Full System TEC cooling - Page 11 - Overclock.net - An Overclocking Community
post #101 of 126 (permalink) Old 04-10-2019, 05:16 AM - Thread Starter
toolmaker03's Avatar
Rep: 90 (Unique: 68)
Quote: Originally Posted by ShrimpBrime View Post
Now this is a very impressive build!! I mean it's big and wonderfully built. I think I read OP at 1750w of TECs!
6 X 331watt 31volt TEC's
6 X 224watt 24volt TEC's
I'm very curious the part numbers for these TECs!! I've been using a Singe TEC# 12715 Qmax of only 136W but was the largest watt TEC I could find that fit easily under most waterblocks at only 40mm. Do you have a couple of part numbers?
Maybe a suggestion for a single TEC solution?
lets start with the 224watt 24volt TEC's they are 40mm X 40mm. TEC model # 19911-5P31-15CQ-WT.
https://customthermoelectric.com/199...er-module.html
and the 331watt 31volt TEC's they are 50mm X 50mm. TEC model # 26311-5P31-17CW.
https://customthermoelectric.com/263...er-module.html
now I do suggest having the ruggedized epoxy upgrade done to the TEC's as this makes them a lot stronger, I asked for the wire upgrade to make the wires harder to pull out. this is a $20 upgrade per TEC, but I would say that it is well worth it.
https://customthermoelectric.com/cus...c-options.html
The following Epoxy based syntactic foam ruggedization seals the TEC from moisture and debris AND also strengthens the TEC against shock, vibration, and shear forces.
SE = Epoxy edge seal, 2+ mm deep
SR = Epoxy Ruggedized Sealing, 5+ mm deep
SRX = Epoxy Ruggedized Sealing, 5+ mm deep, with epoxy potting to extend around lead wires following width and thickness of TEC
SRD = Epoxy Ruggedized Sealing, 10+ mm deep or complete fill
SRDX = Epoxy Ruggedized Sealing, deep to 10+ mm or complete fill with epoxy potting to extend around lead wires following width and thickness of TEC
I got the SRX upgrade.
https://www.overclock.net/forum/rigbu...tle=AMD+AM3%2B
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is offline
post #102 of 126 (permalink) Old 04-10-2019, 03:33 PM
FX-5000
ShrimpBrime's Avatar
Rep: 67 (Unique: 48)
Most excellent! Them 40mm TECs aren't cheap at 50 bucks a crack!! BUT they are twice the strength than the one I use now. It's done very well through the years for me on occasional usage.
The one I had gotten came pre-sealed. Here's the data sheet. http://www.thermonamic.com/TEC1-12715-English.PDF
Purchased that from e-bay years ago. It was 10 bucks maybe?
So a little history and where it led me, might help you at some point in the future while I fully understand what you HAVE accomplished! _______
When I tried cooling a water loop, I found it near impossible. By reading some of this thread and your build, I was actually in shock at the amount of time effort and money involved with this setup. So I went thinking back to many experiments even down to making water blocks from poured aluminum custom castings, basically a block with holes drilled through it. Discovering it froze the block really easily, I thought perhaps cooling liquid with a few would do the trick. Well, like your system, needed a LOT of heat dissipation from the TECs. And that was a entire separate challenge as you have displayed here!
Always having ideas but limited time I was trying to make a different type of cooler with the blocks I made. Basically chilling the water on the inside of the blocks for the cpu cooling wasn't enough. I figured by using ALL of the surface area to cool the chilling loop, I'd have to run the water ON the blocks and then loop them INTO and through the blocks then straight to the cpu. With project delays, I never was able to make this reality. This was just one of very many ideas to actually USE as much of the TECs cooling capability as possible. Running water through the blocks just didn't supply enough cooling to the surface area of the water passing though. Gah. Wish I had the time for this one. I figure I was loosing 60% or more cooling capability passing water just and only through the water block.
Any how I came to a finalization of build and probably will never turn a cheek to it. It was the one and only way I could run a TEC, Freeze a Cpu and just have fun (not intended for daily use... but could) gaming benchmarking, experimenting with processors (all AMD chips) hitting clocks impossible even with a custom ambient loop. I run a Geothermal water loop to cool my TECs. It's super simple, pretty darn cheap to run and provides a super constant water delta and nice and cool too!! Tap to Drain or geothermal to sound cool seems to have had THE best effect for chilling a TEC and even processors over anything and everything I've ever tried set aside a pond pump in a bucket of Ice Water. The TEC sits on a decent cold plate, 1/8" thick 50mm x 60mm and that's right on top of the processor.
Any how, you are totally living a dream of mine and I really love this thread and others like it. + Rep all day and any one reading this thread should double up on that.
Let me read the thread all the way through though. You're adding more Rads, that I read (going backwards from here) but I have some questions for sure. They may already been answered though......
Big props man. I really dig this. I examined your picture/s a lot. Crazy awesome build man. Keep at it.
Might have to pick up one of those 224W TECs for sure. Right now I can idle a Ryzen 2700x at -25c and colder. At a load it's a little more challenging! XD
ShrimpBrime is offline
post #103 of 126 (permalink) Old 11-27-2019, 08:56 PM - Thread Starter
I love this time of year I just got a GTX 1080 ti for $425 I am now ready to build a intel 1151 system with a 9700 CPU. should have the new system up in a few months.
https://www.amazon.com/Gigabyte-GV-N...KCN0FY6WXXJNZJ
below is what I am thinking of building.
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
post #104 of 126 (permalink) Old 11-28-2019, 04:06 AM - Thread Starter
well that sold out fast less than 4 hours.
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
post #105 of 126 (permalink) Old 11-28-2019, 04:41 AM
Hardware Princess
Hydroplane's Avatar
Rep: 37 (Unique: 29)
3700x and 3800x (sometimes, when it's on sale) are around that price, as well. Though Intel is more fun to OC especially when you get below the dew point
Also, I see you got the Waterforce WB, great card, I have two. No complaints, been OC'd since day one. Well maybe one complaint, the rgb color change program from Gigabyte is hopelessly broken, hope you like red lol
CHILLER DESTRUCTION
Build Log - White Voodoo
basic linux pc
(15 items)
Z390 Station
(11 items)
7980XE @ 4.3 GHz 1.10v
Asus Rampage VI Apex
2 x Aorus Waterforce WB 1080 Ti @ 2037/6318
Trident Z 16gb 3200c14 @ 3800c16 1.50V (the other two sticks were sacrificed)
960 Evo 1TB
EVGA 1600 T2
HWLabs GTR 420+280 Rads
7 x Noctua Industrial 140mm 3000 RPM Fans
EK D5 Pump/Res (with RGB!)
LD Cooling PC-V7
Operating System
Linux Mint 19.6
NEC PA271W
Keyboard
Razer Blackwidow Chroma V2
Mouse
Logitech M510
Mousepad
anime tiddy mousepad
9900K @ 5.4 1.50v
EVGA Z390 Dark
Titan RTX 2085/8500
Trident Z 3200c14 @ 4600c20 1.5v
970 Evo Plus 250gb
silverstone 1200 from 2008 (other one exploded)
HWLabs GTX 360 Rad (in RED)
3x EK Vader 120mm 2200rpm Fans
Dimastech Test Bench
AOC Agon AG251FZ 240Hz
Audio
Built-in Monitor Speakers (3 watt)
Dual Intel Xeon L5520 2.26 GHz
48 GB Samsung DDR3-1066
120 GB Samsung 750 Evo SSD
2 TB Western Digital Green
2 TB Hitachi 7200 RPM
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
Hydroplane is offline
post #106 of 126 (permalink) Old 11-28-2019, 07:46 AM - Thread Starter
well at this point in the build process, I try to look at what water blocks are available, and what motherboards they fit, before I buy anything. in this case, it looks like I will need to get the gigabyte z390 master motherboard. so that I can get a bitspower mono block that fits the motherboard. also considering just getting a 9700K from Silicon lottery binned at 5Ghz.
I am also looking at getting some M.2 SSD's for this system.
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
post #107 of 126 (permalink) Old 11-28-2019, 07:51 AM
Hardware Princess
Hydroplane's Avatar
Why monoblock? Z390 VRMs generally stay pretty cool
CHILLER DESTRUCTION
basic linux pc
(15 items)
Z390 Station
(11 items)
960 Evo 1TB
EVGA 1600 T2
LD Cooling PC-V7
Operating System
Linux Mint 19.6
NEC PA271W
Keyboard
Mouse
Logitech M510
Mousepad
9900K @ 5.4 1.50v
EVGA Z390 Dark
Titan RTX 2085/8500
970 Evo Plus 250gb
Audio
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
post #108 of 126 (permalink) Old 11-28-2019, 08:01 AM - Thread Starter
yes that is very true, and with this insane cooling system I built. I would like to show that it really is a full system cooling solution, for the CPU, motherboard, and video card.
ok so I have been running this cooling system on a AMD FX8350 CPU and a ATI 5850 video card. at this point I have 8 360mm radiators cooling the 6 224watt TEC's and 16 360mm radiators cooling the 6 331watt TEC's. the hot side water loops, with the system at load, will stay below 30C on both hot side water loops. and the cold side water loop stays below -10C at load. with this new system, I am expecting it to run as warm as 5C at load. still it is a nice cold water loop, and container for the system to operate within.
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
post #109 of 126 (permalink) Old 11-29-2019, 06:46 AM
Hardware Princess
Hydroplane's Avatar
Nice temps Do you still use clay for insulation? If so, what kind? Looks like it would be easier to install than the eraser typically used to insulate mobos
CHILLER DESTRUCTION
basic linux pc
(15 items)
Z390 Station
(11 items)
960 Evo 1TB
EVGA 1600 T2
LD Cooling PC-V7
Operating System
Linux Mint 19.6
NEC PA271W
Keyboard
Mouse
Logitech M510
Mousepad
9900K @ 5.4 1.50v
EVGA Z390 Dark
Titan RTX 2085/8500
970 Evo Plus 250gb
Audio
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
post #110 of 126 (permalink) Old 11-29-2019, 06:58 AM
skupples's Avatar
Rep: 630 (Unique: 342)
great news. That means the 2x I'm putting up this evening will fly!
skupples is online now
