Full System TEC cooling - Page 10 - Overclock.net - An Overclocking Community
post #91 of 142 (permalink) Old 03-15-2019, 05:23 PM - Thread Starter
toolmaker03's Avatar
Rep: 93 (Unique: 70)
Quote: Originally Posted by Master Chicken View Post
Yeah, now that you mention it, those fins look super dense.
basically they are 300watt radiators with fans that will move enough air through them. this is also why I am using box fans for these radiators, at $17 for a box fan, and I can fit 4 360mm radiators on one box fan, that makes outfitting the radiators with fans cheap. the radiators are cheap to, at $22 dollars each, considering that I needed 12 more of them to cool this setup. this was my best option. so I am adding 3000watts worth of radiator to a hot loop, that already has 2000watts worth of radiator. this gives me a total of 5000watts worth of radiator for the 6 331watt TEC's. yes, these TEC's really do need this much cooling. if you plan on using them at 3/4 power, and keeping the hot side water loop within a 10C delta T from ambient.
https://www.overclock.net/forum/rigbu...tle=AMD+AM3%2B
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is online now
post #92 of 142 (permalink) Old 03-20-2019, 11:52 PM
Umm, How Bout Noooooo.
Cyber Locc's Avatar
Rep: 114 (Unique: 79)
Quote: Originally Posted by toolmaker03 View Post
https://www.amazon.com/Yuly-Aluminum...gateway&sr=8-6
no they came that way, but they are aluminum, I decided to go aluminum because I needed so many, and their is only about a 50watt difference between copper, and aluminum in that size radiator. also the copper are 10FPI, and the aluminum are 20FPI, so the aluminum radiators need 3000RPM fans, or better to function well.
currently I am working on getting a second table, and a wood table top to place on top of that. so this project just got twice the amount of surface area to mount stuff to. not the best solution, but I have no other. I will be setting all this up over the next week or two and getting the new radiators installed on the hot side water loops.
So my chiller build that got back burnered, is going to use a wire shelf rack. That may be an option to consider? I planned to extend non chilled cooling with external rads mounted between the posts.
May be an idea as a way to mount all those rads, without alot of surface area.
Favorite OCN Quotes (Click to show)
You are just talking more and more nonsense now. It's time to take this back to whatever noob forum it came from.
____________________________________________________________________________________________________________________
Cyber Locc is offline
post #93 of 142 (permalink) Old 04-08-2019, 01:41 AM
Dimebagg's Avatar
Rep: 1 (Unique: 1)
Hi
I really like this build. I run a hailea 1000a and find it interesting the similarity of the performance between the systems. (within reason. I know the hailea is 1hp.) Looking at the expense of your most recent investment i really wonder what your gaining over eaisier solutions.
Dimebagg is offline
post #94 of 142 (permalink) Old 04-08-2019, 05:08 AM - Thread Starter
Quote: Originally Posted by Dimebagg View Post
Hi
well, A/C Vs TEC, first and most obvious would be the constant cooling, and steady temps. a TEC system does not turn on and off based on motor heat, or overheating of the compressor. less heat released into the room because I am using 24 radiators I keep the hot side water loop below a 10C delta T. last thing is that it only takes three minutes to cool the water down to 0C from ambient.
now for the cons, it cost more, it takes up a lot more room, and uses a lot more electricity. so I can only say that I am doing it, because others said that it would not work. it is not the best solution, but it is a stable one.
so looking at the gains, to cons, I would say that you are better off with the system you are using. I really wanted something that I could tinker with for years to come. I have been water cooling my PC systems for 20 years now, I have tried TEC's before, and A/C cooling, both systems fried from condensation. this time with the chill box, I really feel that I will not loose any more systems from condensation. so if I was to suggest a upgrade, it would be that, to get a chill box for your PC system, this will prevent condensation from occurring.
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
post #95 of 142 (permalink) Old 04-08-2019, 04:46 PM
Dimebagg's Avatar
Rep: 1 (Unique: 1)
snip
We are on the same wave-length mate. Condensation is the real killer in these builds. Having the hailea has highlighted that for me several times. Honestly, the way i am running it now in terms of power consumption and system safety is a constant 15 degrees c. I run 6-8mins an hour at idle and 15-20mins and hour at full load. What im noticing is that the temps dont really change across the components.
IE hailea runs a cpu and two cards in sli. From leaving the reservoir to rentering the reservoir the fluid temps only raise by 5-6c.
Dimebagg is offline
post #96 of 142 (permalink) Old 04-08-2019, 05:01 PM
Hardware Princess
Hydroplane's Avatar
Rep: 37 (Unique: 29)
Nice to see this still active! I love crazy builds like this. Been thinking of some condensation-fighting means for my own chiller contraption:
1. Vermiculite (kind of like potted plant soil)
2. Plumber's Putty (maybe for the bottom of the mobo)
3. Small chest freezer (basically as a chillbox, would need to use watercooled GPU, otherwise too much heat for the freezer to cool. It would just be to provide cold dry air around the components. Downside: have a big freezer in my house now)
4. AC unit based chillbox (would have to modify the AC to run below ~50F)
5. Dehumidifier box
How did the clay work out? I looked at using some for motherboard insulation instead of overpriced kneaded eraser, but most clays contain water. The plumber's putty I think is non-conductive.
CHILLER DESTRUCTION
Build Log - White Voodoo
basic linux pc
(15 items)
Z390 Station
(11 items)
7980XE @ 4.3 GHz 1.10v
Asus Rampage VI Apex
2 x Aorus Waterforce WB 1080 Ti @ 2037/6318
Trident Z 16gb 3200c14 @ 3800c16 1.50V (the other two sticks were sacrificed)
960 Evo 1TB
EVGA 1600 T2
HWLabs GTR 420+280 Rads
7 x Noctua Industrial 140mm 3000 RPM Fans
EK D5 Pump/Res (with RGB!)
LD Cooling PC-V7
Operating System
Linux Mint 19.6
NEC PA271W
Keyboard
Razer Blackwidow Chroma V2
Mouse
Logitech M510
Mousepad
anime tiddy mousepad
9900K @ 5.4 1.50v
EVGA Z390 Dark
Titan RTX 2085/8500
Trident Z 3200c14 @ 4600c20 1.5v
970 Evo Plus 250gb
silverstone 1200 from 2008 (other one exploded)
HWLabs GTX 360 Rad (in RED)
3x EK Vader 120mm 2200rpm Fans
Dimastech Test Bench
AOC Agon AG251FZ 240Hz
Audio
Built-in Monitor Speakers (3 watt)
Dual Intel Xeon L5520 2.26 GHz
48 GB Samsung DDR3-1066
120 GB Samsung 750 Evo SSD
2 TB Western Digital Green
2 TB Hitachi 7200 RPM
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
Hydroplane is offline
post #97 of 142 (permalink) Old 04-08-2019, 06:13 PM - Thread Starter
5. Dehumidifier box
well I did do several different designs before I ended up with the composition I have now. to start I do have eraser putty in between the water blocks, completely encasing the TEC's. than I covered the entire cold side water loop, in two layers of 5/8" thick foam. than I covered that in clay, about 1/4" thick across the cold side water loop. this setup completely stops all condensation down to -18C on this build. if the build was not capable of getting that cold I might have been able to get away with one layer of foam. the clay servers several roles. first it creates a air tight barrier between the ambient air and the cold side water loop. the second thing it does it fill in, or cover all the tiny holes that foam insulation will leave all over the cold side water loop. third, because I covered the water pumps as well, the environment around the water pump is cooled to the same temperature as the cold side water, so I do not have condensation forming on the electronics of the water pumps. so I would say that it works great.
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
post #98 of 142 (permalink) Old 04-08-2019, 06:52 PM
Missing the Old days
Cerberus's Avatar
Rep: 254 (Unique: 218)
Have you had issues with pin rot? even a full Vaseline socket still gave me issues after 24/7/5-6 months at -40ish
"But I, being poor, have only my dreams. I have spread my dreams beneath your feet. Tread softly because you tread on my dreams."
Folding Rack
(9 items)
Work Folder
(7 items)
AMD r7 2700x
ASUS ROG Crosshair VI Hero
Nvidia Titan X Pascal
PNY Anarchy-X 2x8GB 3200Mhz
256GB Plextor M8Pe m.2
Corsair RM750X
big metal box
Operating System
Microsoft Windows 10 x64
DELL S2716DG
Keyboard
Logitech G910
Mouse
Logitech G602
Mouse
Steelseries Mat
Audio
Logitech G602
Other
steam controller
AMD r7 1700x
MSI X470 Gaming Plus
ZOTAC GTX 980 AMP!
Geil EVO 1x4GB DDR4
Toshiba 3TB
Silverstone ST-1000PT
4U Rosewill
Operating System
Ubuntu 18.04LTS
Headless
AMD FX8350
BIOStar TA970
AMD FURY X
Zotac GTX 960
Gskill 2x8GB DDR3
Western Digital Blue 2TB
Corsair 650w
Cerberus is offline
post #99 of 142 (permalink) Old 04-08-2019, 07:47 PM - Thread Starter
well mine does not get that cold, but no, I do not get any pin rot at all, as condensation inside the chill box is impossible. the inside of the chill box, is always within 1C of the temperature of the water running though the chill box, because of the radiators inside the chill box. this environment prevents the formation of condensation, the only catch, is that the box has to be mostly sealed. their can be pin hole leaks without issue, but their can not be any gross leaks in the box at all. I seal all the holes in the chill box for the wiring, and water lines with liquid rubber. this plugs up all the gross leaks that would be in those areas. by using a wine cooler for the box, most of the box was already fully sealed.
on a side note, I use evaporative coolers to cool my home, not A/C. so the humidity in my house is high most of the year. so I needed a solution that would prevent condensation, regardless of the high humidity in my home.
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
post #100 of 142 (permalink) Old 04-09-2019, 09:37 PM
FX-5000
ShrimpBrime's Avatar
Rep: 67 (Unique: 48)
Now this is a very impressive build!! I mean it's big and wonderfully built. I think I read OP at 1750w of TECs!
6 X 331watt 31volt TEC's
6 X 224watt 24volt TEC's
I'm very curious the part numbers for these TECs!! I've been using a Singe TEC# 12715 Qmax of only 136W but was the largest watt TEC I could find that fit easily under most waterblocks at only 40mm. Do you have a couple of part numbers?
Maybe a suggestion for a single TEC solution?
ShrimpBrime is offline
