How is this setup? - Overclock.net - An Overclocking Community
How is this setup?
post #1 of 10 (permalink) Old 01-15-2006, 01:04 PM - Thread Starter
Rep: 0
Suicidemayne is offline
post #2 of 10 (permalink) Old 01-15-2006, 01:10 PM
pauldovi's Avatar
Rep: 923 (Unique: 529)
The heatercore is great. You can get them cheaper at Autozone ($20). For the tubing you can get it for $.40 at homedepot. That is what I use. The larger the resivoir, the better the performance... I made a custom resivoir with a 1 Gal Rubbermade food jar and some barbs (used a dremel tool and garden hose gaskets). That will perform better but it won't fit in most cases. You can also get the Apogee cheaper using Snerps link:
https://www.overclock.net/water-cooli...-shipping.html
I have the Apogee, you do not have to remove the motherboard for some AMD processors, but you do for others. I don't know. But it is a great block.
If you are looking for some fans for your heatercore try these:
http://www.newegg.com/Product/Produc...82E16835150052
they are a little load, but they work great!
You setup is overall good, expect idle in the high 20s or low 30s and a load in the high 30s or low 40s.
pauldovi is offline
post #3 of 10 (permalink) Old 01-15-2006, 01:13 PM - Thread Starter
Rep: 0
now i want my tubing to glow should i just use the UV tubing or go wit distelled water with UV dye? Or does it matter?
post #4 of 10 (permalink) Old 01-15-2006, 01:15 PM
pauldovi's Avatar
Go with the UV tubing and then get distilled water and anti-freeze. Check the color of your antifreeze so that it matches the color of your tubing.
pauldovi is offline
post #5 of 10 (permalink) Old 01-15-2006, 01:17 PM - Thread Starter
Rep: 0
post #6 of 10 (permalink) Old 01-15-2006, 01:23 PM
pauldovi's Avatar
Yes that does the same thing that the anti-freeze does. It is just more expensive.
pauldovi is offline
post #7 of 10 (permalink) Old 01-15-2006, 01:27 PM
Retired Staff
Transonic's Avatar
Rep: 429 (Unique: 250)
Setup looks good. Why no GPU cooling? They benefit greatly from water, like a 20+ C difference from what I've done.
Transonic is offline
post #8 of 10 (permalink) Old 01-15-2006, 01:36 PM - Thread Starter
Rep: 0
o well i am getting GPU cooling im just goinig to get all of that 1st..
post #9 of 10 (permalink) Old 01-15-2006, 01:49 PM
Jazino's Avatar
Rep: 139 (Unique: 118)
i concur on the gpu cooling, HUGE difference. i am not happy with my homedepot tubing it is very stiff. some people dont like the uv tubing (ugly) havent seen it myself but uv dye is about $10.
Jazino is offline
post #10 of 10 (permalink) Old 01-15-2006, 06:16 PM
SNERP!!!
Snerp's Avatar
Rep: 385 (Unique: 225)
It's easier to put the GPU cooler on when you are setting everything up. It's not that hard adding one, but if you do have the money I'd say just do it with the main install.
FAQ: Teflon Tape...USE IT!OSAMT: "Member of OCN Songwriter and Musician Thread"Proud Member of the OCN Mechanical Keyboad Club!
Alu
(15 items)
AMD Ryzen 5 3600
Gigabyte X570 AORUS ELITE WIFI
XFX RX 5700 XT THICC III Ultra
Team T-Force DARK Pro 16GB (2 x 8GB) DDR4 3200 TDPGD416G3200HC14ADC01
Samsung 960 Evo NVMe PCIe M.2 500GB
Samsung 850 Evo 500GB
Rosewill CAPSTONE-750-M
EK Fluid Gaming 240A w/ Zalman Reserator & Alphacool DDC-310
Zalman Z-Machine GT1000
Operating System
Windows 10 Pro
LG 27GL83A-B 27 Inch Ultragear QHD IPS
Keyboard
Ducky One 2 - Horizon
Mouse
Razer DeathAdder V2
Mousepad
Razer Firefly Hard V2
Audio
Hyperx Cloud II
Snerp is offline
