Coollaboratory Liquid Ultra vs Liquid Pro vs Phobya Liquid Metal - Page 11 - Overclock.net - An Overclocking Community
post #101 of 371 (permalink) Old 07-25-2013, 02:12 PM
SonDa5's Avatar
Rep: 154 (Unique: 113)
I just switched out CLP for CLU and the results are nearly the same.
100% load with Linpack AVX2 @4.4GHZ 4770k 1.2v.
CLP 68 75 77 72 Ambient Temps 24C
CLU 68 75 75 73 Ambient Temps 24C
CLU barely won in my test. I like both of em. CLP is hard to clean. Not sure how hard CLU is to clean yet.
This is on a water cooled bare die direct to block no IHS mount that I have nearly perfected between 3570k mounts, 3770k mounts and now 4770k mounts. I feel confident it is a flat contact mount.
SonDa5 is offline
post #102 of 371 (permalink) Old 07-25-2013, 02:30 PM - Thread Starter
Aussie Overclocker
tw33k's Avatar
Rep: 178 (Unique: 144)
I found ultra way easier to clean.
x99 Test Bench
9900K
ASUS ROG Maximus XI Hero (wifi)
ASUS GeForce GTX 1070
16GB (2x8GB) G-Skill Trident Z F4-3600C16D-16GTZ
Samsung 950 Pro 256GB| Crucial M4 128GB | 1TB F3 | 2TB WD Black
Optical Drive
Samsung BD-ROM
Seasonic 1050W Platinum
Black Ice GTX 480
FrozenQ Liquid Fusion X4 Quad Spiral Reservoir
EK-XTOP Revo D5 PWM Pump
EK Velocity RGB
Alphacool NexXxoS GPX - Nvidia Geforce GTX 1070 M02
Corsair Obsidian 900D
Operating System
Windows 10 Pro x64
27" Acer CB271HU (2056 x 1440)
Keyboard
Microsoft Wireless 5500
Mouse
Microsoft Wireless 5000
Intel 5960X
ASUS X99 Deluxe
Sapphire R9 270X Toxic
G.Skill 32GB (4 x 8GB) PC4-25600 3200MHz DDR4 RAM - 16-18-18-38 - Trident Z Series
Corsair AX760i Platinum
Swiftech H240-X
Lian Li T60
Operating System
Windows 10 Pro 64bit
ACER B273HU
Keyboard
Microsoft Wireless 5050
Mouse
Mouse
Razer Destructor 2
tw33k is offline
post #103 of 371 (permalink) Old 07-27-2013, 03:50 PM - Thread Starter
Aussie Overclocker
tw33k's Avatar
Test System
Intel 3770K @ 4.8GHz 1.2v
ASRock OC Formula
G-Skill Trident X 16GB 2400MHz
Corsair H100i (low fan speed)
SanDisk Extreme 120GB SSD
Corsair AX760i PSU
Aida64 was run for 1 hour stressing FPU only
Ambient temperature was recorded at the start, after half an hour and at the finish using a digital thermo sensor
Phobya
• Easy to spread
• Easy to clean off
• Ran test 3 times to confirm results. 3rd test was aborted due to temp hitting high 60s
Liquid Pro
• Takes some time to spread on HIS
• Pain to clean off
• Test was run 2 times to confirm results
Liquid Ultra
• Very easy to apply
• Used a tiny amount. I wiped it off the end of the syringe with the brush and onto the die
• Very easy to clean off
I know some people are going to dispute the vailidity of these results but I stand by them. During the first Phobya test, I thought I did something wrong so when it finished I immediately removed the chip, cleaned it and reapplied for a second test. I ran a third test to confirm and published the best result. Also, when I saw how much the Ultra beat the Pro by, I re-ran the test with Pro to confirm results.
x99 Test Bench
9900K
Optical Drive
Samsung BD-ROM
Black Ice GTX 480
EK Velocity RGB
Operating System
Windows 10 Pro x64
Keyboard
Mouse
Intel 5960X
ASUS X99 Deluxe
Swiftech H240-X
Lian Li T60
Operating System
ACER B273HU
Keyboard
Mouse
Mouse
Razer Destructor 2
tw33k is offline
post #104 of 371 (permalink) Old 07-27-2013, 04:37 PM
Rep: 63 (Unique: 48)
Dayum, gotta get me some of dat Ultra.
kbab?
Stige is offline
post #105 of 371 (permalink) Old 07-28-2013, 01:58 AM
SonDa5's Avatar
Originally Posted by tw33k View Post
Test System
My testing has been with water cooled bare die direct to block mount and my results were very close. I have mounted my block at least a dozen times and I have it down. I think your mounts was not the same in between tests.
SonDa5 is offline
post #106 of 371 (permalink) Old 07-28-2013, 12:23 PM
RnRollie's Avatar
Rep: 160 (Unique: 125)
if CLU is such a problem -drying out, losing performance- has anybody contacted CoolLabs yet, and what was their reply?
Reality is futile, you will be assimilated by (your) perception.
Golden Rule(s) for Fans: CHEAP + SILENT = NO PERFORMANCE ▼ CHEAP + PERFORMANCE = NOT SILENT ▼ SILENT + PERFORMANCE = NOT CHEAP
+Most SILENT Case Fans are not well suited for CPU-HS-Towers or Radiators
+Most SILENT Case Fans are not well suited for cases, especially if they have filters. (added by doyll on 23/04/2014)
RnRollie is offline
post #107 of 371 (permalink) Old 07-28-2013, 01:40 PM - Thread Starter
Aussie Overclocker
tw33k's Avatar
I ran the tests multiple times because I thought I did something wrong but got the same results each time. I'd like to see your results as a comparison.
x99 Test Bench
9900K
Optical Drive
Samsung BD-ROM
Black Ice GTX 480
EK Velocity RGB
Operating System
Windows 10 Pro x64
Keyboard
Mouse
Intel 5960X
ASUS X99 Deluxe
Swiftech H240-X
Lian Li T60
Operating System
ACER B273HU
Keyboard
Mouse
Mouse
Razer Destructor 2
tw33k is offline
post #108 of 371 (permalink) Old 07-29-2013, 04:33 AM
SonDa5's Avatar
First of all if your chip delidded? Are you running direct block to die or with IHS?
SonDa5 is offline
post #109 of 371 (permalink) Old 07-29-2013, 05:32 AM
deepor's Avatar
Rep: 464 (Unique: 312)
He wrote it's delidded. The test is with CLU/CLP/PLM painted on die, IHS inside, IHS outside, cooler's base.
deepor is offline
post #110 of 371 (permalink) Old 07-29-2013, 10:48 AM
SonDa5's Avatar
I don't see where he wrote that but if he did sandwhich the IHS with CLP its so thin and with the IHS in there the chances of poor contact on mount is high. Bare diwe contact with only surface of block making contact is a lot more accurate for getting good mounts and that is how's I did my tests.
SonDa5 is offline
