5870 Eyefinity 6 & 500w PSU? - Overclock.net - An Overclocking Community
post #1 of 17 (permalink) Old 10-23-2011, 07:20 AM - Thread Starter
Synthetickiller's Avatar
Rep: 2 (Unique: 2)
I have a quick question.
I recently picked up a used Sapphire 5870 Eyefinity 6 for a work PC. Here's the hardware I'll be using:
CPU: Xeon E3 1270 (basically an i7 2600 non-k, but 80w)
Mobo: ASUS P8B-M LGA
Ram: 4x2gb ddr3 1333 ECC
Video: 5870 Eyefinity 6
HDD: 500GB & 2TB 7200rpm
Optical: DVD burner
PSU: Antec Earthwatts 500w
This rig will be used for 2D off work. I know it's overkill, but I wanted options for more monitors and the card was really cheap.
Will the antec be powerful enough
Synthetickiller is offline
post #2 of 17 (permalink) Old 10-23-2011, 07:23 AM
Not new to Overclock.net
TwoCables's Avatar
Rep: 6214 (Unique: 3521)
Since the card will never be used for 3D, this PSU is more than enough and then some. wink.gif
AMD recommends a PSU that has a peak capacity of 600W for a system that has one of these cards in it, but the 500W Earthwatts has a peak capacity that is over 600W.
Loneliness is a good thing to share with someone.
The virtuous spirit has no need for thankful approval, owning a certain conviction that what has been done is right.
i5-2500K @ 4.5GHz (1.368-1.384V fixed voltage)
ASUS P8P67 EVO B3 (UEFI ver. 1850)
MSI GTX 1070 Ti Gaming Titanium 8G
G.SKILL Ripjaws X 8GB (2 x 4GB) 1866MHz, CL9
250 GB Samsung 840 EVO (OS)
3 TB Toshiba P300 (D: drive)
Optical Drive
Samsung SH-S243N 24x DVD Burner
Optical Drive
Samsung SH-S203N 20X DVD Burner
Corsair RM550x
Thermaltake Frio
CM 690
Operating System
Windows 10 Home
AOC G2460PG (24" 1920 x 1080 144Hz G-SYNC)
Keyboard
Filco Majestouch 104-key Cherry MX Blues w/NKRO
Mouse
Intellimouse Optical (1.1A) 1000Hz polling rate
Mousepad
It's just a mousepad
Audio
X-Fi Titanium HD
Audio
Klipsch ProMedia 2.1 (with 16 AWG Monster Cable speaker wires)
TwoCables is offline
post #3 of 17 (permalink) Old 10-23-2011, 07:25 AM
Rep: 55 (Unique: 52)
you'll be plenty fine
adjas is offline
post #4 of 17 (permalink) Old 10-23-2011, 07:45 AM
Ken1649's Avatar
Rep: 960 (Unique: 652)
Optical: DVD burner
5870 Eyefinity6 draw approx 230w on default stock clock. Antec Earthwatts has 2 +12V rails each @22A = 264w. Do not share the +12v rail with other peripherals, use the other rail. The PSU is on the edge for 3D clocks and will be fine for desktop multi monitor real-estate but no gaming.
Ken1649 is offline
post #5 of 17 (permalink) Old 10-23-2011, 07:50 AM
TwoCables's Avatar
But multiple rails aren't added together to find the total +12V capacity.
The total +12V capacity of the 500W Earthwatts Green (EA-500D) is 444W, which is 37A.
The total +12V capacity for the original Earthwatts is 408W which is 34A.
Optical Drive
Optical Drive
Corsair RM550x
Thermaltake Frio
CM 690
Operating System
Windows 10 Home
Keyboard
Mouse
Mousepad
Audio
X-Fi Titanium HD
Audio
post #6 of 17 (permalink) Old 10-23-2011, 07:58 AM
Ken1649's Avatar
Multiple rails will have OCP at each rails. If loaded than rated will trip the OCP.
Though with multiple rails, the +12V will also shared by motherboard ATX24 Pins and for CPU.
So if OP can strictly use the card at 2D clocks and not to peg the core/memory to 3D, the PSU should be fine.
Ken1649 is offline
post #7 of 17 (permalink) Old 10-23-2011, 08:03 AM
TwoCables's Avatar
The OCP looks like it's set to 25A, based on Antec's website.
Either way, he will only be doing 2D. The only reason he got this card is to put together a multi-monitor setup (and he got a good deal on the card). It's for a system at his workplace.
Besides, the total +12V capacity is more than enough here. AMD recommends a PSU that has a peak capacity of 600W, and I'm pretty sure both 500W Earthwatt units have a peak that exceeds 600W.
Optical Drive
Optical Drive
Corsair RM550x
Thermaltake Frio
CM 690
Operating System
Windows 10 Home
Keyboard
Mouse
Mousepad
Audio
X-Fi Titanium HD
Audio
post #8 of 17 (permalink) Old 10-23-2011, 08:14 AM
Ken1649's Avatar
@ OP,
The PSU doesn't have 8-Pins PCIe power connector, you will need this 6-to-8 pins adapter if one is not included in 5870 Eyefinity6.
Ken1649 is offline
post #9 of 17 (permalink) Old 10-23-2011, 11:06 AM - Thread Starter
Rep: 2 (Unique: 2)
Thanks guys. I got the card for about the cost of a new, off-sale GTX 460. I think that's a good deal. biggrin.gif
The card came with a 2 molex to 8 pin adapter. That should be fine?
The PC is entirely overkill, it's just for office work. I had the hardware laying around. The CPU shouldn't stressed.
If there's any question, I can just buy another PSU. I just wanted to be safe. It's not worth killing hardware to be on the cheap.
Edit:
I might just buy a Power PC&C 750w off of someone for cheap. That's probably the best option.
post #10 of 17 (permalink) Old 10-23-2011, 11:09 AM
Ken1649's Avatar
Get a proper PSU, a 750w or 850w with at least 2 8-pins PCIe power connector. Corsair or Seasonic Modular of your choice all be fine.
Ken1649 is offline
