[Official] Antec Kühler H2O 620 & 920 Owners Club - Page 601 - Overclock.net - An Overclocking Community
View Poll Results: Which Antec cooler do you own?
Antec Kühler H2O 620 156 54.36%
Antec Kühler H2O 920 131 45.64%
Voters: 287. You may not vote on this poll
post #6001 of 6095 (permalink) Old 10-26-2016, 01:06 AM
High Clocker
bmgjet's Avatar
Rep: 191 (Unique: 165)
For those of you with a old Antec AIO sitting around a CitiLED 058-1825 LED screws straight on.
SLI Voodoo 2 - > GeForce4 MX 420 -> GF 6600GT -> GF 6800GT -> GF 8800Ultra -> AMD 4870 -> AMD 4890 -> CF AMD 5820 -> CF AMD 6850 -> CF AMD 7970 -> SLI GF 680 -> SLI GF 780 -> CF AMD 290X -> GF 980ti -> SLI GF 980ti -> GF 1080ti -> SLI GF 1080ti -> <- RTX 2080ti (DOA/Refunded)
AMD 8120
FX 8350
7970 CFX
680 SLI
bmgjet is offline
post #6002 of 6095 (permalink) Old 10-28-2016, 08:01 PM
Rep: 9 (Unique: 8)
Need some guidance. Just shipped my cooler from Europe to the US, took 5 months.
Now the pump is loud and the temps are going from 32 to shutoff (93) in about 2 minutes. I don't think it's the thermal paste as it's a slow heat buildup and the pump unit gets hot. The pump sounds like it's running as it's loud. Could it be that the coolant evaporated?
Is it easy to add more coolant?
granno21 is offline
post #6003 of 6095 (permalink) Old 10-29-2016, 12:22 AM
High Clocker
bmgjet's Avatar
Have you bleed the pump, (Have it as lowest point and power it on so air can leave it and travel into radiator)
There is ment to be a bit of air in it to account for the coolants expansion but to fill it is as easy as removing the copper base as you can see in my picture back a few posts.
AMD 8120
FX 8350
7970 CFX
680 SLI
bmgjet is offline
post #6004 of 6095 (permalink) Old 10-29-2016, 08:30 AM
Rep: 9 (Unique: 8)
didn't bleed the pump properly apparently. Tipped the whole computer on its side with the radiator straight up and let it run for a few minutes, and viola, it works!
Thanks!
granno21 is offline
post #6005 of 6095 (permalink) Old 11-15-2016, 12:35 AM
john420's Avatar
Rep: 0
Hello i have a 620 and would like to mod it with some clear hoses.. i know its 1/4 but how many mm are the size of them?? 12/10mm 10/8mm or 8/6mm?? or bigger ?? someone must know so i dont have to cut open the thing to find out as im using it now
EDIT: Just ordered 8/6mm tubes.. then we will see i guess ...
john420 is offline
post #6006 of 6095 (permalink) Old 11-15-2016, 03:27 AM
lordimac's Avatar
Rep: 0
Inner Diameter is 6mm. Use a lighter to heat up the end of the hose before you install it, makes it easier. Outer Diameter doesn't matter, use 8 or 9 mm, depends on what you can get.
lordimac is offline
post #6007 of 6095 (permalink) Old 11-15-2016, 03:29 AM
M3TAl's Avatar
Rep: 182 (Unique: 134)
The inner diameter would be 6mm for 1/4". The outer diameter is irrelevant unless using compression fittings.
Edit:Ahaha, ninja.
M3TAl is offline
post #6008 of 6095 (permalink) Old 11-15-2016, 04:35 AM
john420's Avatar
Rep: 0
Yea ok thanks that was what i thought.. That means i can add my old rad in to the mix from a Northq Siberian tiger and make something like this! biggrin.gif xD
I really hope i will be able to make a fountain effect in the res :3 and make sure the pump stays fed with water as its below the pump..
i have a pretty good feeling i will have nice temps for my 4790k 4.7ghz 1.4v
john420 is offline
post #6009 of 6095 (permalink) Old 11-15-2016, 04:40 AM
lordimac's Avatar
Rep: 0
Looking forward for your project! I was planning the same thing, running the old 620 Cooler/Pump Combo together with an Reservoir and GPU Cooler. But testing the 620 Pump outside wasn't good at all. The water flow was very low, nothing compared to my new EKWB pump. I'm unsure about your fountain effect, sorry. frown.gif
lordimac is offline
post #6010 of 6095 (permalink) Old 11-15-2016, 04:46 AM
john420's Avatar
Rep: 0
Yeah ok.. i guess we will see, defenitly posting a pic when its done wink.gif i still have the pump from the northq... would the loop benefit from having that in? 2pumps? maybe in between the two rads?
john420 is offline
