Dry Ice Water Cooling - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 01-14-2006, 02:52 PM - Thread Starter
DFA
Would it be possible to make a cooling system With only a Pump, cpu water block and Some tubbing passing trough a container with Dry Ice inside ???
DFA is offline
post #2 of 11 (permalink) Old 01-14-2006, 02:53 PM
OG
sctheluna's Avatar
Rep: 106 (Unique: 87)
Ya I don't see why but you would be spending a lot of money buying dry ice all the time.
XBOX LIVE Gamertag~Longshot44
Current Setup
(17 items)
Ultrabook
(7 items)
8700k
Asus Strix 370e Gaming
Asus RTX 2080 Strix OC
GSkill
ADATA XPG SX8200 Pro 1TB 3D NAND NVMe
XPG GAMMIX 1TB S11 Pro 3D NAND PCIe NVMe
Western Digital Blue 500GB SSD
Seagate BarraCuda 2TB
EVGA SuperNOVA 850 G3 80 Plus Gold
Corsair H100i Pro
NZXT H500
Operating System
Windows 10 Home
Viotek GN34CW 34-Inch 21:9 Ultrawide Curved QHD
Keyboard
Corsair K70
Mouse
Corsair M65 Elite
Mousepad
Asus ROG Extended
Audio
SMSL AD18 w/x2 Pioneer SP-BS22-LR Andrew Jones
i5 3317U
ASUS
Integrated HD 4000
4GB DDR3
EVO 850 M.2 500GB
Operating System
Windows 10 Home
IPS 13.3' 1080p
sctheluna is offline
post #3 of 11 (permalink) Old 01-14-2006, 02:58 PM
dry ice is not liquid: you would have to use dry ice to cool the liquid, there would be lots of problems setting it up. somethine similar to a beer chiller maybe?
tuchan is offline
post #4 of 11 (permalink) Old 01-14-2006, 03:34 PM
yeah dry ice only lasts a couple days. My company ships medication with it and the shelf life is 3 days. Plus wouldnt you run the risk of freezing the water. Dry ice is like -79c
ThaWaxShop is offline
post #5 of 11 (permalink) Old 01-14-2006, 07:09 PM
Rep: 132 (Unique: 96)
Yes its possible. Its the same concept as a water chiller,no the water doesnt freeze as an antifreeze is used as the additive.
Its easier though just to make a straight chiller(AC system,submerge Evap in water,use evap water as reservoir)
TylerBello is offline
post #6 of 11 (permalink) Old 01-14-2006, 07:14 PM
Dry Ice + Water = a bomb
did you even think about venting the Co2 gas that would be created? Your RES would become a bomb in a couple of seconds.
Very bad idea. And you would have to spend like $100 bucks on dry ice a day to get that thing running. And another thing, the coolant would freeze, and antifreeze has to freeze at some point ( -200F I think).
Some_Idiot2 is offline
post #7 of 11 (permalink) Old 01-14-2006, 07:28 PM
Well,the coolant wouldnt freeze. The water is not going to get to -200f,ever.Thats -93c.And,the Dice wouldnt be in the water,it would simply be cooling the water,below it,cooling its container assumably(even though its still a useless idea in the world of chillers.)
Oh yeah,and dry ice is cheap,10 pounds,5 bucks.(not 200)
post #8 of 11 (permalink) Old 01-14-2006, 07:34 PM
antifreeze freezes at like -40
and yes, it would be a bomb. don't do this.
Chillaxed is offline
post #9 of 11 (permalink) Old 01-14-2006, 07:35 PM
pbasil1's Avatar
Rep: 460 (Unique: 346)
Originally Posted by TylerBello
Well,the coolant wouldnt freeze. The water is not going to get to -200f,ever.Thats -93f.And,the Dice wouldnt be in the water,it would simply be cooling the water,below it,cooling its container assumably(even though its still a useless idea in the world of chillers.)
ok anit freeze still freezes... just not at the temps it is usually used at, dry ice will freeze antifreeze...
Like cars? Carforum!
How to choose the right fan
what is " folding " ???
When you take an old graphics card and effectively 'fold' it in half, in order to remove the chip.This process takes alot of power.
pbasil1 is offline
post #10 of 11 (permalink) Old 01-14-2006, 07:45 PM
Rep: 130 (Unique: 103)
You could use Acetone, their is a chemical reaction in which the CO2 reacts, causing the acetone to get super cold, like -80 C. Acetone never freezes either. One problem with a pump is that the oil inside may start to solidify due to the extreme cold. You would also need to insulate all the tubing to keep it cold. I would just suggest buying or making your own pot to house the dry ice, pumping it through a loop isn't as efficient.
metalman2785 is offline
