Big Typhoon vs Bigwater - Page 4 - Overclock.net - An Overclocking Community
post #31 of 37 (permalink) Old 01-15-2006, 07:50 AM
pauldovi's Avatar
Rep: 923 (Unique: 529)
Your temps are good enough with air that you can hit 4.0. Intels are ok up to the mid 60s. WC is more rewarding, but it also is more mantience intensive. Your air is performing very well, and you won't do that much better with water.
pauldovi is offline
post #32 of 37 (permalink) Old 01-15-2006, 02:28 PM
supratt93's Avatar
do you have any insight as to why i cant hit higher then 3.87? i mean i have ddr 500, temps are ok never even seen a 50 degree temp, just cant get any higher. plus, i think watercooling is nifty. dont have the cash for it atm though unless i can sell this rig and build a new one.
supratt93 is offline
post #33 of 37 (permalink) Old 01-15-2006, 02:36 PM
pauldovi's Avatar
What is your Vcore?
pauldovi is offline
post #34 of 37 (permalink) Old 01-15-2006, 03:52 PM
supratt93's Avatar
What is your Vcore?
fluctuating between 1.39 and 1.440
post #35 of 37 (permalink) Old 01-15-2006, 03:52 PM
pauldovi's Avatar
You probably need to up your Vcore to OC more.
pauldovi is offline
post #36 of 37 (permalink) Old 01-15-2006, 06:42 PM
SNERP!!!
Snerp's Avatar
Rep: 385 (Unique: 225)
There are 3 reasons for a resivoir, and while not being necessary, it is recommended:
1. Easily fill you system
2. Remove air from you system
3. Add more water to the system, the more water you have, the harding it is for the water to heat up, giving you lower temperatures.
So a resivoir does have a performance increase to some degree. Mine was not to hard to make, I used hose washers, some barb I found at Ace Hardware, and a $1.29 Rubbermade 1 Gal container!
Actually #3 is not true totally. It doesn't matter how much water you have in your system because your pump is constantly pushing the water past the CPU. It will warm up to a normal temp and stay there. It will take longer to warm up when you start the computer the more water you have, but it will level out to one temp. The "performance gain" would be around a degree.
Key word there is fluctuating. You need a better power supply that can supply steady power. The difference between 1.39 and 1.440 is a lot and could be the reason you CPU can't go any higher. I'd look into the Sunbeam Nuuo 550W PSU.
FAQ: Teflon Tape...USE IT!OSAMT: "Member of OCN Songwriter and Musician Thread"Proud Member of the OCN Mechanical Keyboad Club!
Alu
(15 items)
AMD Ryzen 5 3600
Gigabyte X570 AORUS ELITE WIFI
XFX RX 5700 XT THICC III Ultra
Team T-Force DARK Pro 16GB (2 x 8GB) DDR4 3200 TDPGD416G3200HC14ADC01
Samsung 960 Evo NVMe PCIe M.2 500GB
Samsung 850 Evo 500GB
Rosewill CAPSTONE-750-M
EK Fluid Gaming 240A w/ Zalman Reserator & Alphacool DDC-310
Zalman Z-Machine GT1000
Operating System
Windows 10 Pro
LG 27GL83A-B 27 Inch Ultragear QHD IPS
Keyboard
Ducky One 2 - Horizon
Mouse
Razer DeathAdder V2
Mousepad
Razer Firefly Hard V2
Audio
Hyperx Cloud II
Snerp is offline
post #37 of 37 (permalink) Old 01-15-2006, 08:39 PM
pauldovi's Avatar
[QUOTE=Snerp]Actually #3 is not true totally. It doesn't matter how much water you have in your system because your pump is constantly pushing the water past the CPU. It will warm up to a normal temp and stay there. It will take longer to warm up when you start the computer the more water you have, but it will level out to one temp. The "performance gain" would be around a degree.
I have to disagree with you on that. If you have more water, the water stays closer to room temperature. This is because there is more water to heat. It is like trying to heat a small pot or water or a large pot of water, which one takes longer? If you have a small amount of water, the water temperature will be higher, and if they water temp is higher than the amount of heat that the water can take away from the processor is smaller.
pauldovi is offline
