Radeon 5700 Reference 50 Gallon Open Water Loop and Blower Non XT Break Down Disassembly - Overclock.net - An Overclocking Community
post #1 of 6 (permalink) Old 08-29-2019, 08:59 PM - Thread Starter
treetops422's Avatar
Rep: 24 (Unique: 18)
BREAKDOWN Gamer Nexus and Igor show us the XT, here are some non XT pics. And the small differences I noticed along the way.
1. On opening the Non XT, there are also 6 screws on sides.
2. (4th pick down tiny circles atm) It looks like they included some thermal pads that do not seemingly match\touch any components. At least one extra pad exists in a spot where the XT has a extra memory chip? Not 100% on the terminology. I circled in green the extra memory chip thermal pad in green. The red circle is just kind of a random tiny thermal pad, idk why it's there or if it makes contact.
So next we have the removal of the Vapor Chamber\Heatsink. Just like GamerNexus, I used a screw driver. I found a convenient spot on the back with a gap in it. However it did result in a slightly bent chamber. Note that the heat sink fins can be easily bent if you squeeze them or knick em with your screw driver.
50 GALLON TOTE CPU WATER BLOCK ON GPU (Yes I know tap water is bad, my water block is only 20$ and can be cleaned will monitor, this is for fun)
So far I zipped up my CPU water block, quite literally and put some old CPU fans on the rest of the card. I still have some thermal pads to take off. The holes on the video card are to small for the bolts that came with the water block and of course they don't exactly line up. My mounting pressure might be a bit uneven, but it works for now. Regardless this is my rough draft. Will update with way more info later. But I can safely say after 8 hours of benchmarking\browsing\tinkering the water has not changed temp. I'll likely incorporate the video card plate and maybe the vapor chamber at some point. It's only about 40 gal atm. Pumps maybe .5 gpm, that will improve. No that's not a quarter it's a cd at the bottom of that tote . Day 1 bench,
TimeSpy
Graphical Score 8 959 core 2030 965 max pw 60% Peaks gpu 69c tj 87 mem 84 vrm 77 mem vrm 68 mem vrm 53 gpu-z peak 1988 clock max 242 watts 8 443 total score
Sapphire Radeon RX 5700 Non XT Boost Core 2035 Gaming Ram 950 with a 20$ Chinese waterblock on the, Ryzen 3700x 4.25 ghz, 15$ Chinese waterblock, 3200 ddr3 cl16 Team T-FORCE VULCAN TUF B450m Asrock Pro 4 Mobo, 700 Watt OCZ PSU. 6 gallon res + back of a toilet tank with 240 mm radiator.
treetops422 is offline
post #2 of 6 (permalink) Old 08-30-2019, 10:40 AM
Rep: 14 (Unique: 11)
yikes
THUMPer1 is offline
post #3 of 6 (permalink) Old 08-30-2019, 10:44 AM
Vandelay Industries
maltamonk's Avatar
Rep: 81 (Unique: 61)
Are you pulling from the bottom of the tote and returning to the top?
maltamonk is offline
post #4 of 6 (permalink) Old 08-30-2019, 10:48 AM
Chimera1970's Avatar
Rep: 8 (Unique: 7)
You can always pop a couple of ice cubes in there to see what happens lol.
Chimera1970 is offline
post #5 of 6 (permalink) Old 08-30-2019, 11:02 AM
criminal's Avatar
Rep: 698 (Unique: 426)
Quote: Originally Posted by THUMPer1 View Post
yikes
Yikes is right... lol
I have a big bang house. I had all the materials for my new house brought in and dumped on a vacant lot. I took a stick of dynamite, lit the fuse on fire and tossed it into the pile of materials. BOOM went the explosion and when the dust settled I had a new house! Amazing isn't it?
Super P's Rig
(21 items)
Frac
(9 items)
Ryzen 7 3700X
MSI MPG X570 GAMING PRO CARBON
Gigabyte RTX 2070S
XPG Spectrix D41 3600MHz
Samsung 850 EVO
MyDigitalSSD SBX
WD Black 500GB NVMe
EVGA SuperNOVA 850G2
Bykski CPU-XPR-AM
Phobya Balancer 150 Reservoir
XSPC EX280 Radiator
TC-A - CPU Liquid Cooling Pump
XSPC EX360 Radiator
Phanteks Pro M TG
Operating System
Windows 10
MSI Optix AG32CQ
Keyboard
G710+
Mouse
G305
Mousepad
Vipamz Extended XXXL
Audio
Sennheiser HD 439
Audio
Asus U7
5960X
Asus X99
AsRock RX570
Corsair Vengeance 3000MHz
Kingston SSDNOW V300
EVGA 500 W1
CoolerMaster 120MM AIO
Fractal Design Define S
Operating System
Windows 10 Pro
criminal is offline
post #6 of 6 (permalink) Old 08-30-2019, 07:44 PM - Thread Starter
It's on the side atm, I need to lower my case even with the tote, the gpu is about 2 feet higher. Plus the 20 feet of tubing is a bit much for my 15$ pump. However the water feels nice and cold coming from the waterblock.
I remounted my GPU with some wingnuts and tie downs, actively watching my tj max evening out the load, it's a work in progress. The GPU temp never goes above 60c, rarely above 55c,normally below 50c. Ambient 28-30c. I managed 9004 on a TimeSpy graphical score.
My memory\vram\pcb are still hot as hell, I'm working on it. My waterblock is just a little to big to mount with the stock gpu plate\blower as a hybrid air\water cooler. I need bend or cut the stock plate. But it's pretty thick and I want the thermal pads to line up. I did a little bit of gaming 2025 core 965 ram 60 max power without any problems.
Maybe it just needs a rubber ducky
lol 40 gallons vs a bag of ice ^^, eventually eeeeventually. Maybe I'll buy one of those bricks. (yes I know condensation etc)
mm looks like I have some filing to do!
https://imgur.com/a/F2bBr
49 fps in shadow of the tomb on 4k not to shabby, upscaled with DSR, still on a 1080p monitor, 45-54 fps, average probably 47 fps so far, My GPU won't go above 56c despite my mouse vigorous mouse wiggling.
Here is 1080p vs 4k, AMD drivers can be wacky at limiting FPS in some games, without wattman no crashes though. RIS is likely not on. mm FPS isn't showing in screens, least of my worries atm. I'm scared to load wattman it might start coming back on with windows.
Edit well it crashed after about 30 min, probably the mem
