Full System TEC cooling - Page 12 - Overclock.net - An Overclocking Community
post #111 of 151 (permalink) Old 11-29-2019, 05:17 PM - Thread Starter
toolmaker03's Avatar
Rep: 95 (Unique: 72)
Quote: Originally Posted by Hydroplane View Post
Nice temps Do you still use clay for insulation? If so, what kind? Looks like it would be easier to install than the eraser typically used to insulate mobos
well this is a good question. I do use the eraser putty, in fact that is what is in-between the water blocks. eraser putty goes on as a soft putty but hardens to a substance more like foam. this works great between the water blocks so the hot water blocks do not effect the cold ones. than I covered the entire cold side water loop in two layers of foam. finally I covered the entire cold side water loop all the way to the chill box, in a 1/4" clay. the clay seals the cold side water loop away from the ambient temperatures in my room. it also keeps things like the water pumps, cool, and dry. as they stay around the same temp as the cold side water.
I use molding clay, it is more expensive than normal clay. to give some reference I did use between 50-60 LBS of clay to cover the cold side water loop.
https://www.overclock.net/forum/rigbu...tle=AMD+AM3%2B
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is offline
post #112 of 151 (permalink) Old 12-04-2019, 12:02 PM - Thread Starter
well I have one part now I just need the rest of the parts to build a PC.
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
post #113 of 151 (permalink) Old 12-04-2019, 12:16 PM
u broke 666 rep :(
skupples's Avatar
Rep: 681 (Unique: 361)
yep, hopefully Sandman and co. gets a fat check.
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
KAIHL Switches < CHERRY Switches, 10/10, blind taste test @ work.
skupples is offline
post #114 of 151 (permalink) Old 12-04-2019, 03:11 PM
Hardware Princess
Hydroplane's Avatar
Rep: 38 (Unique: 30)
Nice GPU! Let me know if you have any luck with the Gigabyte program to change the color, doesn't work for me at all lol. Stuck with red RGBs
CHILLER DESTRUCTION
Build Log - White Voodoo
basic linux pc
(15 items)
Z390 Station
(11 items)
7980XE @ 4.3 GHz 1.10v
Asus Rampage VI Apex
2 x Aorus Waterforce WB 1080 Ti @ 2037/6318
Trident Z 16gb 3200c14 @ 3800c16 1.50V (the other two sticks were sacrificed)
960 Evo 1TB
EVGA 1600 T2
HWLabs GTR 420+280 Rads
7 x Noctua Industrial 140mm 3000 RPM Fans
EK D5 Pump/Res (with RGB!)
LD Cooling PC-V7
Operating System
Linux Mint 19.6
NEC PA271W
Keyboard
Razer Blackwidow Chroma V2
Mouse
Logitech M510
Mousepad
anime tiddy mousepad
9900K @ 5.4 1.50v
EVGA Z390 Dark
Titan RTX 2085/8500
Trident Z 3200c14 @ 4600c20 1.5v
970 Evo Plus 250gb
silverstone 1200 from 2008 (other one exploded)
HWLabs GTX 360 Rad (in RED)
3x EK Vader 120mm 2200rpm Fans
Dimastech Test Bench
AOC Agon AG251FZ 240Hz
Audio
Built-in Monitor Speakers (3 watt)
Dual Intel Xeon L5520 2.26 GHz
48 GB Samsung DDR3-1066
120 GB Samsung 750 Evo SSD
2 TB Western Digital Green
2 TB Hitachi 7200 RPM
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
Hydroplane is offline
post #115 of 151 (permalink) Old 12-05-2019, 05:30 PM - Thread Starter
well with my last two system I ended up using two GTX580's on each build. I did try a 4 way build with the 580's, but I could not really justify the build as almost no games utilized that configuration of the cards.
so with this build I decided to go ahead and get a second GTX1080 ti for the build as about half of the games I have will utilize the duel card setup. I hope that more of the new games will take advantage of the Nvlink that is being developed today.
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
post #116 of 151 (permalink) Old 12-05-2019, 05:40 PM
u broke 666 rep :(
skupples's Avatar
vulkan has shown promising dual GPU stuffs, and seems to be getting more and more air time(RDR2 dual GPU works in vulkan, for example). NVidia has also finally started to work with checkerboard rendering, so that'll be showing up in a live driver at some point in the future
I have high hopes really, as there's no other way top tier VR is gonna work really damn well. high frames, at high resolutions, x2ish? so hopefully SLIVR and similar techs keep advancing as well.
skupples is offline
post #117 of 151 (permalink) Old 12-11-2019, 09:44 AM - Thread Starter
I got my second card today.
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
post #118 of 151 (permalink) Old 12-13-2019, 03:47 AM - Thread Starter
ok so I guess I should give a time frame and some understanding as to why it has been so long. I have about $100 extra a month to spend on what ever I like. I have spent the last 10 months saving up that money for the purchase of a new video card. I ended up being able to get two video cards for this build, but now I am broke. so I need another $600 to $1000 to finish getting all the parts I need for a new build. this means it will be another 6 to 10 months, before I will have the new build together, and running inside the chill box.
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
post #119 of 151 (permalink) Old 12-15-2019, 11:22 AM - Thread Starter
ok, so because this is a chilled water build I have to remove the water blocks from the video cards and replace the thermal paste, and pads, with artic silver ceramic. this is because normal thermal paste and pads do not react well in cold environments. the paste becomes dry, and the pads become hard and brittle. so much for getting the video cards, with water blocks already attached.
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
post #120 of 151 (permalink) Old 12-26-2019, 04:22 AM - Thread Starter
well I just got a second HWL 240mm radiator for the chill box, this way they are the same type of radiator. as for the alpha cool 240mm radiator, I will be adding that to my internet computer. so my internet build will have a total of 4 radiators, when I do the next upgrade to that build. I am adding a total of two alpha cool 240mm radiators, and replacing the bitspower reservoir, with a water cool glass reservoir. so my internet computer, will have the two 360mm radiators it has now, and two new 240mm alpha cool radiators, added to it's water loop.
my internet computer is below, I will start a new thread in water cooling, when I do these upgrades.
