RX 480 voltage spikes under light load - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 02-23-2019, 01:53 AM - Thread Starter
Ryzen Overclocker
Ph42oN's Avatar
Rep: 5 (Unique: 4)
I have my Asus Dual RX 480 overclocked to 1440mhz, cooled by cpu waterblock. Its at about 1.21v on load, but in light load where clockspeed is jumping around i see some voltage spikes in hwinfo, it says maximum voltage was about 1.42v. In gpu-z max voltage shows about 1.3v. I also did some testing with about 1.3v on load, hwinfo said max voltage was 1.5v.
Should i be worried about these spikes, and would it be safe to run higher than 1.21v?
RyzenAsus
(14 items)
Ryzen 5 1600X
Asus Prime X370-Pro
Asus RX 480 Dual 4GB
G.Skill Flare X 3200 CL14
WD10EZEX
ST3000DM008
XFX 550w
chinese water pump
Heatkiller IV
Barrow Dabel-60a 360
Cooler Master n300
Keyboard
Logitech G810
Mouse
CM Storm Xornet II
Mousepad
Blackstorm Iced
Ph42oN is offline
post #2 of 4 (permalink) Old 02-23-2019, 03:19 PM
@integralfx
BLUuuE's Avatar
Rep: 8 (Unique: 7)
If your 480 uses the IR3567B voltage controller, you can set the Vmax register, so you won't have those voltage spikes.
BLUuuE is offline
post #3 of 4 (permalink) Old 03-05-2019, 03:14 PM - Thread Starter
Ryzen Overclocker
Ph42oN's Avatar
Rep: 5 (Unique: 4)
I found about WattTool, and it seems that when using it to overclock, i get less aggressive LLC than Asus GPU Tweak i was previously using. With it, voltage spikes are gone in GPU-Z, but still appear in hwinfo.
I don't know what voltage controller there is, but at least its not what WattTool can control. Not going to take apart card soon, and didnt find anything when trying to look online.
RyzenAsus
(14 items)
Ryzen 5 1600X
Asus Prime X370-Pro
WD10EZEX
ST3000DM008
XFX 550w
chinese water pump
Heatkiller IV
Cooler Master n300
Keyboard
Logitech G810
Mouse
CM Storm Xornet II
Mousepad
Blackstorm Iced
Ph42oN is offline
post #4 of 4 (permalink) Old 03-05-2019, 04:08 PM
AMD OC'ing Enthusiast
mattliston's Avatar
Rep: 108 (Unique: 86)
Look at your temperatures with hwinfo. do the gpu temps also spike with the voltage?
If not, likely the spikes are merely software being buggy and nothing to worry about
mattliston is offline
