Got my pump today! ... :-( - Overclock.net - An Overclocking Community
post #1 of 10 (permalink) Old 01-11-2006, 01:05 PM - Thread Starter
pauldovi's Avatar
Rep: 923 (Unique: 529)
Well I got my pump today. It is the Swiftech MCP655. I hooked it up to my setup... and... leak. Well I opened the pump up to investigate. I found that there was no o-ring... I called up the makers, and the first guy was a moron, second guy was real nice. He is over-nighting me a new pump (I get to keep the old one as well)! I may go to the hardware store and find a compatable o-ring. Then I can hook up 2 pumps to my system!
pauldovi is offline
post #2 of 10 (permalink) Old 01-11-2006, 01:07 PM
Rep: 497 (Unique: 343)
wow sweat deal... heck 1 pump would probably cut it, but 2, nice...
Fold For Team 37726!! Get Started Here
Upgrades---> T7200 Core 2 Duo
Guide---> What Core 2 Duo Motherboard is right for me?
Projects---> Waterchiller Build
Rig 2---> P4 640 @ 4GHz, Asus P5P800-SE, 512MB crap, Sunbeam NUUO 550w
My Old Rig --->2.4AE @ 4.15GHz , semi Stable, yes 1.75GHz OC ...
wowza is offline
post #3 of 10 (permalink) Old 01-11-2006, 01:47 PM - Thread Starter
pauldovi's Avatar
Well considering the maximum flow for my apogee block is 3 Gallons per minute, or 180 gallons per hour, I don't think I need 2 pumps with them being rated at 317 GPH. Even with the added resistance from all the parts, I think the pump will be bottlenecked by the block.
pauldovi is offline
post #4 of 10 (permalink) Old 01-11-2006, 04:54 PM
SNERP!!!
Snerp's Avatar
Rep: 385 (Unique: 225)
Dude sell that pump and get some money back from the cost of your system. I've got a dollar + shipping on it
FAQ: Teflon Tape...USE IT!OSAMT: "Member of OCN Songwriter and Musician Thread"Proud Member of the OCN Mechanical Keyboad Club!
Alu
(15 items)
AMD Ryzen 5 3600
Gigabyte X570 AORUS ELITE WIFI
XFX RX 5700 XT THICC III Ultra
Team T-Force DARK Pro 16GB (2 x 8GB) DDR4 3200 TDPGD416G3200HC14ADC01
Samsung 960 Evo NVMe PCIe M.2 500GB
Samsung 850 Evo 500GB
Rosewill CAPSTONE-750-M
EK Fluid Gaming 240A w/ Zalman Reserator & Alphacool DDC-310
Zalman Z-Machine GT1000
Operating System
Windows 10 Pro
LG 27GL83A-B 27 Inch Ultragear QHD IPS
Keyboard
Ducky One 2 - Horizon
Mouse
Razer DeathAdder V2
Mousepad
Razer Firefly Hard V2
Audio
Hyperx Cloud II
Snerp is offline
post #5 of 10 (permalink) Old 01-11-2006, 04:59 PM
Jazino's Avatar
Rep: 139 (Unique: 118)
yeah you wont need two pumps with that block, sell it.
Jazino is offline
post #6 of 10 (permalink) Old 01-11-2006, 05:00 PM
I thought if you had 2 of the same pumps running at the same time, you would get 2x the flow header length, but no extra GHP, am I correct?
Some_Idiot2 is offline
post #7 of 10 (permalink) Old 01-11-2006, 06:08 PM - Thread Starter
pauldovi's Avatar
Well, if it is simliar to circuits (circuits are commonly explained using pumps and water), then you would get 2X the potential (head), and 2X the amps (Flow), and 2X the voltage (Push)... But idk... If you think about it, you would get same GPH, but double the head. Maybe I will test it.
I might sell, or I might just give to my buddy who I have convinced to watercool.
pauldovi is offline
post #8 of 10 (permalink) Old 01-13-2006, 08:56 AM
Retired Staff
Burn's Avatar
Rep: 520 (Unique: 309)
It really depends on how the block was rated. For instance, 3 GPH could have been at the bare minimum or the absolute max flow that they could achieve. I'll take that one off your hands
My CNC Mill Project
Originally Posted by CyberDruid
Burn + Electricty + Water =
But the man has the patience of a saint...
We cannot change the cards we are dealt, just how we play the hand.
--Randy Pausch
Current Best Benchmark
Burn is offline
post #9 of 10 (permalink) Old 01-13-2006, 08:59 AM
jbrown's Avatar
Rep: 73 (Unique: 66)
sw33t deal man
jbrown is offline
post #10 of 10 (permalink) Old 01-13-2006, 12:54 PM
Sun
Rep: 328 (Unique: 249)
If you run the pumps in parrallel, you will get about 2x the flow, really it is less, but who cares for exacts. In series, you get 2x the head/pressure, but really it is also a little less.
DO NOT PIRATE GAMES.
Mission: ImPA120.3 Triple Radiator inside Antec 300
Add to the Data @ Fuelly
Sun is offline
