Would appreciate help in finding / editing the voltage offset in the RX480 Bios - Page 7 - Overclock.net - An Overclocking Community
post #61 of 218 (permalink) Old 04-10-2017, 12:40 PM
doktor83's Avatar
Rep: 1 (Unique: 1)
Wow, my Xfx's watttool screen looks the same (NA for the sensors), but changing states in bios , and then in wattool changing P1 for memory makes things work, ie. the card undervolts smile.gif
I downloaded the grotoc bios just to find the data you made the screenshot, so i can figure out offsets in other bioses, especially for my tricky xfx smile.gif
Guessing from the position on your pic that is the beginning of the powerplay table right ? Also structure size is 77 bytes so that should be it smile.gif
doktor83 is offline
post #62 of 218 (permalink) Old 04-10-2017, 01:03 PM
mynm's Avatar
Rep: 54 (Unique: 20)
Yes it's in powerplay, but maybe it could be better to change the pointer 0B, or whatever the value you have, to 01 o 00, so it will use the DPM 0 or DPM 1 voltage. My 380 is using a 01 value so it's using DPM 1 voltage.
mynm is offline
post #63 of 218 (permalink) Old 04-10-2017, 01:38 PM
Meddling user
gupsterg's Avatar
Rep: 786 (Unique: 360)
Just for people to view wink.gif .
Originally Posted by hellm View Post
If u don't change this byte from 0F to 0B, memcontroller voltage will be the same as vcore.
Some customs have this value already set, else i wouldn't know about it.
pptable_v1_0.h
usMvdd is what Polaris owners see as 1000mV in WattMan.
typedef struct _ATOM_Tonga_MCLK_Dependency_Table {
00      UCHAR ucRevId;
02      UCHAR ucNumEntries;        /* Number of entries. */
        ATOM_Tonga_MCLK_Dependency_Record entries[1];                           /* Dynamically allocate entries. */
} ATOM_Tonga_MCLK_Dependency_Table;
typedef struct _ATOM_Tonga_MCLK_Dependency_Record {
00      UCHAR  ucVddcInd;       /* Vddc voltage */
52 03   USHORT usVddci;
00 00   USHORT usVddgfxOffset;  /* Offset relative to Vddc voltage */
E8 03   USHORT usMvdd;
30 75 00 00     ULONG ulMclk;
00 00   USHORT usReserved;
} ATOM_Tonga_MCLK_Dependency_Record;
0F      UCHAR  ucVddcInd;       /* Vddc voltage */
B6 03   USHORT usVddci;
40 0D 03 00     ULONG ulMclk;
gupsterg is offline
post #64 of 218 (permalink) Old 04-10-2017, 01:41 PM
chris89's Avatar
Rep: 84 (Unique: 62)
Any word on Atom Polaris Bios reader? Would be real interesting to get into hex modding the usVddcOffset... On Tonga, altering usMvdd didn't do much. Though down-volting the Hawaii/ Grenada does wonders... Actually more performance at less clock on less voltage and a cooler card...
BTW I can barely see what I'm typing at 5120x2880 desktop res on RX 480 haha thumb.gif
Dell Precision T7500 : Dual Xeon X5675 @ 3.536Ghz X 24 Threads : 48 Gigabytes : Cinebench R15 : 1505 : AMD R9 390X 8GB @ 1173Mhz 1350mv 57599 Power Limit @ 1250Mhz memory error free on tight timings / since 1500mhz+ had errors galore
chris89 is offline
post #65 of 218 (permalink) Old 04-10-2017, 01:57 PM
Meddling user
gupsterg's Avatar
Latest AIDA64 when doing Video Debug > ATI GPU Registers :-
------[ PowerPlay7 BIOS Info ]------
Max GPU Clock      = 2000 MHz
Max Memory Clock   = 500 MHz
PowerControl Limit = 50%
SCLK DPM0 =  300 MHz
SCLK DPM1 =  512 MHz
SCLK DPM2 =  724 MHz
SCLK DPM3 =  892 MHz
SCLK DPM4 =  944 MHz
SCLK DPM5 =  984 MHz
SCLK DPM6 = 1018 MHz
SCLK DPM7 = 1050 MHz
MCLK DPM0 =  500 MHz  (VDDCI: 1.00000 V)
gupsterg is offline
post #66 of 218 (permalink) Old 04-10-2017, 04:07 PM
mynm's Avatar
pptable_v1_0.h
00      UCHAR ucRevId;
SCLK DPM0 =  300 MHz
SCLK DPM1 =  512 MHz
SCLK DPM2 =  724 MHz
SCLK DPM3 =  892 MHz
SCLK DPM4 =  944 MHz
SCLK DPM5 =  984 MHz
Yes thanks, that's it, 0F is UCHAR ucVddcInd, is vddc indicator and is 15. So in that case I guess is Red highlight value 7e 04, with 0B, 11, it will be green highlight value b6 03:
Warning: Spoiler! (Click to show)
I don't know if usMvdd is what Polaris owners see as 1000mV in WattMan, but I have tested it and it isn't in Tonga, and I can chage it in the bios like I said. And in AIDA I don't see the same values for the vddci than those I see in HWinfo.
But at least WattTool and bios editor memory voltage aren't the same.
mynm is offline
post #67 of 218 (permalink) Old 04-12-2017, 06:12 PM
adamvx's Avatar
Rep: 0
I would like to ask you for help me with adding offset to this bios:
saphire480_4g_elpida_bios_no_offset.zip 109k .zip file
I will be so much gratefull for any hints (I am newbie in hex-editing so I would like to get step-by-step info how to add offset for this case, especially how to add tables, how to calculate it etc )
PS:
I set -100mv offset in hex and 890mv static in pbe (it shouldn't even start with this setting but.. as v-core is limited by v-ram... that must be higher voltages in real )
what is strange I have another card.. she has 100mv offset too
but..
she hangs on powerstage 4 (which I set at 980mv in PBE) but works at 990mV
so what's real values?
how to calculate it?
File Type: zip saphire480_4g_elpida_bios_no_offset.zip (109.4 KB, 9 views)
adamvx is offline
post #68 of 218 (permalink) Old 04-13-2017, 05:27 AM
doktor83's Avatar
Rep: 1 (Unique: 1)
Adam, did you try it this way ?
https://www.youtube.com/watch?v=sc5qFEIMYTs&feature=youtu.be
It should work on Polaris too, as Gupsterg said.
doktor83 is offline
post #69 of 218 (permalink) Old 04-13-2017, 06:04 AM
adamvx's Avatar
Rep: 0
I know this manua but I am afraid I break something..
adamvx is offline
post #70 of 218 (permalink) Old 04-13-2017, 06:06 AM
doktor83's Avatar
Rep: 1 (Unique: 1)
doktor83 is offline
