Northbridge question - Overclock.net - An Overclocking Community
post #1 of 5 (permalink) Old 01-07-2006, 08:36 PM - Thread Starter
Rep: 68 (Unique: 60)
I just purchased and installed the Zalman Northbridge Water Block in my system. My concern is this: It's small. The bottom of the block has a very small circle of aluminum that doesn't cover the whole northbridge. My system is rock stable overclocked at 2.33GHz, but before I put the Zalman on I was @ 2.43 GHz. (I can't say for certain it was as stable as it is now because I didn't run Prime95 for long enough.)
Anywho, what I'd like to know is should I scrap this cooler for a larger square one, or does it not really matter? If you look at the installation instructions, the drawing shows a similar setup as mine with the edges of the cooler meeting the edges of a chip. I know it's just a drawing, but you'd figure they'd at least try to put it to scale.
Any advice would be appreciated.
A simile is like a metaphor.
The Llama is offline
post #2 of 5 (permalink) Old 01-07-2006, 09:08 PM
pauldovi's Avatar
Rep: 923 (Unique: 529)
My suggestion is to return the northbridge block. Waste of your water system's pressure. At most just get a aftermarket HS with a fan.
pauldovi is offline
post #3 of 5 (permalink) Old 01-08-2006, 05:38 PM
SNERP!!!
Snerp's Avatar
Rep: 385 (Unique: 225)
Pauldovi has the right idea. Take it back. A NB block doesn't make a performance difference at all and it brings up your temps and kills pressure/flow. Get a Thermalright NB-1. That should cool your NB very well. Stock NB cooling would even take care of it. The only time you actually need after market cooling on you NB is when you are increasing your voltage to it.
FAQ: Teflon Tape...USE IT!OSAMT: "Member of OCN Songwriter and Musician Thread"Proud Member of the OCN Mechanical Keyboad Club!
Alu
(15 items)
AMD Ryzen 5 3600
Gigabyte X570 AORUS ELITE WIFI
XFX RX 5700 XT THICC III Ultra
Team T-Force DARK Pro 16GB (2 x 8GB) DDR4 3200 TDPGD416G3200HC14ADC01
Samsung 960 Evo NVMe PCIe M.2 500GB
Samsung 850 Evo 500GB
Rosewill CAPSTONE-750-M
EK Fluid Gaming 240A w/ Zalman Reserator & Alphacool DDC-310
Zalman Z-Machine GT1000
Operating System
Windows 10 Pro
LG 27GL83A-B 27 Inch Ultragear QHD IPS
Keyboard
Ducky One 2 - Horizon
Mouse
Razer DeathAdder V2
Mousepad
Razer Firefly Hard V2
Audio
Hyperx Cloud II
Snerp is offline
post #4 of 5 (permalink) Old 01-09-2006, 03:37 AM - Thread Starter
I never really thought of the pressure issue. I figured at worse case I would break even from the stock cooling. Thanks for the advice guys.
post #5 of 5 (permalink) Old 01-09-2006, 11:30 AM
Rep: 149 (Unique: 110)
CrimsonMango is offline
