Full System TEC cooling - Overclock.net - An Overclocking Community
post #1 of 140 (permalink) Old 01-29-2018, 12:34 PM - Thread Starter
toolmaker03's Avatar
Rep: 93 (Unique: 70)
https://imgur.com/a/3fywM
ok, so after 6 builds, and 170 pages, I have a final build. this is where I am at so far, I am currently using 12 TEC's for a total of 1740watts of TEC cooling. all the TEC's will be water cooled, with a total of 24 CPU water blocks being used. I now have 24 radiators for this build, 16 radiators on the 331watt TEC's, and 8 radiators on the 224watt TEC's.
ok I am going to try and detail a complete parts list.
6 X swiftech 360mm radiators
18 X Flex Aluminum 360mm radiators
1 X UT60 alphacool 240mm radiator
1 X hardware labs 240mm radiator
44 X 120mm fans
2 x bitspower reservoirs
1 X watercool reservoir
8 X swiftech D5 water pumps
1 X koolance D5 strong water pump
3 X 600watt 13.2volt power supplies
3 X 1200watt 26.4volt power supplies
3 X 100amp PWM motor controllers
6 X bitspower TR4 CPU water blocks
6 X barrow 2011 CPU water blocks
6 X Frozen Q AM3 CPU water blocks
3 X XSPC AM3 CPU water blocks
3 X watercool universal CPU water blocks
6 X 331watt 31volt TEC's
6 X 224watt 24volt TEC's
2 X fan controllers
6 X switches
3 X 24volt 200amp relays
3 X 12volt 200amp relays
54 X bitspower 3-way 90 degree fittings
30 X 3mm male to male fittings
3 X Y fittings
28 X XSPC T fittings
3 X koolance flow meters
3 X XSPC temperature sensors
10 X bitspower & barrow 1/4 turn valves
8 X adjustable SLI fittings
14 X bitspower & EK 50mm extension fittings
12 X barrow 40mm extension fittings
61 X koolance 3/8" ID 5/8" OD compression fittings
14 X koolance 3/8" barbs
18 X bitspower male to male rotary fittings
1 X koolance 12volt to 24volt pump motor step up.
2 x XSPC temp sensor displays
1 X koolance flow meter display
2 X power and reset switches
4 X bitspower plastic T fittings
2 X bitspower plastic 90 degree fittings
1 X 100' total of 10AWG wire
3 X 12volt to 24volt 20amp step up's
1 X 250' total of 5/8" ID 1" OD norprene insulation
1 X 50' total of 3/8" ID 5/8" OD tubing
12 X fan wire splitters
24 X fan wire extensions
8 X temperature sensor wire extensions
1 X 50 pounds of molding clay
1 X 400 zip ties
1 X 50' of 3/4" aluminum angle
1 X 8' of 2" plastic angle
1 X enermax 850watt PC power supply
1 X OCZ 1200watt PC power supply
1 X 100 M3 12mm bolts, 200 M3 washers, 100 M3 nuts
1 X 100 M4 50mm bolts, 400 M4 washers, 200 M4 nuts
8 X 200mm M4 bolts
8 X 70mm M4 bolts
64 X tension springs
https://www.overclock.net/forum/rigbu...tle=AMD+AM3%2B
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is offline
post #2 of 140 (permalink) Old 01-29-2018, 12:44 PM
Perennial Noob
jvillaveces's Avatar
Rep: 22 (Unique: 15)
The only things I recognize in that picture are the Aquaero and the rads! Is there a PC in there or is this just the cooling system?
Esmeralda
(25 items)
Eldorado
(23 items)
Overkill HTPC
(18 items)
Intel Core i7-6850K
RAMPAGE V EDITION 10
NVIDIA TITAN X (Pascal)
Corsair Dominator Platinum Special Edition Blackout
Samsung 960 Pro M.2
Samsung 850 Pro
Samsung 850 Pro
Samsung 850 Pro
Samsung 850 Pro
Seasonic SS-1200XP3 PLATINUM
EK-FC GeForce GTX FE Copper/Plexi Water Block (For GeForce 1060/1070/1080/1080Ti/TitanX Pascal and Titan Xp) -Nickel/Plexi Change
EK-FB ASUS R5-E10 Monoblock RGB Edition
Aquacomputer D5 Pump Mechanics USB with Aquabus (x2)
EKWB EK-XTOP Revo D5, Plexi (x2)
Watercool Heatkiller Tube 150
Black Ice SR2 420 radiator
Alphacool X-flow Nexxxos 420 radiator
Noctua SSO2 Bearing Fan NF-A14 iPPC-2000 PWM (x6)
Aquacomputer Aquaero 6 Pro
HexGear R80 Black
Operating System
Windows 10 Pro 64 bit
Asus ROG Swift 24
Keyboard
Razer Blackwidow Ultimate (Green)
Mouse
Corsair Sabre RGB 10,000 DPI
i7 4790k
Asus Z97-Deluxe
EVGA GeForce GTX980 Ti SC ACX2.0
Corsair Dominator Platinum 2133 MHz
Samsung 850 Pro
Optical Drive
Asus DRW-24B1ST
Corsair AX 1200i
EK Supremacy EVO nickel-plexi
Monsoon Free Center compression fittings (gold)
PrimoChill PrimoFlex Advanced LRT crystal clear
EK-FC Titan X - Nickel (x2)
Alphacool 140mm
Aquaero 6 Pro
Alphacool Nexxxos XT45 280 mm
Black Ice GTS 280 x 60
aquacomputer d5 pump mechanics with usb and aquabus interface (x2)
Bitspower Dual D5 Mod Top - POM Version
Bitspower D5 / MCP655 Pump Mod Top S Model - Acetal
Bitspower Water Tank Z-Multi 150 Inline Reservoir (true brass version)
Corsair 760T
Operating System
Windows 10 Pro x64
Keyboard
Razer Ultimate
core i5 6500
Asus Maximus VIII Gene
EVGA GeForce GTX 980 Ti 6GB SC+ GAMING ACX 2.0+
Corsair Vengeance LPX 16GB (4 x 4GB) DDR4 DRAM 2133MHz C13
Samsung 950 PRO -Series 256GB PCIe NVMe - M.2 Internal SSD 2-Inch MZ-V5P256BW
Optical Drive
Pioneer Electronics Internal Blu-Ray Writer (BDR-2209)
Seasonic 1050 Watt Gold
EK Coolstream SE 240
EK Coolstream SE120
Swiftech MCP655 PWM
EK-XRES 100 Revo D5 Pump Top/Reservoir - Acetal
EK-FB ASUS M8G Monoblock - Nickel
EK-FC Titan X/GTX980 Ti Waterblock - Nickel
Monsoon Free Center Hardline Compression Fittings, 1/2" x 5/8"
Monsoon PETG Hardline Tube 1/2 x 5/8
EK-Vardar F4-120 (2200rpm) High Performance Liquid Cooling Fan
Steiger Dynamics LEET Chassis
Operating System
Windows 10 Home
jvillaveces is offline
post #3 of 140 (permalink) Old 01-29-2018, 12:47 PM - Thread Starter
currently, that is a pic of the cooling system only. the PC is going inside of a wine cooler. (chillbox)
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
post #4 of 140 (permalink) Old 01-29-2018, 12:48 PM
Typo Elemental
Simmons572's Avatar
I can't believe it, we're actually looking at an operational product! This is definitely a long time coming.
Are you still planning on putting everything in the coolers like you were planning to do at one point? What about the modeling clay?
AMD Threadripper 1900x
Asus Prime X399-A
EVGA 1080 Classified
Samsung 960 Evo
Intel 750 Series 400GB U.2
Samsung 850 Pro 512 GB
Seasonic 1050w 80+ Gold
Corsair Air 740
Operating System
Windows 10 Pro
i5 6600k
Asus Z170i Pro Gaming
Sapphire R9 Nano
Kingston FURY 16GB (2 x 8GB) DDR4-2400
Samsung 950 Pro 512 GB
Athena AP-MFATX40 400W Flex-ATX
be quiet! ​PURE ROCK ​SLIM
Lian-Li PC-TU 100B
Operating System
Windows 10 Pro
ViewSonic XG2401
Keyboard
MK Disco RGB TKL (KBT Brown)
Mouse
Razer Mamba TE
Mouse
Razer Firefly Cloth
Audio
Beyerdynam​ic DT 770 ​Pro 80 ohm
Audio
Antlion Audio ModMic 4 w/ Mute
Audio
Schiit Fulla 2
Other
Noctua NF-A9x14 (x2)
Other
Fractal Design FD-FAN-SSR2-92
Other
Fractal Design FD-FAN-SSR2-60 (x2)
Other
Fractal Design GP12-WT
i7 6800k
Xeon e5-1620 V3
EVGA Micro 2
Asus GTX 780
Sapphire Fury X
Sapphire RX 480
Kingston - FURY 8GB (2 x 4GB) DDR4-2400
ADATA - XPG Z1 8GB (2 x 4GB) DDR4-2400
SanDisk - SSD PLUS 240GB
Kingston - SSDNow V200
Corsair HX850i
be quiet! - PURE ROCK
Thermaltake Core V21
Operating System
Windows 10 Pro
Simmons572 is offline
post #5 of 140 (permalink) Old 01-29-2018, 01:08 PM
The 6502 Still Rocks
Master Chicken's Avatar
Rep: 30 (Unique: 28)
The beast. If I hadn't been following along all this time, I'd have trouble deciphering that picture.
Master Chicken is offline
post #7 of 140 (permalink) Old 01-30-2018, 03:38 AM - Thread Starter
the last thread was getting to long, so I decided to create a new thread to cover the end of this last build. you may have noticed that I am going a lot slower on the build this time, the reason for this is that I am testing everything before I finalize it on the build. this process takes longer, but I think that the end result will be a hassle free build upon completion. I am done building this rig, I have made a stopping point, and I am sticking to that. 12 TEC's are enough to give me 3 times the load of the system in TEC cooling, and that is really all I need. as the years pass, I may upgrade this system, but I will not add more TEC's to it. if the last build, with 9 TEC's, had provided me with just a little better drop from ambient than 8C with the system at load, I would have stopped there.
I know that I have not been showing all of the testing I have been doing, but is hard to test, and take pics at the same time. as well I am a red neck when it comes to building my test rigs. so they are dangerous, and I would not want others to try doing, what I am doing with my test builds, as destroying stuff is highly possible, with the way I throw it together.
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
post #8 of 140 (permalink) Old 01-31-2018, 06:20 AM
lzf995 is offline
post #9 of 140 (permalink) Old 02-05-2018, 12:37 PM - Thread Starter
ok, so for a update on the TEC's I sent back to be fixed. CTE decided to simply replace, rather than fix, the TEC's I returned to them, I can not complain about that kind of service. I am not a big costumer by any means but for me I have already spent about $1200 on there TEC's, and for them to treat me this well gives me good reason to continue getting there products and get even better ones next time. so as these TEC's begin to fail I will replace with metallized, ruggedized, versions, of course those will be $200 TEC's each but I feel like they will make for nice upgrades to the ones I have now.
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
post #10 of 140 (permalink) Old 02-05-2018, 09:30 PM
You went with metalized surfaces on the new ones? Better heat transfer?
