[Worklog] Project Atlantis (Double Wide Domination) - Overclock.net - An Overclocking Community
post #1 of 126 (permalink) Old 02-06-2011, 08:41 AM - Thread Starter
Watercooling Enthusiast
fat_italian_stallion's Avatar
Rep: 248 (Unique: 208)
(forgive my ghettolicious banner)
It's time for my ufo to become a more intense build. I will be raising my ufo from the depths of watercooling to a combination of a rather strong waterloop and a 3/4 hp phase change unit. It will be done in two stages, inevitably raising the ufo by 18inches using two pedestal attachments.
Stage 1 will be installed and the rig will run on two loops, each loop with 6 x 120 rad. Loop 1 will consist of cpu, ram, nb/sb, mosfets while loop 2 will consist of 3 gpu blocks.
Progress Pics WC Component Tally: ~$2350
Stage 2 will include the 3/4 hp phase change unit tuned for -38C that should keep my cpu at a nice and cool. Hoping for 4.2ghz load temps around 0C and up to 5.0 at around 30C
Stage 2 scratched for new build
Current Core Components
-Intel i7 920
-Asus P6T6 WS Revolution
-(6)2GB Corsair Dominator 1600mhz DDR3
-(3) EVGA GTX480 (Vanilla)
-(4)Seagate 1.5TB Barracuda 7200 RPM HDD
- 500GB OCZ Colossus SSD
-Silverstone ST1500 1500watt PSU
-Creative X-fi Fatal1ty Soundcard
Current Watercooling Components
-mcp 355 w/ xspc acrylic pumptop
-SR1 360, 240, 120
-Danger Den Radiator Reservoir
-Frozen Q 400mm helix Reservoir
-EK Supreme HF
-(3) Koolance Vid-NX480
-Mips Ramcooler 6
-(2)Koolance Mvr-40
-Koolance p6t6ws revolution wb
-(2sets) Koolance Quick Disconnects
-(22) Koolance 3/8id 1/2od compression fittings
-(6) koolance dual vid connectors
Starting Config Pics:
:devil:Current TDP temps (70F ambient): CPU 62C (4.2ghz 1.4v), GPU1 49C, GPU2 51C, GPU3 51C:devil:
Vendor Comments: MNPCtech was a delight to work with. I would definitely suggest getting any mod parts you need from them. Friendliest service I've yet encountered with a computer parts manufacturer. Their parts are also top quality and second to none. If you need any mod parts please buy from them so they can continue to provide us with top notch gear.
Cooling will continue to be adjusted automatically by a lamptron touch fan controller according to case temps in specific sections of the rig.
Stage 1 ($929 total): Goal is to reduce [email protected] load temps by up to 8C
Expect Major Updates Including Installed Stage 1 on Monday February 14th
-Mountain Mods Pedestal in config posted below
-HW labs SR1 360 radiator
-XSPC RX 360 radiator
-(9) Midspeed blue led yate loons (will undervolt to 7v for normal usage)
-eheim hpps Replaced by 4x MCP 355
-(6) koolance 3/8id 1/2od compression fitting
-koolance 3/8id 1/2od 90* compression fitting
-(2) 360 MNPCTECH Pro-line Radiator Grills
-(3) Simple black wire fan grills
-20ft primochill primoflex blue 3/8id 1/2 od tubing
-(2) 3pin to 6x 3pin
-3pin to 4x 3pin
-(3) 24" 3pin extension
-kill coil
Arrived Parts Pics:
MNPCtech Proline Billet Rad Grills
RX360
SR1 360
MCP 355 x 2
XSPC Dual Pumptop
Primochill Primoflex UV Blue LRT 3/8ID 1/2OD Tubing
Mid Speed Blue Led Yate Loons
Black Wire Fan Grills
Koolance 3/8id 1/2 od Fittings
24inch 3pin Extensions
Kill Coil
3pin splitters (will be resleeved)
Pedestal Parts
Parts Observations: SR1 build quality is far superior to that of the RX 360. Definitely worth the extra $15
:devil:Stage 1 TDP temps (70F ambient): CPU 55C (4.2ghz 1.4v), GPU1 36C, GPU2 36C, GPU3 38C:devil:
Stage 2 ($1,154+ shipping)(planned order date of 3/5/11): Goal is to hit 5.0GHZ+ with my 920 for 24/7 operation at sub zero temperatures.
-Mountain Mods Pedestal in the same config as above to keep the look consistent
-3/4 hp phase change unit built by sdumper (which will cool the cpu)
-(9) midspeed blue led yate loons
At stage 2 the loops will be split to 9x 120 rad to cool the gpus while 3 x 120 rad to cool the ram, mosfets, and nb/sb
When finished estimated power consumption including phase change ~2200watts at TDP
If I believe that this 580 rumor is true, then why can't I also believe that the 6k series is made of 100% pure rainbow oil and that it can fly? They're both about as plausible...
fat_italian_stallion is offline
post #2 of 126 (permalink) Old 02-06-2011, 08:42 AM - Thread Starter
Stage 1 Pics
Progress Pics
Pump Setup
Left Side Panel
Front and Rear Panels
Assembled
Assembled 2
Finished Pics
Angled
Left Side
Above Angled
Front
1 hour load Equilibrium Temps
On a side note it's the perfect height for an armrest while gaming.
post #3 of 126 (permalink) Old 02-06-2011, 08:43 AM - Thread Starter
Reserved for Stage 2 Pics
post #4 of 126 (permalink) Old 02-06-2011, 08:43 AM - Thread Starter
Reserved for Completed Project
post #5 of 126 (permalink) Old 02-06-2011, 11:03 AM
Rep: 27 (Unique: 23)
Subed. Got to support my MM brother.
begjr2 is offline
post #6 of 126 (permalink) Old 02-06-2011, 04:36 PM
Existence's Avatar
Rep: 0
Can't wait to see how this build turns out. You always know how to do it big and do it right. Keep up the good work!
Existence is offline
post #7 of 126 (permalink) Old 02-06-2011, 04:39 PM
TheReciever's Avatar
Rep: 434 (Unique: 322)
You can expect great things from stallion, subbed
Biased rPGA and MXM 3.0A/B Elitest.
TheReciever is offline
post #8 of 126 (permalink) Old 02-06-2011, 05:02 PM
charliehorse55's Avatar
Rep: 778 (Unique: 512)
You definitely need to add a money counter to this project. Start it at how much you've spent on your rig thusfar, and add to it as you go along. I expect somewhere in stage 2 you will pass 10k.
Also, I don't think you can hit 5.0 GHz 24/7 on that chip, but you might get close. Also, even if the compressor is tuned for -38C that does not mean your CPU will be that temperature. When you load your rig up you have roughly 26C water, so going to phase is only going to drop your load temperatures by about 65-70C. With your current OC you'd load just above 0. Once you take it higher, the CPU core temperature would rise even more.
Have you considered this beast? Might get your temperatures down where they'd need to be for 5 GHz+.
Finally, have you considering picking up a better clocking 920? You could probably get one that does 4.3-4.4 GHz on less than 1.3V.
charliehorse55 is offline
post #9 of 126 (permalink) Old 02-06-2011, 05:09 PM - Thread Starter
I have considered picking up another 920, but I'm saving that money for the an Ivy Bridge dual Xeon build. I have little funds for each upgrade. The one that's lacking is the 4way sli kepler fund, only enough for waterblocks so far. The one I have is a champ for a C0. Overclocks better than most D0s I've seen out there. I'm super impressed it can hit 4.6 folding stable. With stage 1 I'm at around $8700 (no peripherals) since I purchased everything pretty much at the launch of the products. Stage 1 is costing $711 with shipping. Nothing better to spend my money on right now. Figured I'd get myself a ballin valentines day gift since I'd rather not spend $200 on a girl that I won't end up dating long term for 1 night. When that comes out I'm going to switch my UFO into a duality and run both setups in the same box. I'll just add another phase unit for the other processor and put this cpu back to water.
post #10 of 126 (permalink) Old 02-06-2011, 05:13 PM
Come on though, like $1000 more for -100C more. Then you would load around -90C lol.
That's roughly $10/C, which is a better deal than the $11/C you are paying for with the SingleStage unit you had picked out there.
