5700XT Help - Junction temps (MSI GAMING X) - Overclock.net - An Overclocking Community
post #1 of 26 (permalink) Old 04-02-2020, 10:37 PM - Thread Starter
Irev's Avatar
Rep: 3 (Unique: 3)
Hello AMD , ❤
Kinda need some help regarding my 5700XT and the ever climbing junction temperatures.
I have the 5700XT Gaming X from MSI and the ‘Junction’ temps keep climbing up over time, increasing the fan curve and acoustics of the card. What could be causing Junction temps to go from a normal ‘great’ temperature to a ‘bad’ temp in this way ???
I will need to explain
When I first got the card I run some stress testing to check temperatures, 3dmark timespy on a 1 hour loop, core temp 74c and junction temp 92c
around 3 months later I do some testing and notice Junction temps are way high , core temp now 73c and junction 108c !!!
I decide to re-paste the card thinking that it is probably bad paste from factory.
After a re-paste I run a test and now card is good again temps even better then factory, core temp 66c junction 81c
thinking this had solved the problem around 1 week later I re-test and notice that temps are BAD again, now 81c core and 108c junction…
I thought maybe I didn’t apply enough pressure when re-pasting card and it could have air bubbles or something (I think that is a real thing!?) lol
So this time I did another re-paste this time I applied a little more paste then before and did the process more carefully. I also added in a ‘GPU bracket’ once the card was installed back to my case to stop any sagging and keep the card secured better…. When testing core temp now 71c and junction 88c – back to normal again!
3 days later I re-run my testing and would you believe it … temps gone BAD again 79c core 106c junction…..
What am I doing wrong here!?
A couple of thoughts I have >>>
1. Bad Thermal paste? - I'm using Noctua NT-H1
(however the factory thermal paste showed same symptoms)
2. Vertical mount? – Should a card of this weight be horizontally mounted?
(Would this take away mounting pressure issues?)
3. Screw retention? – does my card not have enough pressure from heat sink to GPU ??
(Interesting mention, if I apply ‘pressure’ with my hands between fan shroud and back plate the ‘Junction’ temps drop instantly by around 10-15c and as soon as I ‘release’ the pressure with my hand Junction temps rocket up again instantly)
I’m getting pretty worn out dealing with the issue as this is my 2nd 5700XT with temp problems, the first one being a 5700XT MSI EVOKE. I was confident the Gaming X would be much better… very frustrating
5700XT | AMD | RYZEN 7 1700
Irev is offline
post #2 of 26 (permalink) Old 04-02-2020, 10:50 PM
PC Enthusiast
Ashura's Avatar
Rep: 50 (Unique: 38)
The Junction temp is not just related to the core, so reapplying thermal paste isn't going to help.
Your memory temps might be high, perhaps in the high 90s. The cooler is not making good contact with the thermal pads on the card.
MSI cards are the worst 5700XTs in cooling, especially the Memory.
The easy solution is to undervolt the card.
PolaRyz
(15 items)
AMD Ryzen R7 1700x
Asus Crosshair VI Hero
Asus GTX 1060 6Gb
Hyper X Predator 32gb 3000Mhz
Crucial MX100 256 GB
Seagate ST1000DM003
Toshiba DC01ACA300
SeaSonic S12G 750w 80+ Gold
Phanteks TC14PE
Phanteks Enthoo Pro
Operating System
Windows 10 Pro x64
LG 23MP68VQ
LG 23MP68VQ
Mouse
Logitech G402 Hyperion Fury
Mousepad
Steelseries Qck Mass
Ashura is offline
post #3 of 26 (permalink) Old 04-02-2020, 11:04 PM - Thread Starter
Irev's Avatar
Rep: 3 (Unique: 3)
https://www.youtube.com/watch?v=PdC8konCqMM&t=121s
Thanks for your reply, the video you linked shows the EVOKE my card is the MSI Gaming X, and is significantly better then the evoke in terms of cooling performance.
Undervolting is obviously an option however with a MSI Gaming X I shouldn't need it
Irev is offline
post #4 of 26 (permalink) Old 04-02-2020, 11:07 PM
PC Enthusiast
Ashura's Avatar
I know, But the problem you're mentioning is unfortunately quite similar to the Evoke.
For one reason or the other the cooler isn't making good contact.
you could tighten the screws, change the thermal pads etc...
but like you mentioned, it shouldn't be needed with a flagship card.
PolaRyz
(15 items)
AMD Ryzen R7 1700x
Asus GTX 1060 6Gb
Seagate ST1000DM003
Toshiba DC01ACA300
Phanteks TC14PE
Phanteks Enthoo Pro
Operating System
Windows 10 Pro x64
LG 23MP68VQ
LG 23MP68VQ
Mouse
Mousepad
Ashura is offline
post #5 of 26 (permalink) Old 04-03-2020, 02:39 PM
treetops422's Avatar
Rep: 24 (Unique: 18)
If it's not throttling then meh. However you could flip your computer upside down to see if it is mounting pressure. Or simply squeeze it with 2 fingers, watch n see if the temps drop, keep the pressure for at least a minute. Then of course, is it a lot hotter now where you live? Something to consider. Ambient temp makes a huge difference.
EDIT
"(Interesting mention, if I apply ‘pressure’ with my hands between fan shroud and back plate the ‘Junction’ temps drop instantly by around 10-15c and as soon as I ‘release’ the pressure with my hand Junction temps rocket up again instantly)"
I missed this. If you do it for a few minutes and it stays down. Even a minute. Then yeah you will benefit from more pressure. Flipping it or adding plastic washers to the screws on the backplate should help.
Sapphire Radeon RX 5700 Non XT Boost Core 2035 Gaming Ram 950 with a 20$ Chinese waterblock on the, Ryzen 3700x 4.25 ghz, 15$ Chinese waterblock, 3200 ddr3 cl16 Team T-FORCE VULCAN TUF B450m Asrock Pro 4 Mobo, 700 Watt OCZ PSU. 6 gallon res + back of a toilet tank with 240 mm radiator.
treetops422 is offline
post #6 of 26 (permalink) Old 04-04-2020, 06:09 AM - Thread Starter
Irev's Avatar
Rep: 3 (Unique: 3)
EDIT
Thanks for the reply, yep I also think it's a mounting pressure issue... I wonder if any other MSI Gaming X cards have this issue... obviously the issue is no were near as bad as the Strix mounting issue.
I'll test some 'pressure' for a minute or so and see what happens... still annoying to do this with this particular model!
Its one of those things were I Just think maybe I should have gone with the red devil or nitro card, but most of my system is currently MSI.
Irev is offline
post #7 of 26 (permalink) Old 04-04-2020, 06:54 AM
Intel in 2020 LOL
Rep: 38 (Unique: 19)
Have you messed with the power slider? My junction temp goes from 94C to 110C when I max that out.
AMD Bliss
(16 items)
AMD Ryzen 7 3700X
MSI X470 Gaming Pro - 1.0.0.4B
Sapphire RX 5700 XT Pulse
2x8GB G.Skill Trident Z 3600C15 @3800 14-15-12-28-40 1T 1.52V
Samsung 970 Evo Plus 250GB
2x Samsung 860 Evo 500GB
2x Crucial MX500 1TB
Super Flower Leadex II Gold 650W
be quiet! Dark Rock 4
Phanteks P350X
Asus VG245HE
Keyboard
Logitech G710+
Mouse
Logitech G502 Hero
Mouse
Logitech G502 Proteus Core
Mousepad
Logitech G440 hardmat
Audio
Asus Cerberus
Intel Core i5 4460
Gigabyte B85M-D3H-A
Sapphire RX 580 Nitro+ 8GB
2x8GB Kingston HyperX Fury @1600 CL10
Samsung 860 EVO 500GB
WD Blue 1TB
Super Flower Golden King Pro SF-500P14PE 500W 80+ Platinum
Intel Stock Cooler
Zalman Z11+
Operating System
Windows 10 x64
Asus VG245HE TN 1080p 75hz
Keyboard
Logitech G710+
Mouse
Mousepad
Logitech G440
Audio
Logitech X-540 5.1
Intel Core 2 Quad Q6600
Gigabyte P43-ES3G
Asus R9 270X Top 2GB
2x2048MB Kingston DDR2 800mhz
Samsung 840 EVO 120GB
WD Blue 1TB
Sirtec High-Power 80+ 400W
Some 92mm cooler
Zalman Z11+
Operating System
Win 7 Ultimate x64
Several LG/BenQ 17" 1280x1024 75hz
Keyboard
Logitech G710+ MX Brown
Mouse
Mouse
Razer DeathAdder 2013
Mousepad
Mousepad
Razer Goliathus Speed WoT Edition
rares495 is offline
post #8 of 26 (permalink) Old 04-04-2020, 09:01 AM
antonis21's Avatar
Rep: 14 (Unique: 14)
First of all i have the same card.For my experience the juction temp is the the same from the first day i bought the card.My current settings at wattman 2070mhz core 1,11v,mem 1820mhz ,45%fun curve only, max and power limit 5%.With these setting my average gaming clock is arround 2015mhz and temps at demanding games or timespy 70-73 for gpu and 90-93 junction.When i was trying to find the lowest Vcore for 2150mhz(2090mhz real clock) on wattman where in my case is 1,16v and power limit up to 15% then i had hard time to tame the junction temp,i had junction around 100c with 55% fun and sometime due to tem spikes of 103-105 fun was going 2300 rpm.So i use max core clock settings only for benchmarks now.This is my experience with the card is a really good overcloker.Are you using latest drivers?Maybe you get some wrong readings due to old driver or incorrect installation
PHENOM 9950 3.1GHZ http://valid.x86-secret.com/show_oc.php?id=433823PHENOM II 940 3.840Ghz http://valid.canardpc.com/show_oc.php?id=976928CORE I7 3770K 4.7GHZ http://valid.x86.fr/rygvzcCore i9 9900k 4.9Ghzhttps://valid.x86.fr/iv2ulq
i9 INSIDE..
Intel Core i9 9900k
ASUS ROG z390F-Gaming
MSI RX 5700 XT Gaming X
32GB Corsair Dominator Platinum 3200Mhz CL16
Samsung 970 Pro 512GB
Samsung 970 EVO Plus 500GB
Corsair RM850x White
CORSAIR H105
CORSAIR Graphite 760T White
Operating System
windows 10 PRO X64
SAMSUNG 23' 1080p
Keyboard
RAZER BLACKWIDOW
Mouse
LOGITECH G502
antonis21 is offline
post #9 of 26 (permalink) Old 04-04-2020, 05:25 PM - Thread Starter
Irev's Avatar
Rep: 3 (Unique: 3)
HI antonis,
I'm using latest drivers and get same temp reading from msi ab, gpuz and also radeon software.
See this attached image of the temp reading from factory paste, this is before I re-pasted the card, as you can see high junction temps but decent core temp. the fan is running around 1900rpm all settings stock.
The strange thing is after I repaste the junction drops to like 85c and stays there for quite a while after a day or two the temps slowly raise back up to the 105-109c junction.... im honestly not sure what to do here to fix it...
I did lay my computer down flat to 'test' vertical mounting the GPU however it made little to no difference in junction temps.
next thing to try is more mounting pressure.
Sidenote: my fans only start spinning once card hits 70c on the core temp does your card show same behavior?
Here is screenshot of temps im getting
Irev is offline
post #10 of 26 (permalink) Old 04-05-2020, 01:54 AM
antonis21's Avatar
So you tried different programs for tempreture readings.Its strange your temps are a lot higher than mine.My room temp is around 20c so nothing special.Can you tell tme your power consumption;Mine 170 to 195 watts at heavy gaming and 215w at time spy.For your information all this with Gpu Clock 2070mhz(2015 real) Vcore 1.11v and mem 1820mhz.
i9 INSIDE..
Intel Core i9 9900k
CORSAIR H105
Operating System
windows 10 PRO X64
SAMSUNG 23' 1080p
Keyboard
RAZER BLACKWIDOW
Mouse
LOGITECH G502
