Would appreciate help in finding / editing the voltage offset in the RX480 Bios - Page 4 - Overclock.net - An Overclocking Community
post #31 of 218 (permalink) Old 04-05-2017, 07:14 AM
gupsterg is offline
post #32 of 218 (permalink) Old 04-05-2017, 07:21 AM
grotoc's Avatar
Rep: 0
Do all your cards have IR3567B?
How can I check that ?
grotoc is offline
post #33 of 218 (permalink) Old 04-05-2017, 02:54 PM
adamvx's Avatar
Rep: 0
gigabyte470samsung.zip 109k .zip file
And how to edit offset in this bios?
should I add something here or I can just replace proper values?
adamvx is offline
post #34 of 218 (permalink) Old 04-07-2017, 09:22 AM
doktor83's Avatar
Rep: 1 (Unique: 1)
I have a sapphire nitro+ 470 card that has a VDDC offset, and by editing it in a hex editor i can change the voltage.
Now if i change the DPM states on this same card (with the VDDC offset set at default, ie 4 x 6.25mv = 25mv),and i try to DOWNVOLT, it never goes under 1000mV, but if i OVERVOLT then the voltage really changes.
Why is this happening?
Is this because the bios has a VDDC offset added ?
doktor83 is offline
post #35 of 218 (permalink) Old 04-07-2017, 09:53 AM
Meddling user
gupsterg's Avatar
Rep: 786 (Unique: 360)
In post 20 is a googledoc link to registers. Two of them can be used to identify IR3567B.
0x0D = IR3567B Identification register, will be 20h for IR3567A , 44h for IR3567B.
0x92 = IR3567B Identification register, must be equal to 43h for IR3567B.
In a i2c dump you should find those at stated offset locations.
gupsterg is offline
post #36 of 218 (permalink) Old 04-07-2017, 11:52 AM
doktor83's Avatar
Rep: 1 (Unique: 1)
Gremlins
doktor83 is offline
post #37 of 218 (permalink) Old 04-07-2017, 12:00 PM
Loladinas's Avatar
Rep: 41 (Unique: 35)
Interesting. At that point I'd probably try removing all of the AIB software (Trixx, Afterburner, etc), removing drivers with DDU and trying fresh.
Loladinas is offline
post #38 of 218 (permalink) Old 04-07-2017, 12:20 PM
doktor83's Avatar
Rep: 1 (Unique: 1)
I did all of that. First removed Trixx, then uninstalled video drivers, then ran DDU to clean up,and installed 16.10 drivers again smile.gif
doktor83 is offline
post #39 of 218 (permalink) Old 04-07-2017, 12:57 PM
adamvx's Avatar
Rep: 0
No,
it's because 1000mV Vddci (mem voltage) minimal limit is hardcoded in Bios and PBE is unable to reduce it...
I would like to find a way to change this, too but till now I didn't succeed
adamvx is offline
post #40 of 218 (permalink) Old 04-07-2017, 01:35 PM
doktor83's Avatar
Rep: 1 (Unique: 1)
Originally Posted by adamvx View Post
No,
But if the vddci is hardcoded in bios, how come i can lower voltage by changing the vddc offset?
Does that mean i have to add vddci register in bios (i think thats the 8E 00 stuff smile.gif) ?
doktor83 is offline
