Assassins Creed 2 stuck at 60fps maximum - Page 2 - Overclock.net - An Overclocking Community
Old 05-26-2011, 09:02 AM
Zcypot Level 1
Zcypot's Avatar
Originally Posted by ShtSh00ttr;13643337
Most people can see upwards of 100fps. The 30fps is a bit of a myth that has to do with the MINIMUM number of frames per second required to create the illusion of motion.
Light is one of the most critical components in being able to differentiate between frames. The US Air Force ran an experiment with pilots and found that 1/220th of a second is still discernible to the human eye. They flashed a plane on a dark backround at 1/220th of a second. Not only did the pilots see the object but were able to identify the type/model of the plane.
30 FPS = Minimum needed to convey motion (trick the eye) .
Anything below 30 your start to experience input lag on the hardware...I should know running dirt 3 on eyefinity with 25 fps(1 gpu no xfire yet) has about half second delay on my steering.
Zcypot is offline
Old 05-26-2011, 09:04 AM
OverTheBelow Level 1
OverTheBelow's Avatar
Actually, I think 7 or 8 is the minimum framerate required to imply motion, but otherwise your post is correct.
Support PC developers - act against piracy.
OverTheBelow is offline
Old 05-26-2011, 09:05 AM
ShtSh00ttr is an unknown quantity at this point ShtSh00ttr is an unknown quantity at this point
Well if your going get all technical....
Correction: 30 FPS is the MINIMUM required to convey the illusion of FLUID motion. LOL
Also there is a HUGE difference with blur in frame. The old wagon wheel at 24fps in analog would look more fluid as each frame as the wheel partially blurred as it was shot with a shutter speed less than the rotational speed of the wheel. That make a big difference when looking at motion video. Digital stills (think gaming) where each frame is perfectly clean of motion blur (like a digital photo at high shutter speed) requires a greater frame rate to convey fluid motion
ShtSh00ttr is offline
Old 05-26-2011, 09:07 AM
intelman Level 1
intelman's Avatar
yeah I guess 30 fps does seem low, just thought I had read that somewhere haha
intelman is offline
Old 05-26-2011, 09:42 AM
Kung Pow is an unknown quantity at this point Kung Pow is an unknown quantity at this point Kung Pow is an unknown quantity at this point
the question of the OP has already been answered.
The rest is off topic!
Kung Pow is offline
Old 05-26-2011, 12:34 PM - Thread Starter
Cancer Level 1
Cancer's Avatar
Originally Posted by OverTheBelow;13643324
Facepalm.
Seriously, why the hell does someone always spout this complete BS the minute framerate is brought up? The human eye does not see in frames, but in context is capable of detecting differences even above 100.
Anyway, I (accidentally) eliminated the 62fps cap somewhat by renaming 'AC2/videos/UBI_LOGO.bik' but I don't think it's a complete workaround. The game seems to randomly dip and rise in frames with this.
Tried that...it didn't change the 60fps cap.
People from Denmark are Danish.
Therefore, people from Benmark must be Banish!
Cancer is offline
Old 05-26-2011, 12:36 PM
The cap can´t be modified.
Just live with it 60 FPS is still nice.
If you want more get Brotherhood
Kung Pow is offline
Old 05-26-2011, 12:37 PM - Thread Starter
Cancer Level 1
Cancer's Avatar
Originally Posted by Kung Pow;13643287
Assassin´s Creed 2 has a FPS cap.
Meaining the game automatically locks the frames at 60 FPS.
Don´t worry it has nothing to do with the performance of your PC it is just done so by Ubisoft since the game is console ported and they didn´t wanna do any extra work of synthesizing frames:)
cheers.gif to the game
Stupid lazy ubisoft...they sure took the time to DRM the hell out of it.
Vsync doesn't even work for this game...it's locked at 60hz so if you have a higher refresh rate than that you're screwed apparently.
There's gotta be a hack for it somewhere.
Until I find a hack...I'll just run it at 2000x1500 resolution with 8x AA.
Stupid ubisoft....my fan isn't even audiable.
Cancer is offline
Old 05-26-2011, 12:44 PM
pursuinginsanity is an unknown quantity at this point pursuinginsanity is an unknown quantity at this point
pursuinginsanity's Avatar
Also there is a HUGE difference with blur in frame. The old wagon wheel at 24fps in analog would look more fluid as each frame as the wheel partially blurred as it was shot with a shutter speed less than the rotational speed of the wheel. That make a big difference when looking at motion video. Digital stills (think gaming) where each frame is perfectly clean of motion blur (like a digital photo at high shutter speed) requires a greater frame rate to convey fluid motion smile.gif
No, it isn't. If 30 were required for motion, movies filmed at 24 fps (like 99.9% of movies) would appear to stutter and, well, wouldn't appear "fluid" at all.
If this is the Bulldozer we've been waiting for, I'm sorry AMD, you suck.
^^^^Not much has changed on that front in oh, 5+ years eh.
pursuinginsanity is offline
Old 05-26-2011, 01:30 PM
Umn you even quoted me above stating 24fps is required in analog w/blur ... I said 24fps in analog.... rolleyes.gif
