is this good coolant? - Overclock.net - An Overclocking Community
post #1 of 36 (permalink) Old 03-11-2010, 08:12 PM - Thread Starter
RushMore1205's Avatar
Rep: 183 (Unique: 105)
hey guys so i see this new coolant it comes unmixed which is kind of kool, and then you can make it as dark as you want
http://www.frozencpu.com/products/75...Red.html#blank
what do u think
PM ME FOR DETAILS and Prices
Folding Power: 2x GTX 470,GTX460,GTS450,i7-920 4.1ghz,2x amd Phenom x2 560 3.8ghz(unlocked to quad),AMD x6 4.0ghz
RushMore1205 is offline
post #2 of 36 (permalink) Old 03-11-2010, 08:13 PM
It's still almost enough.
Chunky_Chimp's Avatar
Wouldn't recommend it. Most here will say the same thing; colored tubing with distilled + biocide is the best way to do it.
Combined air and water cooling tips: Fan database | My San Ace 9G1212H1011 review | Don't mix metals or use premixes / dyes | Distilled vs. tap water | Good radiator brands | Water (almost) can't flow too fast | Which PT Nuke to use | Regarding thermal paste spreading
Deep Blood
(15 items)
Soft Sentinel
Intel Core i7 920 D0 (Batch # 3901A240)
Foxconn X58 Blood Rage (non-GTI)
Sapphire Vega 64 8GB
6GB Corsair Dominator 1.6GHz TR3X6G1600C8D Rev 3.2
Samsung SSD830 128GB / Seagate 640GB+2TB+2x4TB
Optical Drive
Samsung SH-S223Q 22X
Antec HCPP-850
XTTH | OCZ Freeze | 9G1212H1011
CaseLabs SM8
Operating System
Windows 7 Ultimate x64 SP1
Dell U2410f (rev. A02)
Keyboard
Code 104 w/O-rings + Vortex PBT/POM doubleshot keycaps
Mouse
Roccat Kone EMP w/Dechanic Mini pad
Audio
Asus Xonar DX / Klipsch RM-14s + Dayton DTA-120 / MXL Tempo
Other
Microsoft Lifecam Cinema
Intel Core 2 Duo E6320
Intel DP35DP
XFX GeForce 7600GT
2GB Mushkin DDR2 800 5-5-5-12
Seagate Barracuda 7200.10 320GB
Optical Drive
Asus 18x multi-burner
Enermax Liberty 400w modular
Rosewill R5604-TBK
Operating System
Windows XP Pro SP3 32-bit
Samsung LN-S2351W
Keyboard
Ideazon MERC
Mouse
Logitech MX-518 (rev.2; 1800 DPI [no Teflon feet])
Mouse
Xtrac Pads Ripper
Chunky_Chimp is offline
post #3 of 36 (permalink) Old 03-11-2010, 08:14 PM
STG3 VET
Juggalo23451's Avatar
Rep: 1174 (Unique: 756)
All you need is distilled water with pt nuke or a silver coil that is it.
<div class="post-sig post-sig-limit shazam usersig-click"><div class="reparse-sig-lineheight"><p><a href="https://www.overclock.net/water-cooling/913181-water-cooling-guide-noobs.html#post11984918">Water cooling guide for noobs,parts,setup install case suggestions,etc</a></p><span></span><p><a href="https://www.overclock.net/water-cooling/962044-upgrade-time-update-2-3-18-a.html">Case labs TH10/ build log (2 gtx 590s) water cooling oh my</a></p><span></span><p><a href="https://www.overclock.net/water-cooling/528648-heatkiller-club.html">Founder of the Heatkiller Club</a></p><span></span><p><span>W</span><a href="https://www.overclock.net/water-cooling/601449-water-cooling-cases.html">ater cooling case suggestions</a></p></div></div>
Juggalo23451 is offline
post #4 of 36 (permalink) Old 03-11-2010, 08:17 PM
frankenstein406's Avatar
Rep: 67 (Unique: 64)
I like pc ice if its a pre bought coolant but distilled/pt nuke or silver coil is fine. Will you be mixing metals?
frankenstein406 is offline
post #5 of 36 (permalink) Old 03-11-2010, 08:21 PM
Arkuatic's Avatar
Rep: 129 (Unique: 118)
Honestly don't see the point of coolants as they provide no performance gain nor any benefits aside from color. If you were too cheap and bought clear tubing then you're probably losing money as you have to invest in coolants for color when you could have spent that extra buck or two on colored tubing.
Arkuatic is offline
post #6 of 36 (permalink) Old 03-11-2010, 08:24 PM - Thread Starter
i actually got clear tubing on purpose becasue i wanted my res to have color liquid in it, i think it looks cool,
why is there a problem if i mix metals, i have my cpu and nb are copper and my mosfet is silver i think
post #7 of 36 (permalink) Old 03-11-2010, 08:27 PM
Arkuatic's Avatar
Not sure but I think mixing metal causes heavy stains on your loop. If you wanted a colored reservoir you could of just added an led light or gotten a frozenq reservior(reactor/liquidF res).
Using coolants causes a ton of buildup later on and an extreme pain to clean out sometimes.
Arkuatic is offline
post #8 of 36 (permalink) Old 03-11-2010, 08:39 PM - Thread Starter
wow definatly didnt know that, i guess i will not water cool my mosfet then lol
i have a case that has good airflow
post #9 of 36 (permalink) Old 03-11-2010, 08:41 PM
Arkuatic's Avatar
I'm not sure on the stain w/ mixing metals though I did see a post by a member who had mixed metals and his blocks came out pretty stained. Case isn't all that there is to airflow, fans and other stuff too. Cooling your memory is also more important than your mosfets.
Arkuatic is offline
post #10 of 36 (permalink) Old 03-11-2010, 09:16 PM - Thread Starter
yeah i know man, the case is a work in progress but this is what it looked like 3 days ago
