What is this: Just Cooler System DeHumidifier - Overclock.net - An Overclocking Community
post #1 of 24 (permalink) Old 01-30-2007, 12:44 PM - Thread Starter
Retired Staff
Rep: 4426 (Unique: 2045)
What is this? Is it dehumidifier or a humidifier for you PC? If the latter, what moron invented this? If it is a dehumidifier, maybe an interesting investment for sub-ambient cooling assuming it is powerful enough. I don't get it... 1.4w power consumption for heater AND fan?
http://www.outletpc.com/c1968.html
Key Selling Points: Keep your system cool by humidifying it! This Just Cooler DR-100 system dehumidifier keeps the slots and pins on your motherboard clean! It's easy to install, just attach to a vacant slot on the motherboard and let the moisture begin.
Specifications:
Model: Just Cooler System DeHumidifier - DR-100
Item No: C1968
General Features:
• Built-in heater to heat up water mist
• Low noise
• Keep slots and pins clean
• Easy to install
Specifications:
• MTBF: 20,000 hours
• Speed: 35,000 RPM
• Airflow: 18 CFM
• Voltage: DC 12V
• Current: 0.12A
• Power: 1.44W
To answer most of your questions: (1) a fridge cannot cool a PC (2) 64-bit OS for over 3.4GB (3) If a PCIe card fits, it should work (4) Resolution, not screen size (5) Report, not respond to Spam (6) Single-Rail/Non-Modular PSUs are not always better than Multi-Rail/Modular (7) Sequential does not matter as much as random for OS drives (8) Requirements come before hardware for servers
DuckieHo is offline
post #2 of 24 (permalink) Old 01-30-2007, 03:28 PM
AARDVARCUS's Avatar
Rep: 58 (Unique: 52)
What kind of retard invented this?!? It is a heater that sprays out water. This will go perfectly for raising case temps and rusting your case....
AARDVARCUS is offline
post #3 of 24 (permalink) Old 01-30-2007, 03:31 PM
Snerp's Avatar
Rep: 385 (Unique: 225)
I'm guessing it's a Humidifier. It turns your computer into a cigar box
Makes you wonder....
FAQ: Teflon Tape...USE IT!
OSAMT: "Member of OCN Songwriter and Musician Thread"
Proud Member of the OCN Mechanical Keyboad Club!
Snerp is offline
post #4 of 24 (permalink) Old 01-30-2007, 03:32 PM
Akhen's Avatar
Rep: 127 (Unique: 107)
*shudders*
Akhen is offline
post #5 of 24 (permalink) Old 01-30-2007, 04:00 PM
hvacgaspiping's Avatar
Rep: 71 (Unique: 54)
Dumb***** engineering!
cheers.gif Proud member of Team Folders, Inc.
hvacgaspiping is offline
post #6 of 24 (permalink) Old 01-30-2007, 04:06 PM
Snerp's Avatar
This is cheap phase change cooling
Snerp is offline
post #7 of 24 (permalink) Old 01-30-2007, 04:18 PM
AARDVARCUS's Avatar
Just think, get 5 or 6 and it will really moisten things up. Better yet, put your computer in the oven on high with a garden hose spraying on it!
post #8 of 24 (permalink) Old 01-30-2007, 04:27 PM
When you humidify the air for electronic equipment, the control has to be precise and the moisture added to the air must not even be close to dew point temperature. Any precipitation at all will end up in places to make things rust and corrode. I don`t see how this "System Dehumidifier" can even come close to accomplishing this. Please, don`t even consider buying one.
post #9 of 24 (permalink) Old 01-30-2007, 04:31 PM
AARDVARCUS's Avatar
Someone here needs to buy one and put it in your case, just for the lulz.
post #10 of 24 (permalink) Old 01-30-2007, 04:50 PM
biatchi's Avatar
Rep: 206 (Unique: 143)
go ahead and try it for us
#1 - The first rule of Infraction Club is, you do not talk about Infraction Club.
#2 - The second rule of Infraction Club is, you DO NOT talk about Infraction Club!!
Basically Random Idiotic Terrible Insanely Stupid Humour
biatchi is offline
