Cleaning liquid metal with more liquid metal (IHS and Copper plate) - Overclock.net - An Overclocking Community
post #1 of 6 (permalink) Old 08-15-2019, 08:31 PM - Thread Starter
SaccoSVD's Avatar
Rep: 41 (Unique: 32)
I just thought it would be useful for people curious about LM and how to clean it up.
Someone suggested to use a bit more LM to clean up between applications.
I'm using it between the IHS and my AIO copper cold plate, so after about one month I wanted to check my first application to see if everything was in order.
I naturally found the usual stain on the copper plate starting to develop.
For science, I tried cleaning the IHS with alcohol and I tried to clean the AIO copper plate with a bit more LM.
So, as expected, the IHS surface turns black with the alcohol and cleaning takes more effort.
On the copper plate adding more LM activated the stain and it all turned shiny and liquid again (was partially dry and partially still liquid before). I got a clean dry cotton pad and removed it all quite easily, also I rubbed on it a bit more with steel wool. The result was that the copper plate had a nice shiny coating, where later on I re applied a fresh paint thick coat before mounting.
So, I strongly suggest you do that. No more alcohol to remove LM.
PC Specs: 3900X - X470 Taichi - TridentZ Neo CJR 64GB 3733Mhz tight timings / 1080ti waterforce xtreme - H115i Pro with 4 fans + Lapped IHS + Liquid Metal.
Per CCX OC Settings: 4.5/4.4/4.375/4.375 at 1.331V (1.306V vdroop) Max AIDA64AVX temp 80c balanced AIO (23 room temp)
SaccoSVD is offline
post #2 of 6 (permalink) Old 08-15-2019, 08:38 PM
Skating Enthusiast
steelbom's Avatar
Rep: 146 (Unique: 117)
That's interesting... never knew that
Kasuf
(9 items)
Ryzen 3700X
MSI Tomahawk B450
ASUS Radeon RX 480 ROG Strix
Corsair Vengeance LPX 32GB 3000MHz
Samsung 850 EVO
Corsair HX750i
Noctua NH-D15
Silverstone FT05B-W
LG 34" Ultrawide (LG34UC98)
steelbom is offline
post #3 of 6 (permalink) Old 08-15-2019, 09:12 PM - Thread Starter
SaccoSVD's Avatar
I'm gonna update it in about a year from here.
SaccoSVD is offline
post #4 of 6 (permalink) Old 08-15-2019, 09:33 PM
Rep: 4 (Unique: 4)
The "stain" is the gallium leaching out of the liquid metal compound into the copper (I think it forms some sort of gallium/copper alloy). Which is also the reason liquid metal "dries up" and needs to be replaced occasionally, the gallium has leached out leaving behind the other drier components in the liquid metal compound.
clannagh is offline
post #5 of 6 (permalink) Old 08-15-2019, 10:12 PM
Falkentyne's Avatar
Rep: 396 (Unique: 283)
I'm using it between the IHS and my AIO copper cold plate, so after about two months I wanted to check my first application to see if everything was in order.
On the copper plate adding more LM activated the stain and it all turned shiny and liquid again (was partially dry and partially still liquid before). I got a clean dry cotton pad and removed it all quite easily, also I rubbed on it a bit more. The result was that the copper plate had a nice shiny coating, where later on I re applied a fresh paint thick coat before mounting.
This is pretty interesting.
Basically the hardened layer is leftover indium and tin that hardened because the gallium got absorbed. If you apply more LM, the indium and tin may realloy (there's another better word, but I forgot the word), allowing it to get wiped up again then any gallium leftover is child's play at that point.
definitely worth trying out eventually.
[email protected] ghz, RX Vega 64, 32GB DDR4, Gigabyte Aorus Master, Seasonic Platinum 1000W, Corsair 760T
Alt: MSI GT73VR Throttlebook with 7820HK @ 4.7 ghz, GTX 1070 MXM TDP mod to 230W, 32 GB RAM
Falkentyne is offline
post #6 of 6 (permalink) Old 08-16-2019, 04:56 AM - Thread Starter
SaccoSVD's Avatar
It would be really good to see someone to try this as well with a much older application.
The first one I did on my 1800X after a year looked pretty nasty. CPU and Cooler "glued" together and I had to pry them loose.
I wish I knew this trick back then.
SaccoSVD is offline
