Would appreciate help in finding / editing the voltage offset in the RX480 Bios - Page 6 - Overclock.net - An Overclocking Community
post #51 of 218 (permalink) Old 04-09-2017, 09:49 PM
doktor83's Avatar
Rep: 1 (Unique: 1)
doktor83 is offline
post #52 of 218 (permalink) Old 04-09-2017, 11:50 PM
chris89's Avatar
Rep: 84 (Unique: 62)
For sure. I'm on a really nice bios now. Averaging 35fps at 5120x2880 Fallout 4 while using way more than my physcial ram, virtual commit over 11GB on 8GB ram. More ram means more fps for this game. It ran good though.
Dell Precision T7500 : Dual Xeon X5675 @ 3.536Ghz X 24 Threads : 48 Gigabytes : Cinebench R15 : 1505 : AMD R9 390X 8GB @ 1173Mhz 1350mv 57599 Power Limit @ 1250Mhz memory error free on tight timings / since 1500mhz+ had errors galore
chris89 is offline
post #53 of 218 (permalink) Old 04-10-2017, 04:21 AM
mynm's Avatar
Rep: 54 (Unique: 20)
Originally Posted by doktor83 View Post
Gremlins
I think that I can explain that.
You can see here: https://www.overclock.net/t/1609782/watttool-a-simple-tool-that-combines-overclocking-with-vrm-monitoring-tweaking-for-rx-400-series that:
Memory clock and voltage: works similar to WattMan. The voltage is not the actual memory voltage (which is fixed to about 1.5 V or needs a hardmod). The voltage controllers second loop is not used, so it is questionable, whether the memory controller has an own dynamic voltage plane. My guess is that the voltage set here simply is a lower limit for the core voltage. If you overclock the memory, always check for memory errors (can be done with HWiNFO)
So WattMan memory voltage is limiting the minimun core voltage when the memory is at the max frequency. And it isn't what you see in the bios editor as memory voltage.
I know how to mod that WattMan memory voltage in my 380 like I say here: https://www.overclock.net/t/1563409/software-for-r9-285-bios-edit/970#post_25725041
But I don't have a 480 or a 470 to test.
I don't see your bios here, but in the grotoc bios those values I guess are: Warning: Spoiler! (Click to show)
Orange highlight value I guess is bios editor memory voltage: 1000mv.
Red highlight value 0B, I guess is a pointer to WattMan memory voltage, is 11 so it's pointing to eleventh voltage in vddc voltage table.
Red highlight value B6 03 is 3B6 that is 950mv and I guess is WattMan memory voltage.
Black highlight value is 1650 mhz for the memory.
So changing the pointed value I guess that you could lower the core voltage to 900mv.
mynm is offline
post #54 of 218 (permalink) Old 04-10-2017, 05:13 AM
ryan5rd's Avatar
Rep: 3 (Unique: 3)
Ok I've been trying to follow this thread but have been failing pretty miserably. I have a 4gb 480 that doesn't seem to have any vdcc control whatsoever built in.
(http://filebin.ca/3IaTpLWMymtC/modded-oc1275-1900.rom)
I've been trying to follow @chris89 's steps to undervolt but I don't 100% understand, especially since my bios seems to be missing the offsets required. I'll keep trying on my own, but if there's anything I can do to help please let me know!
I got it....
Chris Berman dressed as a Night Elf Hunter, smoking a cigarette while making a pipe bomb in a van, right outside of Eaten. As he went to check his email on his workstation, he spilled his green water cooling additive everywhere, and when he went to clean it up, he hit one of his fans that was on, causing a nice cut and making a bloody hand print. He did not want to leave evidence so he drove the van into the hood
ryan5rd is offline
post #55 of 218 (permalink) Old 04-10-2017, 05:20 AM
chris89's Avatar
Between 65282 and 65285 basically use a clock like these to undervolt those power states...
Between 65286 and 65288 you can either run run less clocks or enter manually in 65286, 7, 8 any value at or below 1250mv. Likely 1066-1166mv and call it 65288 max 1306mhz at 1166mv.
chris89 is offline
post #56 of 218 (permalink) Old 04-10-2017, 06:30 AM
doktor83's Avatar
Rep: 1 (Unique: 1)
I don't see your bios here, but I in the grotoc bios those values I guess are: Warning: Spoiler! (Click to show)
Now this is interesting, i might give it a try when i get more free time.
This explains the next thing:
I modified all GPU mhz/ mV parameters in Polaris on a Xfx 470 4gb card.
Memory also (vddci)
But even after this i MUST lower VDDCI with WattTool to 890mV if i want the undervolt to work.
Looks like the card is ignoring the setting for mvdcc that gets directly from the bios.
doktor83 is offline
post #57 of 218 (permalink) Old 04-10-2017, 07:03 AM
mynm's Avatar
Memory also (vddci)
Yes, WattTool and wattman memory voltage are the same, I guess that the bios pointed voltage and that it isn't only changing vddci, I guess it coul be changing the min vddci and vddc for the max memory clock like in my 380. So if it's working with WattTool, changing the pointed voltage at the bios could work.
I don't know what the bios editor memory voltage is or if it's vddci, but they aren't the same thing.
mynm is offline
post #58 of 218 (permalink) Old 04-10-2017, 08:39 AM
chris89's Avatar
@mynm Thanks man yeah I find the vddci to be static on Polaris unlike Tonga. It's 900mv all the time.
Maybe you picked up an RX 480 8GB we could figure out how to increase vddci to 1000mv rather than 900mv? More overclocking I'm sure.
Thanks
chris89 is offline
post #59 of 218 (permalink) Old 04-10-2017, 09:32 AM
Loladinas's Avatar
Rep: 41 (Unique: 35)
Thanks
Yeah, you probably shouldn't overvolt the IMC. According to buildzoid that things is as fragile as a baby panda, and overvolting kills it faster than you can say "Crikey!".
Loladinas is offline
post #60 of 218 (permalink) Old 04-10-2017, 11:30 AM
mynm's Avatar
Thanks
You are welcome thumb.gif . I see that in some 480 with NCP81022 controller https://www.overclock.net/t/1609782/watttool-a-simple-tool-that-combines-overclocking-with-vrm-monitoring-tweaking-for-rx-400-series/240#post_25870177 vddci can be monitored and it's 900mv like you say, so maybe WattTool, wattman memory voltage or the bios pointed voltage isn't changing vddci.
I guess vddci could be the 84 03 value next to the red highlight 0B pointer. This value is named vddic in tonga but itn't working on it, but it could be working on the 480/470/460.
Edited: I'm not going to buy a 480/580 or 470/570.
mynm is offline
