Assassins Creed 2 stuck at 60fps maximum - Overclock.net - An Overclocking Community
post #1 of 23 (permalink) Old 05-26-2011, 07:38 AM - Thread Starter
Cancer's Avatar
Rep: 34 (Unique: 29)
With vsync on or off ingame it maxes at 60fps.
Assassin2.ini also has vsync turned off.
With ATI control panel forcing vsync always off despite application settings it maxes at 60fps...and may have caused the game to crash/reboot my computer.
(Though I am unsure of this because I have only played it for an hour and it may have been something else that did that.)
In addition to this...my refresh rate is 85hz but does my FPS top out at 85fps? Noooooooo.
Even at a maximum resolution of 2048x1536 my max refresh rate is 75hz.
This is driving me insane.
Assassin2.ini:
[Graphics]
AdapterVendorID=4098
AdapterDeviceID=26393
MonitorDesc=Generic PnP Monitor
DisplayWidth=1600
DisplayHeight=1200
RefreshRate=85
MultiSampleType=8
VSync=0
EnvironmentQuality=3
TextureQuality=2
ShadowQuality=2
ReflectionQuality=2
CharacterQuality=2
PostFX=1
People from Denmark are Danish.
Therefore, people from Benmark must be Banish!
Cancer is offline
post #2 of 23 (permalink) Old 05-26-2011, 07:44 AM
Retired Staff
Murlocke's Avatar
Rep: 912 (Unique: 541)
Why exactly would you need/want over 60fps in a game like Assassin's Creed 2? I see no point/benefits. I wouldn't be surprised if the cap is built into the game.
Just go play the game... I could see if this was a multiplayer shooter where you might want more than 60fps.
Murlocke is offline
post #3 of 23 (permalink) Old 05-26-2011, 07:50 AM
intelman's Avatar
Rep: 17 (Unique: 14)
yeah I think it's like 30 or so fps and after that the human eye can't see it anyways.
intelman is offline
post #4 of 23 (permalink) Old 05-26-2011, 07:52 AM
Assassin´s Creed 2 has a FPS cap.
Meaining the game automatically locks the frames at 60 FPS.
Don´t worry it has nothing to do with the performance of your PC it is just done so by Ubisoft since the game is console ported and they didn´t wanna do any extra work of synthesizing frames:)
cheers.gif to the game
Kung Pow is offline
post #5 of 23 (permalink) Old 05-26-2011, 07:53 AM
Antsu's Avatar
Rep: 35 (Unique: 32)
I can feel the difference to atleast 100+, I understand you bro, but can't help :/
I don't care what anyone says about human eye not seeing it, but I do.
Antsu is offline
post #6 of 23 (permalink) Old 05-26-2011, 07:55 AM
Horsemama1956's Avatar
Rep: 122 (Unique: 103)
I think he just wants it to match his refresh rate, which is 85.
Horsemama1956 is offline
post #7 of 23 (permalink) Old 05-26-2011, 07:57 AM
Zcypot's Avatar
Rep: 39 (Unique: 39)
Zcypot is offline
post #8 of 23 (permalink) Old 05-26-2011, 07:57 AM
OverTheBelow's Avatar
Rep: 53 (Unique: 50)
Facepalm.
Seriously, why the hell does someone always spout this complete BS the minute framerate is brought up? The human eye does not see in frames, but in context is capable of detecting differences even above 100.
Anyway, I (accidentally) eliminated the 62fps cap somewhat by renaming 'AC2/videos/UBI_LOGO.bik' but I don't think it's a complete workaround. The game seems to randomly dip and rise in frames with this.
Support PC developers - act against piracy.
OverTheBelow is offline
post #9 of 23 (permalink) Old 05-26-2011, 07:57 AM
Prox's Avatar
Rep: 57 (Unique: 49)
No, it's definitely not 30. I can tell a difference between 50 and 60 fps easily.
Prox is offline
post #10 of 23 (permalink) Old 05-26-2011, 07:59 AM
Most people can see upwards of 100fps. The 30fps is a bit of a myth that has to do with the MINIMUM number of frames per second required to create the illusion of motion.
Light is one of the most critical components in being able to differentiate between frames. The US Air Force ran an experiment with pilots and found that 1/220th of a second is still discernible to the human eye. They flashed a plane on a dark backround at 1/220th of a second. Not only did the pilots see the object but were able to identify the type/model of the plane.
30 FPS = Minimum needed to convey motion (trick the eye) .
ShtSh00ttr is offline
