[WIP]RX460 to RX560 conversion pack (Asus, Gigabyte, MSI, Powercolor, Sapphire and XFX) - Page 3 - Overclock.net - An Overclocking Community
post #21 of 260 (permalink) Old 07-06-2017, 02:08 PM
aGeoM Level 1
For the RX580 it is not needed, as for RX560 I really don'd know, I haven't mod my RX560 BIOS for better memory timings yet. Anyway I already modded the MSI BIOS if you wanna try.
MSI_RadeonRX560_AERO_ITX_4GOC11961750_MICRON.zip 108k .zip file
File Type: zip MSI_RadeonRX560_AERO_ITX_4GOC11961750_MICRON.zip (107.7 KB, 252 views)
skull.gif [Official]AMD RX 480/ 470/ 460 Owners Club skull.gif
aGeoM is offline
post #22 of 260 (permalink) Old 07-06-2017, 03:22 PM
yahtsman Level 1
yahtsman's Avatar
Sapphire Nitro RX 460 4G flashed normal ... But ... artifacts ... under load on GPU clock more than 1250 MHz. (sorry for my english)
yahtsman is offline
post #23 of 260 (permalink) Old 07-07-2017, 05:12 AM
delaveganz Level 1
delaveganz's Avatar
Have tried your mod, and it didn't work - secondary display did not work, GPU-Z did not report Pixel FillRateand sensor readouts were all wrong.
Flashed back to original RX460 BIOS. :-(
delaveganz is offline
post #24 of 260 (permalink) Old 07-07-2017, 06:05 AM
aGeoM Level 1
The only change was the memory module, nothing else, or you have driver problems ( did you uninstalled drives with DDU before flash? ) or the BIOS on TPU does not fit your card.
aGeoM is offline
post #25 of 260 (permalink) Old 07-07-2017, 12:55 PM
Tecno Games Level 1
Tecno Games's Avatar
I modified the bios of my powercolor 2gb Hynix, but the only thing that changed was the clock
Tecno Games is offline
post #26 of 260 (permalink) Old 07-07-2017, 01:29 PM
sifupepe Level 1
sifupepe's Avatar
the bios in folder XFX work in single fan xfx rx 460? because i have only single fan rx 460 not double fan, i need a lot modify my card to rx 560
sifupepe is offline
post #27 of 260 (permalink) Old 07-07-2017, 02:21 PM
cyraxus Level 1
cyraxus's Avatar
i have asus 2gb rx 460 dual card. i succesfuly flash Sapphire RX 560 2048 MB BIOS hynix bios to my card..But 1300 mhz not stable. i underclock to 1250 mhz gpu speed and overclock to memory speed 2000. it is stable for daily use. Also fan speed is very low beside orginal bios.My card doesnt have any power plug but sapphire has.No problem so far. Maybe 1300 mhz unstability depends on power i dont know.
cyraxus is offline
post #28 of 260 (permalink) Old 07-07-2017, 02:52 PM
cyraxus Level 1
cyraxus's Avatar
Your card shaders can be hardware locked..
cyraxus is offline
post #29 of 260 (permalink) Old 07-07-2017, 04:39 PM
delaveganz Level 1
delaveganz's Avatar
So I tried out other RX560 4GB card BIOSes with Micron from TechPowerUp site
Sapphire PULSE RX 560 OC 4 GB - works but saw GPU throttling when running Heaven benchmarks (68deg) rolleyes.gif
XFX,4GB DF Radeon RX 560 4GB - works but temp runs a bit high when running Heaven benchmarks (76deg) - not sure what the DF designation means ?
XFX,4GB SF Radeon RX 560 4GB - seems to work with better temp when running Heaven benchmarks (75deg) thumb.gif
Happy with my MSI RX460 OC 4GB (SF) running on the XFX,4GB SF Radeon RX 560 4GB BIOS smile.gif
post #30 of 260 (permalink) Old 07-07-2017, 04:53 PM
aGeoM Level 1
And shaders unlocked too?
EDIT
Can you upload XFX SFan BIOS, maybe @sifupepe can try on his card, he is desperate drool.gif for one. smile.gif
aGeoM is offline
