Are Shrouds Really Worth it? - Overclock.net - An Overclocking Community
post #1 of 10 (permalink) Old 01-12-2006, 09:00 PM - Thread Starter
Are they?
Some_Idiot2 is offline
post #2 of 10 (permalink) Old 01-12-2006, 09:04 PM
Fishie36's Avatar
Rep: 751 (Unique: 473)
Shroud for what? Rad?
Fishie36 is offline
post #3 of 10 (permalink) Old 01-12-2006, 09:06 PM
Shrouds on a rad? Definately, yes.
Pinhead-227 is offline
post #4 of 10 (permalink) Old 01-12-2006, 09:07 PM
0rion's Avatar
Rep: 293 (Unique: 253)
I think so. I have one on my dangerden heatercore, and what it does is eliminate the hot spot caused by the center of the fan by lifting it off the surface of the radiator. I think it also provides more even cooling, instead of directly under the fanblades, it pushes/pulls air throught the radiator all over it, providing more effective cooling.
What's the point in making that if you're not going to have sex with it?
Q6600 @ 4.0ghz validation
Best post EVAR
0rion is offline
post #5 of 10 (permalink) Old 01-12-2006, 09:11 PM
SNERP!!!
Snerp's Avatar
Rep: 385 (Unique: 225)
you said it
FAQ: Teflon Tape...USE IT!OSAMT: "Member of OCN Songwriter and Musician Thread"Proud Member of the OCN Mechanical Keyboad Club!
Alu
(15 items)
AMD Ryzen 5 3600
Gigabyte X570 AORUS ELITE WIFI
XFX RX 5700 XT THICC III Ultra
Team T-Force DARK Pro 16GB (2 x 8GB) DDR4 3200 TDPGD416G3200HC14ADC01
Samsung 960 Evo NVMe PCIe M.2 500GB
Samsung 850 Evo 500GB
Rosewill CAPSTONE-750-M
EK Fluid Gaming 240A w/ Zalman Reserator & Alphacool DDC-310
Zalman Z-Machine GT1000
Operating System
Windows 10 Pro
LG 27GL83A-B 27 Inch Ultragear QHD IPS
Keyboard
Ducky One 2 - Horizon
Mouse
Razer DeathAdder V2
Mousepad
Razer Firefly Hard V2
Audio
Hyperx Cloud II
Snerp is offline
post #6 of 10 (permalink) Old 01-12-2006, 09:11 PM - Thread Starter
Yayes, double heatercore.
post #7 of 10 (permalink) Old 01-13-2006, 06:51 AM
Retired Staff
Rep: 391 (Unique: 203)
In short, yes, they do work. It all depends on the fans used, but temps can decrease by as much as a few degrees.
Main Rig:3.4E @ 4.15ghz, P5WD2, X1900XTX, 2X512 Corsair PC8000UL, Raptors Raid 0, OCZ Powerstream 520.
Rig #2: (folding 24/7)
2.8E @ 3.22, IS7, BFG 6800 Ultra, 2X512 Geil PC4000, 60GB Maxtor, Aspire 500 watt.
Rig #3: (folding 24/7 @ 75%)
2.6B @2.9, IC7, 9800XT, 2X256 Corsair PC3200, 120GB WD, Aspire 500 watt.
Fold for Overclock.net!
Lando95 is offline
post #8 of 10 (permalink) Old 01-13-2006, 07:21 AM
If you've got a large heat load, your temps will improve by more than a few degrees. With my TEC and heatercore, my water temps improved by about 20 degrees with the shroud.
post #9 of 10 (permalink) Old 01-13-2006, 11:52 AM - Thread Starter
Cool, I can feel air being pushed back out of my fans when they are trying to push air through my fans because of the drag force created by the heatercore, is that a bad thing?
post #10 of 10 (permalink) Old 01-13-2006, 01:52 PM
The other advantage of the shroud is the fan air pressure is spread out evenly across the heatercore, so there's not as much "spot pressure" on the fan. It can more efficiently move the air that way.
Edit: If you can feel air behind the fan (where the air should be flowing "into" the fan) than another fan on the opposite side of the heatercore will help immensely. That will spread the pressure between the two fans, and help force the air to flow through the rad.
