A temporary fix for the excess PCI-E slot power draw for the reference RX 480 cards - Page 12 - Overclock.net - An Overclocking Community
post #111 of 178 (permalink) Old 07-06-2016, 11:30 AM - Thread Starter
The Stilt's Avatar
Rep: 861 (Unique: 329)
Originally Posted by comagnum View Post
I can test this evening after work if you'd like @The Stilt
Gorod is on it already, but thanks.
If the software works as expected, I'll release it immediately.
The Stilt is offline
post #112 of 178 (permalink) Old 07-06-2016, 11:35 AM
... not new ...
Rep: 105 (Unique: 70)
Originally Posted by OneB1t View Post
also what piss me really is that they fixed PCI-E power draw issue in 3 days but fixing 2D power usage with multimonitors or in light load like playing youtube takes them exactly 3 years now...
What's worse is that the fix for that is insanely simple: underclock the RAM. The GPU clocks are already very tame in those scenarios, the high power draw is 100% due to the RAM ramping to full clocks.
If AMD would include a few clock tiers for the RAM, the problem would 100% vanish. With full RAM clocks, a 1080p Youtube video uses 186W on my system. With 625Mhz RAM clocks, it uses just 150W. Further, the RAM is usually stable as low as 500 to 550Mhz.
looncraz is offline
post #113 of 178 (permalink) Old 07-06-2016, 12:18 PM
Rep: 49 (Unique: 30)
thats just simply ******** i know few people who not buying RX 480 because of that multimonitor issue
its not really that much in terms of money but this is about not wasting when there is no need to...
its simply amazing that AMD will fix PCI-E power draw issue in few days which is not really that hot as it looks (if your MB cant handle 110W then you prolly dont want to buy RX 480 anyway as your whole PC is piece of crap) but they overlook their 2D power consumption for few years (also worth to mention that NVIDIA had same issue and they fixed it..)
OneB1t is offline
post #114 of 178 (permalink) Old 07-06-2016, 01:44 PM
Gorod's Avatar
Rep: 1 (Unique: 1)
Card no longer dropping clocks in 3DMark GT1 as it did before the use of The Stilt program , frequencies will remain locked to set values !
The memory over the 2250 limits also working ( wattman now shows extended range for memory clocks) , so far the card was able to pass 3DMark with 2300 . The result is with card on stock cooling and weak old CPU , just to test it quickly , tessellation was disabled in driver (for easy of compare with previous results) and power limit set to +50% in wattman (with 0% it behaves like with +50% before - slight drops in clocks in some tests) , with +50% however stays locked to set values 100% of the time when under load thumb.gif
Gorod is offline
post #115 of 178 (permalink) Old 07-06-2016, 01:51 PM
That's a pretty good score.
Is Polaris memory bandwidth bottlenecked?
TheLAWNOOB is offline
post #116 of 178 (permalink) Old 07-06-2016, 01:56 PM
Meddling user
gupsterg's Avatar
Rep: 786 (Unique: 360)
@gorod
Does RX 480 like 390 series / Fury & X have "Power Efficiency" setting in "Gaming" > "Global Settings" of Crimson driver?
I have noted your past results on RX 480 with i7 6700K in HWBot, my Fury X results:-
My 24/7 OC vs RX 480 1460/2250
My HWBot sub of 1175/545 vs RX 480 1460/2250
Tess.tweak done in my results as well.
Looking at your Fury X 1155/575 sub, mine is a bit off on GS score elements redface.gif (compare).
gupsterg is offline
post #117 of 178 (permalink) Old 07-06-2016, 02:00 PM
NomNomNom's Avatar
Rep: 65 (Unique: 59)
The I2C commands he posted in OP also unlocked the memory clocks for you?
NomNomNom is offline
post #118 of 178 (permalink) Old 07-06-2016, 02:21 PM
Gorod's Avatar
Rep: 1 (Unique: 1)
TheLAWNOOB the card does not seem too bottlenecked by memory but of course scores improving slightly with memory overclock as well smile.gif My card wont go past 2300 with stock cooling , will have to see tomorrow if better cooling helps (maybe memory controller does not like those high temps ??? )
gupsterg yeah RX 480 has "power efficiency" setting in driver , turned it off of course smile.gif Did you up the voltage of your Fury X card ? For some reason they drop efficiency/performance when voltage is increased , but you probably already know that hehe biggrin.gif
In any case now at least the owners of RX 480 will have a peace of mind that card is working full speed all the time no matter what bench or game , and can play with memory overclocks as well even if they might not go much further over 2250 without voltage mods . So big thanks to The Stilt for that ! thumbsupsmiley.pngsmile.gif
Gorod is offline
post #119 of 178 (permalink) Old 07-06-2016, 02:21 PM
paromi's Avatar
Rep: 3 (Unique: 3)
What are you guys doing and what software did you use
i understand that you got rid of the Thermal Throttle and got higher memory Speeds
Thanks in advance
paromi is offline
post #120 of 178 (permalink) Old 07-06-2016, 02:29 PM - Thread Starter
The Stilt's Avatar
Ok, so here is the tool Gorod just tested above.
It is simply called EMBD (Ellesmere's Backdoor) and it increases the power limits from the stock figures. It also raises the maximum allowed MEMCLK limit from 2250MHz to 2500MHz. It re-configures the display driver and makes no changes to the hardware itself. The functionality of the program is purely "fire & forget" and it is executed only once (once to apply and once to remove, if necessary). Once you have deployed the tool you can delete it if you feel the need to do so.
It changes the configuration so that the new -50% PowerTune setting (in WattMan) is the same exact thing, as the stock configuration (at ±0% PowerTune) was.
After this tool has been deployed, the new power limit figures are:
PowerTune -50% = 110W, ±0% = 165W TDP, +50% = 247.5W TDP. The current limitations also reflect the same changes, so it is likely that you'll actually hit the current limitations of the VRM controller itself before you hit the driver limits.
The voltages or the frequencies have not been changed from the default settings.
https://1drv.ms/u/s!Ag6oE4SOsCmDhDIoWNpvaMKq8OtE
NOTE: Both of the changes (Apply & Clear) require a reboot. Also the program does not support multiple adapters, regardless if they are in standalone or in CrossFire mode.
EMBD V1.2 https://1drv.ms/u/s!Ag6oE4SOsCmDhERPkAmTcANOYbnk
