WaterCooling kit or custom? - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 01-03-2006, 04:20 PM - Thread Starter
-Jeppe-'s Avatar
Rep: 52 (Unique: 37)
When I nearly had given up hope on watercooling becuse of the costs from ordering from a foregin country one of the stores here in Finland get some quality w/c stuff either this kit this one or make a custom one with this parts note I can't get any DD parts in finland
Cpu Block : Swiftec Storm or Apoage
Pump: Swiftec MCP655
Radiator : Swiftechin MCR220 (Black Ice) or a BIX II
Res:Swiftecs MCRES-525 or MCRES-MICRO this is a 3.5 that goes in the floppy drive place
Tubing:some 1/2" tubing
Accs: Fans ,Clamps,Uv-dye,AG Super Cooler(can't find zerex )
I need input on wich cpu block and Radiator If I go with the custom build
and in future uppgrade to the w/c I'm going to order from the UK a DD X1800 Block with new clerex tubing I'll be adding this any way ago with the kit or the custom one
All help appreciated
Edit: anyway of adding a poll to this thread?
-Jeppe- is offline
post #2 of 11 (permalink) Old 01-03-2006, 04:29 PM
SNERP!!!
Snerp's Avatar
Rep: 385 (Unique: 225)
Looks like your custom options are about the same as the kit. There isn't anything wrong with that kit at all. The swiftech kits have been ranked very high on many websites.
Now you just have to figure out your money situation and what parts you want.
FAQ: Teflon Tape...USE IT!OSAMT: "Member of OCN Songwriter and Musician Thread"Proud Member of the OCN Mechanical Keyboad Club!
Alu
(15 items)
AMD Ryzen 5 3600
Gigabyte X570 AORUS ELITE WIFI
XFX RX 5700 XT THICC III Ultra
Team T-Force DARK Pro 16GB (2 x 8GB) DDR4 3200 TDPGD416G3200HC14ADC01
Samsung 960 Evo NVMe PCIe M.2 500GB
Samsung 850 Evo 500GB
Rosewill CAPSTONE-750-M
EK Fluid Gaming 240A w/ Zalman Reserator & Alphacool DDC-310
Zalman Z-Machine GT1000
Operating System
Windows 10 Pro
LG 27GL83A-B 27 Inch Ultragear QHD IPS
Keyboard
Ducky One 2 - Horizon
Mouse
Razer DeathAdder V2
Mousepad
Razer Firefly Hard V2
Audio
Hyperx Cloud II
Snerp is offline
post #3 of 11 (permalink) Old 01-03-2006, 05:26 PM - Thread Starter
-Jeppe-'s Avatar
I just wondering if the rad that comes with the kit is good or bad ? and is there any huge differences between the storm and apoge
-Jeppe- is offline
post #4 of 11 (permalink) Old 01-03-2006, 05:52 PM
PCNerd's Avatar
Rep: 430 (Unique: 256)
The Apogee, from what I can tell, is just an optimized STORM block. That is a very nice kit, the best, I believe.
PCNerd is offline
post #5 of 11 (permalink) Old 01-03-2006, 06:03 PM
Jazino's Avatar
Rep: 139 (Unique: 118)
i have seen many reviews most sating there is very little diff between the storm and apogee, like 1-2 degrees usually. if money is a factor it will do just fine.
Jazino is offline
post #6 of 11 (permalink) Old 01-03-2006, 06:07 PM
SNERP!!!
Snerp's Avatar
The Apogee and the Storm are completely different designs. The Apogee is an improvement on the Swiftech 600X series. The temp difference between the two blocks has been found to be about 1°C with the Storm beating the Apogee. I own the Apogee and I love it. A lot of people own the Storm and they love it. I don't think you can go wrong with either.
I'm not sure about the swiftech rad, but I doubt it would be bad. If I had to go with a kit it would be one of the swiftech kits. If you are looking at spending about the same amount of money with both go custom.
Alu
(15 items)
AMD Ryzen 5 3600
Operating System
Windows 10 Pro
Keyboard
Mouse
Razer DeathAdder V2
Mousepad
Audio
Hyperx Cloud II
Snerp is offline
post #7 of 11 (permalink) Old 01-04-2006, 09:46 AM - Thread Starter
-Jeppe-'s Avatar
I've been reading some rewiews on the kit and it looks really good the rad semes to be really good and it comes with delta 70cfm fans but I can't seem to find any info on the tubbing size any users who has the kit that would be able to tell any info and opinions would be great
-Jeppe- is offline
post #8 of 11 (permalink) Old 01-04-2006, 01:53 PM
SNERP!!!
Snerp's Avatar
"Larger 7/16" ID (5/8" OD) tubing is used to maximize the coolant flow rate inside the system."
" The 7/16" ID tubing features the same or better flexibility than 3/8" ID tubing, no distinguishable difference in terms of system flow rate compared to 1/2" ID tubing, but significantly reduces the bulk associated with 1/2" ID thick wall tubing."
That is from http://www.swiftnets.com/.
I am a ninja *ninja backflip*
Alu
(15 items)
AMD Ryzen 5 3600
Operating System
Windows 10 Pro
Keyboard
Mouse
Razer DeathAdder V2
Mousepad
Audio
Hyperx Cloud II
Snerp is offline
post #9 of 11 (permalink) Old 01-04-2006, 02:10 PM - Thread Starter
-Jeppe-'s Avatar
I think I gonna order the kit becuse if I would make the custom I would have to buy from all kinda shops It will be easier to go with the kit and cheaper and I read some reivews sayings it's really good and that the rad is supposedly also pretty good I just hope that the apoge and the rest of the things comes with the 1/2" fittings so if I'm gonna get some bigger tubing later
-Jeppe- is offline
post #10 of 11 (permalink) Old 01-04-2006, 02:25 PM
SNERP!!!
Snerp's Avatar
It does like I said in my last post.
Alu
(15 items)
AMD Ryzen 5 3600
Operating System
Windows 10 Pro
Keyboard
Mouse
Razer DeathAdder V2
Mousepad
Audio
Hyperx Cloud II
Snerp is offline
