Would appreciate help in finding / editing the voltage offset in the RX480 Bios - Page 22 - Overclock.net - An Overclocking Community
post #211 of 218 (permalink) Old 10-28-2017, 11:10 AM
Overclock Everything
Awesomeguy10578's Avatar
Rep: 10 (Unique: 10)
I've read this thread on how to mod the NCP81022 on my Sapphire RX 580 Nitro and I'm just a bit confused with all the information on different posts and things like that. Can you guys give me some pointers? Also I have 2 cards on CFX so when reading it I wasn't sure what do I have to do differently. Thanks
Originally Posted by wincomo View Post
I have 580 with NCP81022 and successfully added -50mv voltage offset in bios via register E6.
The stock i2c table is this: 01 03 0E 00 10 96 20 00 00 00 00 00 FF 00
first tried this: 01 03 12 00 10 96 20 00 00 00 00 00 E6 00 F8 00 FF 00 and it's not working,
then I tested: 01 03 12 00 10 96 40 00 00 00 00 00 E6 00 F8 00 FF 00 and now it works fine.
Could you help me explain how does it work? I'm kinda confused, I'm trying to add a positive voltage offset which is not what you were doing. I'm kinda new to this I2C control thing. Thanks.
Awesomeguy10578 is offline
post #212 of 218 (permalink) Old 06-12-2018, 12:26 PM
EMYHC's Avatar
Rep: 2 (Unique: 2)
Hi guys,anyone can add offset register to my bios?My card is a sapphire nitro+ rx 580 8 GB,the last mod that i want made is add +25 offset(my card is on liquid,i have no problem with temp),someone can mod the bios for me please?
EMYHC is offline
post #213 of 218 (permalink) Old 06-13-2018, 08:27 AM
EMYHC's Avatar
Rep: 2 (Unique: 2)
I try to follow the guide of Gupsterg for add offset to my nitro 580,everything is well,but when i compare with stock with winmerge my offset are always +4 bytes of stock...what i wrong?When drag and drop file is fixed i post my bios...
EMYHC is offline
post #214 of 218 (permalink) Old 07-05-2018, 01:27 AM
EMYHC's Avatar
Rep: 2 (Unique: 2)
Finally i'm able to set my offset!One question,what is the right values for +12mv offset?my registry is E6 00 F8 00,and i give -50 mv,is possible set -12mv or any values not multiples of 25?
EMYHC is offline
post #215 of 218 (permalink) Old 12-02-2018, 06:24 PM
Hardware Destroyer
Rep: 0
Got XFX RX 480 and stuck with VOI too.
It doesn't work at all.
GPU1-B06-D20: ON NCP81022
Modified VOI Table:
32 00 03 01 01 03 16 00 10 96 40 00 00 00 00 00 D2 00 00 00 E6 00 EC 00 FF 00 01 07 0C 00 0E 00 00 00 00 00 00 00 04 07 0C 00 0E 00 00 00 00 00 00 00
Original VOI Table:
1C 00 03 01 01 07 0C 00 0E 00 00 00 00 00 00 00 04 07 0C 00 0E 00 00 00 00 00 00 00
dsanke is offline
post #216 of 218 (permalink) Old 12-03-2018, 02:21 AM
mynm's Avatar
Rep: 54 (Unique: 20)
Modified VOI Table:
Original VOI Table:
The VOI and the 40 address is ok.
Maybe you will have to add some values to the asic int, and the set voltage table like here: https://www.overclock.net/forum/27735056-post883.html . Did the attached tables worked for your msi bios?
Maybe the attached files in the linked post could work for this xfx bios. But maybe I will have to see your xfx 480 bios first to be sure.
mynm is offline
post #217 of 218 (permalink) Old 12-13-2018, 04:50 AM
trihy's Avatar
Rep: 10 (Unique: 7)
Guys, Im familiar with nvidia bios editing.
But on amd Im terrible.
Could anyone help me to lower the voltage on my card? It gets really hot under load and any mv lower will be great.
It's ok to dump the bios with gpuz?
What does this 950mv means?
According to msi ab my card uses a lot more mv than 950 under load.
BTW, also wattman shows 950mv for the last 4 states.
Edit. Applied -45mv with msi ab and worked fine
How can I apply a -40 or -50mv undervolt in bios?
Atttached stock bios for my card. f anyone could take a look, it will be great.
Thanks.
trihy is offline
post #218 of 218 (permalink) Old 04-27-2019, 12:02 PM
morecs's Avatar
Rep: 0
nvm
morecs is offline
