5700 xt Red Devil Problem/s - Overclock.net - An Overclocking Community
post #1 of 12 (permalink) Old 10-17-2019, 11:55 PM - Thread Starter
ernorator's Avatar
Rep: 0
Just got my 5700 xt Red Devil yesterday. Installed it in my PC with fresh win 10 amd newest drivers. Immediately after that i notest 2 things.
1. When i move mouse cursor or scroll up and down in chrome i can hear quiet buzzing sound coming from gpu, bit like coil whine but not so high pitched. No sound in windows safe mode or without amd drivers.
2. Red Devil soposed to be quiet but mine is not. Normaly under windows gpu is on fan stop 45-55 celcius but any game I try to play, bfv, league of legend, world of tanks gets gpu fans to speed up to 2800 rpm.
Checked it in 3dmark
Fire Strike https://www.3dmark.com/fs/20715993
Time Spy https://www.3dmark.com/spy/8926019 - seems a bit low, was anticipating 9300-9500 gpu score.
And temps are high i think. Would be ok if fans spin at ~1500RPM but for 2800 RPM 72 celsius on gpu, 105 hotspot. vrm's, ddr6 temps are more than ok.
Is there any way to fix this or I just send this back to shop (have 14 days for that).
ernorator is offline
post #2 of 12 (permalink) Old 10-18-2019, 01:13 AM
rdr09's Avatar
Rep: 867 (Unique: 634)
I have a reference XT and never seen Hotspot that high at stock. Undervolted at stock Hotspot does not even go over 90c. Either return that card and get a diff brand or you can undervolt and see if it temp go lower. But with the whine, i'd rma it.
[email protected] 6 http://valid.canardpc.com/show_oc.php?id=2211392 4.6 @ 4 http://valid.canardpc.com/show_oc.php?id=2216580
5.0 @ 8 http://valid.canardpc.com/show_oc.php?id=2511322
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
post #3 of 12 (permalink) Old 10-18-2019, 01:19 AM
The last VRM burner
Rep: 29 (Unique: 16)
Such high hotspot comes most likely from broken TIM application.
PC for all
(21 items)
i7 5775c @4.2GHz/3.8GHz
Gigabyte Z97X Gaming 5
Soon to be 2070 Super FE
KHX24C11T3K2/16X 11-12-12-32-1T-250
Corsair MP510
Samsung Evo 860
SeaSonic Focus Plus 750W
Raijintek Tisis lapped+ Thermal Grizzly Kryonaut
Arctic P12 PWM x2
Arctic P14 x4
LianLi 330X
Operating System
Windows 10 64-bit Pro
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red Silent
Mouse
SteelSeries Rival 600
Mousepad
Artisan FX Raiden
Audio
Audio in Motion SC808 + MUSES8820 + 2x 2xLME49990
Audio
AKG M220
Other
NZXT Hue+
Other
Mayflash F300 Arcade Stick
BroadPwns is offline
post #4 of 12 (permalink) Old 10-18-2019, 03:47 PM - Thread Starter
ernorator's Avatar
Rep: 0
1. quiet buzzing sound
Did new windows instalation and switched off cursor tracing in windows. No buzzing now.
2. New problem was with my 144hz display flickering every 4s. Switching refresh rate to 60/75/120 helped but i digged deeper. MSI afterburner was the problem i think. After uninstalling it, problem was gone.
3. Yup quality control at powercolor sucks big. Thermal compound was bit dry and was like 4 times more than needed. Mounting presure was week. Opened the card (without voiding warranty) and put some kryonaut, tightend the screaws a bit more. There are springloadet screws and I did not use any washers so it can still be better.
Well, it did work 24 celsius ambient
Before
After
Ryzen 5 3600 | Aorus x570 Pro | G.Skill B-die DDR4 [email protected] | rx 5700 XT blower and Red Devil fail Gtx 1070 G1 | SS Focus Gold+ 750W | SilverStone Raven2
post #5 of 12 (permalink) Old 10-18-2019, 05:44 PM
The last VRM burner
Buzzing sound will happen any time you exceed some FPS threshold in any application, be aware of that. Afterburner tends to get bugged, try reinstalling it again and check if problem persists.
PC for all
(21 items)
Corsair MP510
Samsung Evo 860
Arctic P12 PWM x2
Arctic P14 x4
LianLi 330X
Operating System
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Mouse
Mousepad
Artisan FX Raiden
Audio
Audio
AKG M220
Other
NZXT Hue+
Other
post #6 of 12 (permalink) Old 10-25-2019, 01:34 PM
Rep: 1 (Unique: 1)
Have you found a solution yet? I have had a similar issue with the temperature/hotspots. I am left to believe these are motherboard issues rather than a GPU issue. Have a 5700xt red devil my hotspots are just as warm going up to 108c on non intensive gaming. Put this same card in my Intel build and temps are normal. Keep in mind I have the card set to 100% fan speed and it gets this hot. Got another card because I thought it was a GPU issue and the same things happening. Either a sensor error or faulty motherboard. Will be RMAing the board sadly I'll let you know if it helps.
RedBlueHue4 is offline
post #7 of 12 (permalink) Old 10-26-2019, 02:55 PM - Thread Starter
ernorator's Avatar
Rep: 0
Nope, got back to 110 hotspot after 12h. Was fighting with it for the next few days. Puted raijintek morpheus on it but still hotspot was 100-110. After close inspection i think that my gpu die was a bit warped. Maby that was the problem. Don't have intel system so I did not try it in oter pc but i changed pcie from 4 to 3, no impact. Sended it back to shop.
post #8 of 12 (permalink) Old 10-28-2019, 03:46 PM
Rep: 1 (Unique: 1)
Would you update me when you get the next GPU to see if you have the same issue? I'm thinking it's a motherboard problem so far in my situation I've swapped literally every component. If it is a false sensor reading it is hard to trust playing on it with temps that get this hot. Yours is happening after several hours? Mine will get nice and toasty immediately.
post #9 of 12 (permalink) Old 10-29-2019, 07:53 AM - Thread Starter
ernorator's Avatar
Rep: 0
Hot spot 110 was instant. I will not get another card, they are giving me my money back. I'll get 2070 super or just sit it out on 1070 till next year and cyberpunk 2077.
post #10 of 12 (permalink) Old 10-31-2019, 03:57 PM
skupples's Avatar
Rep: 558 (Unique: 317)
i'll let y'all know. I just got a red devil in.
that temp is the tjmax, no? 110? Anyone hit it with an IR therm to confirm the sensor reading isn't borked.
skupples is online now
