W/C Question? - Overclock.net - An Overclocking Community
W/C Question?
post #1 of 8 (permalink) Old 01-09-2006, 06:20 PM - Thread Starter
lohoutlaw's Avatar
Hey guys my system is running strong and healthy, but i have noticed that the water level on my fill tub is dropping about an 1" just over a week.
Yes, i have checked for leaks. There is not a drop of liquid to be found any were in my system or the heater core.
Is the water level dropping like this normal?
lohoutlaw is offline
post #2 of 8 (permalink) Old 01-09-2006, 06:22 PM
chechenepiphany's Avatar
Rep: 41 (Unique: 38)
I would guess that the tank isn't sealed and that the warm water is just evaporating.
chechenepiphany is offline
post #3 of 8 (permalink) Old 01-09-2006, 06:25 PM
Rep: 219 (Unique: 137)
ya like what he said. droppin 1 inc aweek is not normal at all.
hanwinting is offline
post #4 of 8 (permalink) Old 01-09-2006, 06:27 PM
Jazino's Avatar
Rep: 139 (Unique: 118)
mine has been up for about two weeks or so and has also dropped nearly an inch, but it is just a t line. if your losing that much out of a res than you likely have a problem. hopefully they just take a couple weeks to "settle in" though.
Jazino is offline
post #5 of 8 (permalink) Old 01-09-2006, 06:28 PM - Thread Starter
lohoutlaw's Avatar
Now you got me scared? The W/C system is sealed. No leaks or opennings and no, the res. is sealed.
Could this be a settling faze?
post #6 of 8 (permalink) Old 01-09-2006, 06:30 PM
maybe you are using just water and didn't mix anything so its evaporating from the heat...it can evaporate out of tubes you know....like water evaporating out of a water bottle
Chillaxed is offline
post #7 of 8 (permalink) Old 01-09-2006, 06:30 PM
If you aren't leaking anywhere, you're fine. Either its settling in, or its evaporating. Just keep on fillin er up.
post #8 of 8 (permalink) Old 01-09-2006, 06:35 PM - Thread Starter
lohoutlaw's Avatar
Yes but water wont evap. from a sealed bottle.
But i guess for now i will think of it as settling down..
Thanks you all!
