMan13
grossebeaver
Patch
10acjed
Juggalo23451
IntelConvert
Sangko
qUAan
Zamoldac
wilykat
Melcar
trueg50
Anish
xXLinkageXx
Xaero252
haste266
like30ninjas
Flatliner
gillbot
R00ST3R
3dfxvoodoo
mcoffey
Lysdexik
Levesque
Willhemmens
xXwhygodwhyXx
trn
shurik06_83
//.DK
dennis_g
waqasr
haste266
scc28
Shutterflash
Rifleman007
-JUNK-
houseofbugs
ny_driver
runeazn
ChosenLord
tke395
contain
Couch Potato
SwishaMane
wermad
Klockradio
mcpetrolhead
doat
doritos93
shirosky102
Lhiannon
JohnDProb
Salvo210
k4m1k4z3
PizzaMan
DennisC
Artikbot
Paradigm Shifter
antand
Rud3Bwoy
Slightly skewed
DirektEffekt
Phobos223
Digital Artist
Johnsen
VW_TDI_02
vodka3dg
ShortySmalls
Sig Tag
Water Cooling Does Not Leak Club
:Snorkle:[COLOR="DarkOrchid"][SIZE="3"][FONT="Franklin Gothic Medium"][I][URL="https://www.overclock.net/water-cooling/637560-my-water-cooling-didnt-leak-club.html#post8031790"]Water Cooling Does Not Leak Club[/URL][/I][/FONT][/SIZE][/COLOR]:Snorkle:
Fallen Angel -X is offline
post #2 of 305 (permalink) Old 12-30-2009, 05:13 AM - Thread Starter
Thing is tho that you can find all these threads on the internet saying how their watercooling leaked and horror stories. But hardly any that say My WaterCooling Didnt Leak. This thread is to show people new to water cooling that it doesnt always leak.
Its very simple
post #3 of 305 (permalink) Old 12-30-2009, 05:20 AM
CM690's Avatar
Rep: 180 (Unique: 157)
My watercooling doesn't leak!
My stuff:
2 x Xigmatek 120mm XLF-F1253 1500RPM - White LED (For the rad)
Several Metres of 1/2" ID - 3/4" OD Clearflex 60 Hose
XSPC Delta V3 CPU Waterblock LGA775
XSPC RS240 Black Rad
EK-NB/SB 5 - Plexi NB Block
XSPC Bay Reservoir - Clear Acrylic
12V OCZ Hydro Pulse Water Pump 500
PrimoChill PURE Performance Coolant (32 oz.) - UV Brite Orange
CPU's:
Celeron D 3.33Ghz | Athlon 64 | E5200 2.5Ghz (3.5Ghz OC)| Q6600 2.4Ghz| Intel i5-650 3.2Ghz HT/on|
GPU's:
Sapphire X1300 256MB | Leadtek 8600GT 256MB | Sapphire X1950GT 256MB | XFX GTS250 Core Edition 1GB | XFX HD5770 1GB XXX Edition | nVidia GTX470 1280mb Reference
CM690 is offline
post #4 of 305 (permalink) Old 12-30-2009, 05:21 AM - Thread Starter
Thank you very much CM690
Added
post #5 of 305 (permalink) Old 12-30-2009, 05:28 AM
CM690's Avatar
I think the idea was to see people that have working watercooling (? xD) and then that would help people by being able to ask them advice? Maybe?
CPU's:
GPU's:
CM690 is offline
post #6 of 305 (permalink) Old 12-30-2009, 05:29 AM - Thread Starter
Yep you hit the nail on the head
post #7 of 305 (permalink) Old 12-30-2009, 05:41 AM
Rep: 473 (Unique: 355)
Mine leaks, it's like a nice radioactive leak! But it's ok cause my cat licks up all the antifreeze that drips out.
Intel:MainRig i7 [email protected]/Gigabyte Z68X-UD3H/16GB [email protected]/2xHD6990
Intel:Secondary Xeon [email protected] 1.35v/X58A-UD3R/12GB [email protected]/3xHD6970
AMD:HTPC 2400-BE/A7GM-S 2.0/2GB [email protected]/HDMI
Server1ell R610 DualQuad/[email protected]
Server2:HP Proliant DL360 G5 DualQuad/[email protected]
rpm666 is offline
post #8 of 305 (permalink) Old 12-30-2009, 05:43 AM
vuxdu's Avatar
Rep: 115 (Unique: 108)
Ah, I wish mine would spring a leak so I can buy new components
But I suppose I'll join!
Swiftech GTZ,
Swiftech MCR320
Swiftech MCRESv1
7/16" tubing with 1/2" barbs
Distilled water with a little bit of green UV dye and Petras biocide.
edit: I am thinking of switching out to something none conductive soon. haha
vuxdu is offline
post #9 of 305 (permalink) Old 12-30-2009, 05:46 AM
Retired Staff
Open1Your1Eyes0's Avatar
Rep: 452 (Unique: 321)
My watercooling doesn't leak. Link Here
Watercooling Specs:
CPU: Enzotech Sapphire SCW-REV.A CPU Waterblock
Chipset: Swiftech MCW30 Chipset Waterblock
GPU: Watercool HEATKILLER® GPU-X² GTX295 GPU Waterblock
Pump: D-Tek DB-1 Pump
Radiator: SwiftTech MCR320-QP-Res Radiator
Case Fans: Three 120mm CoolerMaster Red LED 2000RPM Fans
Radiator Fans: Three 120mm Scythe UltraKaze 2000RPM Fans
Tubing: PrimoChill PrimoFlex 10-Foot Clear Tubing (1/2" ID - 3/4" OD)
Thermal Paste: Shin-Etsu X23-7783D Thermal Compound
Liquid: Poland Spring Distilled Water
Always remember, you CAN set up your kit in a way to know ahead of time it won't leak. Key is time and patience and making sure you're not being lazy with tightening things but at the same time being careful not to break something.
Open1Your1Eyes0 is offline
post #10 of 305 (permalink) Old 12-30-2009, 06:33 AM
Rep: 157 (Unique: 145)
mine doesn't leak ATM lol :
tygon tubing
compression fitting
distilled water
5dollar silver coin
480gtx rad
mcp655 with ek v2 top
heatkiller rev3 CU
anti kink coils green and blue
****ty fan's you dont want to know.. you want to know well here they are the msot crappy fans ever named :!!! San Ace 120
crappy no?
runeazn is offline
