[Official] AMD R9 Radeon FURY / NANO / X / Pro DUO FIJI Owners Club - Page 644 - Overclock.net - An Overclocking Community
post #6431 of 11676 (permalink) Old 01-11-2016, 09:50 AM
sugarhell's Avatar
Rep: 564 (Unique: 287)
Originally Posted by The Stilt View Post
If the temperature is below the throttling temperature (75°C) and the power draw stays below the TDP (270W, PowerTune / Power Control @ 0%), it is definitely a driver issue and not directly related to PowerTune or PowerPlay. Disabling PowerPlay is definitely not the correct approach to solve it, since it will mess up the power management completely.
Its a driver issue for years. The past years the method to avoid this problem was:
Disable powerplay
Then you set 2 profiles. A 2d one and a 3d one.
The 2d one is the default clocks of your gpu via the bios.
The 3d one most of the times was the default clocks of your gpu +1 mhz
Manual change from 3d clocks to 2d with AB
A pain in the ...
This was the perfect way for the 7970 to achieve 3d clocks all the time without trottling. But with 290x and fury it seems they changed the powerplay or something.
Originally Posted by BiG StroOnZ
Warning: Spoiler! (Click to show)
No I said if Vega is clocked @ 1600MHz out of the box, I will eat my shoe on Twitch.tv.
Originally Posted by Juicin View Post
Not in games, which is what 99.9999 percent of us care about
And unless you own a business, you get paid for your time. So your compute power just makes more work for you not less
Ryzen is a joke to the vast majority of the market who would consider buying their product.
sugarhell is offline
post #6432 of 11676 (permalink) Old 01-11-2016, 09:55 AM
Rep: 24 (Unique: 11)
Originally Posted by sugarhell View Post
Disable powerplay
The current afterburner version doesn't support that for fury cards yet..Unwinder to the rescue! biggrin.gif
Semel is offline
post #6433 of 11676 (permalink) Old 01-11-2016, 10:22 AM - Thread Starter
Stock
hyp36rmax's Avatar
Rep: 144 (Unique: 122)
Price drop on the Nano to $499! mighty tempting for two
hyp36rmax is offline
post #6434 of 11676 (permalink) Old 01-11-2016, 11:41 AM
98uk's Avatar
Rep: 823 (Unique: 636)
Is anyone here running out of graphics memory. I haven't done yet... but seems to be going very close.
With BF4, playing at 2560x1440, with all ultra 2 x AA, i'm using ~3.6gb GPU memory.
Just take a poo on his lawn, that'll sort it. Then say his slutty daughter did it. - ace8uk (2017)
98uk is offline
post #6435 of 11676 (permalink) Old 01-11-2016, 02:58 PM
Noirgheos's Avatar
Rep: 5 (Unique: 5)
My question is, how did reviewers test Crimson without downclocking?
EDIT: lol vsync was off
Noirgheos is offline
post #6436 of 11676 (permalink) Old 01-11-2016, 02:59 PM
Noirgheos's Avatar
Rep: 5 (Unique: 5)
What kind of FPS do you get with those settings on your Fury?
post #6437 of 11676 (permalink) Old 01-11-2016, 03:01 PM
98uk's Avatar
Between 70-120 depending on the map and what's going on
98uk is offline
post #6438 of 11676 (permalink) Old 01-11-2016, 07:48 PM
The Stilt's Avatar
Rep: 750 (Unique: 286)
Someone try this and see if it makes any difference on the downclocking issue. The bios has only two SCLK states (instead of eight) so in theory it should address it, unless it is a hardware related issue (power or thermal related throttling). It might cause some undefined behavior during UVD or VCE, but that´s what I´m looking you guys to find out. In case there is a issue with the bios (no picture, restart while loading the display driver, etc) you can recover by using the second bios (primary / secondary).
The bios is intended for Fury X MBA (113-C8800100-103) board. AFAIK there is currently only a single version available, so it should be the correct one regardless of the ODM or the age of the card.
FuryXLCB2.zip 102k .zip file
If anyone tries it, please report the changes in behavior, issues, improvements, etc.
The Stilt is offline
post #6439 of 11676 (permalink) Old 01-11-2016, 07:54 PM
Noirgheos's Avatar
Rep: 5 (Unique: 5)
Thats insane! I sometimes drop below 60FPS at 1080p! Only in certain areas though. Like spikes. But damn. What the hell is wrong with my PC? My CPU can't bottleneck it, its a 4790K. Is running 15.11.1 CCC instead of Crimson really limiting me that much?
post #6440 of 11676 (permalink) Old 01-12-2016, 12:41 AM
98uk's Avatar
I'm using Crimson 15.12 with a stock 4770k. You might want to also check your RAM is fast enough, I was using 1600mhz before and that held me back massively.
98uk is offline
