RX 5700 Won't Post on x570 Aorus Pro wifi? - Overclock.net - An Overclocking Community
post #1 of 5 (permalink) Old 07-10-2019, 02:23 PM - Thread Starter
timmyjoe's Avatar
Rep: 2 (Unique: 2)
I've been playing with the Gigabyte Aorus X570 Pro Wifi today got my test bench all Booted up and most things are great for the most part but I can't get the Radeon RX 5700 to post on the board. I did once or twice, windows blue screens at launch and said "Video Scheduler Internal Error"
Now a few things,my 5700 has a modded cooler on it. I might think I did something to the card but I've tested it after having the issues on the Aorus Pro Wifi in 3 systems. A EVGA X299 7820x system, a TR 2950x Asus Zenith Extreme System and on the Asrock Taichi x470 system using the 3700x and they all work and run firestrike without issue.
I can also confirm that the Radeon Vii, an RX 580 and a GTX 980ti all work on the x570 board with out issues.
Wondering if this is some sort of PCIE Gen 4 thing? I thought I heard of some issue with video card support and PCIE Gen 4 on Ryzen but I can't track down where I heard that.
I also updated the bios to the F4D and that didn't do anything.
Anyone else having problems getting the new AMD cards working on the new AMD boards? It's driving me crazy!!
timmyjoe is offline
post #2 of 5 (permalink) Old 07-10-2019, 05:44 PM
⤷ αC
AlphaC's Avatar
Rep: 870 (Unique: 574)
Hi Timmy Joe!
I don't know if you are using a riser cable but if you are , try not doing that. PCIE 4.0 needs redrivers to maintain signal integrity.
Also in BIOs see if you can set it manually to PCIE 3.0 as a workaround before swapping it in.
Under Settings Menu tab:
Name:	BIOS option.png
PCIe Slot Configuration Allows you to set the operation mode of the PCI Express slots to Gen 1, Gen 2, Gen 3, or Gen 4. Actual operation mode is subject to the hardware specification of each slot. Auto lets the BIOS automatically configure this setting. (Default: Auto)
http://download.gigabyte.us/FileList/Manual/mb_manual_x570-aorus-pro-wifi_v1_e.pdf
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #3 of 5 (permalink) Old 07-11-2019, 05:11 AM - Thread Starter
timmyjoe's Avatar
Rep: 2 (Unique: 2)
I can confirm the Alpha's solution works. Not that I was using a riser cable. I actually thought of it last night. I had tried forcing PCI-E Gen 4 and still had the issue but later it occurred to me this might be the video card's problem and not the motherboard's so I set PCI-E Gen 3 in the bios and low and behold it booted. I have contacted AMD regarding this issue. I might update this thread once I get my hands on another x570 motherboard, see if this is exclusive to the Aorus or any board.
Thanks for the help!
timmyjoe is offline
post #4 of 5 (permalink) Old 07-11-2019, 05:22 AM
Top kek
Rep: 110 (Unique: 65)
You need to probably contact the motherboard manufacturer about it, and expect BIOS update.
Previous Hardware:
Spoiler!
Desktop PC
(19 items)
AMD FX-8320
ASRock Fatal1ty 990FX Killer
Sapphire Nitro+ RX480
XFX RX470 Singlefan
MSI RX580 GamingX 4GB
Mushkin Redline 996996 2x4GB 2133Mhz
Western Digital 160GB 7200RPM 8MB
Maxtor 250GB 7200RPM 8MB
Corsair Force LS
WesternDigital Blue 500GB 7200RPM 16MB
Corsair TX850M
ThermalTake Frio Silent 14
ThermalTake View 27
Operating System
Windows 10 Enterprise 1607
Operating System
Linux Mint 17.3 Rosa
AOC i2267FWH
Keyboard
Logitech K120
Mouse
Bloody V5
Audio
Corsair HS30 Raptor
ku4eto is offline
post #5 of 5 (permalink) Old 07-17-2019, 01:12 PM
Rep: 0
Just weighing in that I have tried two different 5700's on my Aorus Pro X750 and have had the same issue with both of them. Will try forcing PCI 3.0 this evening to see if that helps.
desm is offline
