HELP! My friend just put together a 3950x rig and it doesn't work - Overclock.net - An Overclocking Community
post #1 of 6 (permalink) Old 01-07-2020, 12:46 PM - Thread Starter
Turtle Rig's Avatar
Rep: 6 (Unique: 6)
As I said a friend of mine not close friend but he got in touch with me that he built a X470 and 3950x CPU which I think he got from newegg, but I don't know if it is in stock now I doubt it is,,, he sorta got lucky. He installed everything and we went with skype to talk about this and fix it. The mobo is Gigabyte x470. He used Kryonaut like I told him to use and he got a DRP4 which is the size of a mini basketball lol.. No really no joke hehe. Anyhow he turns on his system and the fans start spinning and video card fans are spinning the system is quiet since the fans are not ramped up and what not. Then it shows Gigabyte Logo and it just shuts down. We are able to get a post to BIOS if were lucky. Everything is on default and what not. How should we begin the troubleshooting ? RAM sticks is the first action for situations like this ? Anyhow well do the RAM one stick at a time and see what happens. sighs
INTEL 10980XE @ NO STOCK
GIGABYTE X299X AORUS MASTER
GIGABYTE WF RTX 2080
CORSAIR DOMINATOR PLATINUM RGB @ 64GB 3200 CL16 QUAD CHANNEL B-DIE
CORSAIR MP510 960GB M.2 GEN 3 SAMSUNG 950 PRO M.2 500GB 850 PRO 500GB CRUCIAL M4 500GB LaCie EXTERNAL 2TB PORSCHE DESIGN & 500GB eSATA
CORSAIR AX1600i TITANIUM @ CORSAIR 330r BLACKOUT EDITION CASE
CORSAIR H115i PRO RGB @ NOCTUA NF-14's INTAKE NF-14 EXHAUST NF-P12
AOC 40" CURVED 4k LG 55" C9 OLED G-SYNC 120HZ
Keyboard
LOGITECH 915 LINEAR WIRELESS
Mouse
LOGITECH G PRO WIRELESS LIZZARD GRIP 3M TAPE
Mousepad
STEELSERIES SMALL
Audio
LOGITECH G935 WIRELESS SCARLETT 2i2 AUDIO INTERFACE KRK ROKITS 10" & SENNHEISER HD 650 & 4.5.0 BTNC SL GRAND 88 CAKEWALK BY BANDLAB
Turtle Rig is offline
post #2 of 6 (permalink) Old 01-07-2020, 01:01 PM
Bad5ector's Avatar
Rep: 13 (Unique: 10)
Sounds like the HSF isn't making proper contact with the CPU and it is hitting thermal limits. If I was to guess.
Otherwise, x470... maybe a bios flash to the latest is in order to support the 3950x.
ShadowMoses
(21 items)
i7 7700K
ASUS ROG Maximus IX Formula LGA1151
EVGA GeForce GTX 1080 Ti Founders Edition
Corsair Vengenace Lpx 32GB DDR4 3200MHZ
Seagate ST1000DX001 SSHD 1TB 3.5in SATA3 64MB Cache Internal Solid State Hybrid Drive
Kingston HyperX Predator 240GB
EVGA SuperNOVA 1000 G1 80 Plus Gold Certified 1000W Fully Modular
RAD - EK-CoolStream XE 360
CPU Block - EK-Supremacy EVO - Nickel
GPU Block - EK-FC Titan X Pascal - Nickel
Pump / Res - EK-XRES 140 Revo D5 PWM (incl. sleeved pump)
Fans - 3 x EK-Vardar F4-120ER (2200rpm)
Coolant - EK-Ekoolant Pastel BLUE (concentrate 250mL)
Tubing - EK-DuraClear 11,1/15,9mm
Thermaltake Core P3 SE Snow Edition
Operating System
Microsoft Windows 10 Pro 64Bit
BenQ XL2720Z 27in LED 144HZ 1ms GTG FPS Gaming Monitor
42" LG TV
Keyboard
Corsair Gaming K65 Lux RGB Compact Mechanical Keyboard
Mouse
Corsair Gaming M65 Pro RGB Optical Gaming Mouse
Mouse
Corsair Gaming MM300
Bad5ector is offline
post #3 of 6 (permalink) Old 01-07-2020, 01:07 PM - Thread Starter
Turtle Rig's Avatar
Rep: 6 (Unique: 6)
Thank you sir, REP for you. I had him flash a BIOS but it was older prior to the 3950x hoopla. We will get the lateset BIOS update and update it one at a time until we get to last BIOS and see what happens. Also you are right it might be the contact ,, this is his 2nd PC build of his life. He lives far so I will have to just skype with him and tell him the things you said. Thank you, will report back. I think there are 2 new BIOSes for his board and I bet your right for 3900x its ok but not for 3950x. Once we finish with BIOS flashing one version at a time then we will see whats up. If it happens again Im gonna have him reseat his DRP4 and use the right ammount of paste. I learned about Kryonaut recently we will use that. I will tell him to screw it on tight but not tight enough to chip the motherboard. I think your on to something my friend, hopefully well sort things out. Also he is a bit of slow person and he has seizures and is not a retard but suffers daily and he tells me my only joy is when Im online and playing with others war games or whatever and surfing. Will report back thx my friend.
Keyboard
Mouse
Mousepad
STEELSERIES SMALL
Audio
post #4 of 6 (permalink) Old 01-07-2020, 01:33 PM
ACleverName's Avatar
Rep: 14 (Unique: 12)
You can also try running Memtest86 should you still have issues after that to weed out the ram (its 64 bit app now so it goes past 4 gigs and tests all avail) Also try another PSU as i had some goofy issues with one where it was doing the same. Use a known good one if possible.
Just Roll With It
ACleverName is offline
post #5 of 6 (permalink) Old 01-19-2020, 07:29 PM
crazycrave's Avatar
Rep: 5 (Unique: 5)
If it's not a new Max edition board then the x470 does not have the right bios to boot it as I used a 2200g to boot my MSI X470x Gaming Pro to get the bios updated for my 3700x .. also I need to recheck myself as the 3950x may have a newer bios then mine which is AGESA 1004 Beta b
Ryzen 5 3600
Gigabyte AB350M-DS3H CF
G-SKill 16Gb
Red Dragon RX 570 8Gb
Corsair TX 650 watt
https://valid.x86.fr/yhrtin
crazycrave is offline
post #6 of 6 (permalink) Old 01-19-2020, 08:21 PM
LTSC Consiglieri
skupples's Avatar
Rep: 658 (Unique: 351)
did turtle rig go with a 3950x and just not wanna admit it? hmmmm
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
skupples is offline
