XFX 5700XT RAW II, seeking help! - Page 2 - Overclock.net - An Overclocking Community
post #11 of 16 (permalink) Old 02-24-2020, 09:05 PM
treetops422's Avatar
Rep: 22 (Unique: 16)
Quote: Originally Posted by K1ll3rGreen View Post
So... I re-installed the 2020 drivers and gta5 is performing as one would expect.. but I can't use the same undervolt//overclocks and computer crashes on factory settings running burn test. also my goto benchmark is minimal 20 frames less. This is where i call it a night..
Your computer is not crashing, radeon settings(wattman) is crashing.
Please try this and report back to me if it solved your problem. I think the root of stuttering etc is Radeon Settings(Wattman).
My most successful current work around for all issues. DDU safemode, update to the newest drivers. Follow the simple instructions below given to me by another member. OC with AB. Monitor with GPU-Z. Basically you are nuking Radeon Settings(Wattman).
No anti lag, no image sharpening (you can use reshade if you really want it), but most importantly no more head aches.
"program files]\AMD\CNext and delete everything.
open up task manager and shut things down and delete them
It's pretty hacky, but it works
you do need aticlxx, but that's all.
No graphics settings once you do this."
Sapphire Radeon RX 5700 Non XT Boost Core 2035 Gaming Ram 960 43c Air Water Hybrid Cardboard Blower with a 20$ chinese Waterblock on the core 50 gallon tote of water, Ryzen 3700x 4.25 ghz, 15$ chinese waterblock, same tote 3200 ddr3 cl16 Team T-FORCE VULCAN TUF , B450m Asrock Pro 4 Mobo, 700 Watt OCZ PSU.
treetops422 is offline
post #12 of 16 (permalink) Old 02-25-2020, 04:52 PM - Thread Starter
Jack of all trades
K1ll3rGreen's Avatar
Rep: 1 (Unique: 1)
Thank you, I will give this a try tomorrow when at PC and report back. How do I install just the drivers and not the full suite that comes from AMD's download for the 5700xt?
K1ll3rGreen is offline
post #13 of 16 (permalink) Old 02-26-2020, 09:05 AM
You can't atm as far as I know, but deleting all the bloatware seems to work out pretty well.
post #14 of 16 (permalink) Old 02-27-2020, 10:23 AM - Thread Starter
Jack of all trades
Rep: 1 (Unique: 1)
You are correct, without the 'bloatware' running and messing with nothing this card works as should. I can not use MSI AB for overclocking for whatever reason, crashes everytime I do a test run. Any idea why or alternatives to get this card OC//UV'd?
post #15 of 16 (permalink) Old 02-27-2020, 09:27 PM
I use AB, but it automatically messes up my settings by default it goes to 1.25v, if I set the volts at that max in MPT. Even without AB running. If I do not mess with the volts, AB OCs just fine. You really don't need to mess with the volts anyways. MPT can save your config if you want it too.
So to reiterate, if I set max voltage to 1.3(don't do that), AB despite showing 1.2v will OC to 1.3v. Even if I do not run it, no it is not set to run on windows start. So maybe do not touch the volts in MPT or AB? The 1.2v set in MPT do fine. idk why the voltage has issues with this setup.
Unless you want to save on your power bill, I don't think there is any reason to undervolt. I leave it a 1.2v, the default. I'm glad to hear this workaround is effective beyond just me.
btw thank Schmuckley for this little fix
post #16 of 16 (permalink) Old 02-28-2020, 12:29 PM - Thread Starter
Jack of all trades
Rep: 1 (Unique: 1)
MSI AB seems to be functioning properly now that I have completely deleted CNext folders and included SW 'features'. Now to solve vram and delta temps... I get temp blackscreens or full blackscreen lockups when delta temp hits 85c or higher during burntests/benches. VRAM temps are also at least 10c higher than core under normal use, assuming they're not making proper contact or thermal solution used isn't great? Already taken card out once and screws did have a quarter turn or less to snug up, Any ideas on a better cooling solution for the whole card? Heat sink is super beefy and keeps core temps well within reason but that doesn't matter much if ram overheats and crashes everything.
