Need Help Overclocking my Vega 56! - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 04-09-2019, 10:39 AM - Thread Starter
m70b1jr's Avatar
Rep: 13 (Unique: 12)
Hello guys! So, I just got done building my first custom water loop (with hardline tubing)! (Well, I build a mineral oil PC with an external passive radiator, but I dont count it) and of course, I got a alphacool waterblock for my Vega 56 card (Gigabyte gaming OC Vega 56) It's an AIB Card, So if I try flashing any other type of BIOS On there, I get a black screen. The card has Hynix HBM, so It doesn't overclock well.
ANYWAYS, I've tried messing with the powerplay table mod, but it doesn't seem to help performance, With 150% power limit offset, I still cant get the GPU to get to 1700mhz speeds, I have it set to 1770 in afterburner, but it only actually goes to 1600mhz... What am I missing? Should I still "Undervolt?" Max out the voltage slider? keep it at 0? Can i get some help here?.
EDIT: Found my issue. The card will throttle clock speeds as soon as it his 50c. Anyway to get around this?
Official Ryzen 7 3700x Owner!
Holder of Fastest Vega 56 on 3DMark
Main Rig
(8 items)
Ryzen 7 3700x
Asrock X370 Pro4
Aorus 1080Ti
Gigabyte Vega 56
Vengence PRO RGB
EVGA 750 G2 SuperNova
Custom Waterloop
NZXT H500i
m70b1jr is offline
post #2 of 8 (permalink) Old 04-10-2019, 06:00 AM
No.2 in Gaming
MrPerforations's Avatar
Rep: 79 (Unique: 58)
Hello,
the MSI™ Radeon™ RX Vega 56 Air Boost oc might have a compatible bios as it uses Hynix™ HBM and Samsung™ HBM. it is a 1620mhz max clock bios and might help. I have managed to get a clock of 1680mhz from my MSI™ Radeon™ RX Vega 56 cards which also use the Hynix™ HBM.
https://www.techpowerup.com/vgabios/...emSize=&since=
AMD Ryzen™ 1700 3.75ghz
MSI™ X370 Gaming Pro Carbon™
MSI™ Radeon™ Vega 56 Air Boost OC
Avexir™ Blitz™ 3200 CL16 @ 3200
Seagate™ 2TB Barracuda™
Optical Drive
ASUS™ DRW-24D5MT
EVGA™ Supernova™ 1000 G2
XSPC™ Raystorm™ 750 2x EX360 Radiators
Coolermaster™ Cosmos Pure Black
Operating System
Windows™ 10 x64
Electriq™ VM280UHD 4k
Keyboard
RII™ K66 Red Switch mechanical keyboard
Mouse
EasySMX™ Red Gaming mouse
Audio
Creative labs™ sb x-fi titanium
Audio
Logitech™ 540x 5.1
MrPerforations is offline
post #3 of 8 (permalink) Old 04-10-2019, 12:20 PM - Thread Starter
m70b1jr's Avatar
Quote: Originally Posted by MrPerforations View Post
Hello,
Fixed my issue, I forgot a thermal pad on the back of the car (some of the VRM is actually on the backside of this AIB card), and I hit 1760mhz currently. Now trying to push my HBM
Main Rig
(8 items)
Ryzen 7 3700x
Asrock X370 Pro4
Aorus 1080Ti
Gigabyte Vega 56
Vengence PRO RGB
Custom Waterloop
NZXT H500i
m70b1jr is offline
post #4 of 8 (permalink) Old 04-10-2019, 06:29 PM
No.2 in Gaming
that's a dam nice clock, I hope to get some Bykski™ water blocks next week. hope to get some good clocks as that is way above mine using air. keep us informed, wishing you the best.
Optical Drive
ASUS™ DRW-24D5MT
Operating System
Windows™ 10 x64
Keyboard
Mouse
Audio
Audio
Logitech™ 540x 5.1
post #5 of 8 (permalink) Old 04-10-2019, 06:37 PM - Thread Starter
m70b1jr's Avatar
I'm currently #7 in the world for Time Spy on a R5 2600 and Vega 56, I would easily be #1 if my Hynix memory wasn't trash. I'm only hitting 860 on HBM
Main Rig
(8 items)
Ryzen 7 3700x
Asrock X370 Pro4
Aorus 1080Ti
Gigabyte Vega 56
Vengence PRO RGB
Custom Waterloop
NZXT H500i
m70b1jr is offline
post #6 of 8 (permalink) Old 04-11-2019, 07:05 AM
No.2 in Gaming
well done on that score, im 2nd on the AMD™ Ryzen R7 1700 with AMD™ Radeon™ RX Vega 56 crossfire™ list. I got my Hynix™ high bandwidth memory to 900mhz without changing anything, it cant do 950mmhz.
I found that on my base clock of 1620mhz I found that at 4.5% it scores high and then drops off at 5%.
cant wait to water cool them.
Optical Drive
ASUS™ DRW-24D5MT
Operating System
Windows™ 10 x64
Keyboard
Mouse
Audio
Audio
Logitech™ 540x 5.1
post #7 of 8 (permalink) Old 12-11-2019, 01:02 AM
Rep: 0
How to get above the 1600mhz
@m70b1jr
I'm recently trying to push my vega56 a little. I have no intention to switch to watercooling so far, so still on air.
Do you mind sharing what voltage settings you are using. At stage 7 i have currently 1090mV which works reliably.
But I have a steady 1600mhz while gaming. Memory at 900mhz. Core temp is about 70Celsius.
Where could i find more room to increase the clockspeed.
ptje.nl is offline
post #8 of 8 (permalink) Old 12-11-2019, 04:28 AM - Thread Starter
m70b1jr's Avatar
Quote: Originally Posted by ptje.nl View Post
@m70b1jr
I recently upgraded to a 1080ti (got it + a waterblock for $425 total black friday) so I cant look at exactly what my settings were.
If i remember correctly i was using +150% power using a registry hack, and the highest allowed voltage for my BIOS, allowing me to get clock speeds of about 1725mhz.
Main Rig
(8 items)
Ryzen 7 3700x
Asrock X370 Pro4
Aorus 1080Ti
Gigabyte Vega 56
Vengence PRO RGB
Custom Waterloop
NZXT H500i
m70b1jr is offline
