Help my display is stuck Black and White!! - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 07-18-2007, 07:48 PM - Thread Starter
Rep: 48 (Unique: 48)
Don't know how this happened but my Video card is showing my clone screen in black and white. My main screen is fine it's in full color with no problems.
I didn't change a thing.
APOLLOSTEES is offline
post #2 of 8 (permalink) Old 07-18-2007, 09:04 PM
CyberDruid's Avatar
Rep: 2585 (Unique: 1242)
Restart and see if it happens again. If so try and reinstall the drivers and see if it goes away or comes back. I think it might be curable by a reinstall--I have never heard of anything like it.
August 13th, 2011 sad-smiley-002.gif Happy trails, may we meet again.
CyberDruidPC is History
CyberDruid is offline
post #3 of 8 (permalink) Old 07-19-2007, 03:37 PM - Thread Starter
Thanks for responding. Rep to you for your help.
Unfortunately that did not fix my problem. I am stumped I have uninstalled then reinstalled my graphics card driver, and the problem still remains.
Not only that I've gone into the Catalyst control center under TV properties 2 and tried actually switching it to black and white (like that is what I wanted) then switching it back to more under S-Video sharpness. That also did not work.
I am using the extended desktop mode. My main display my Viewsonic monitor is fine, but, my secondary display my HDTV which is connected via S-Video is stuck in black and white. Anybody else have a suggestion.
post #4 of 8 (permalink) Old 07-19-2007, 03:42 PM
Rep: 312 (Unique: 230)
Check the cables are secure?
Has it been fine in the past?
cheers.gif British Overclockers Club
The Fury is offline
post #5 of 8 (permalink) Old 07-19-2007, 03:46 PM - Thread Starter
Duh
Wow I should've caught that! You were so right the cable was not fully connected on my card. I reseated it and it's back in full color.
Hey we're all intitled to 1 bonehead mistake. I really apreciate you responding rep to you.
post #6 of 8 (permalink) Old 07-19-2007, 03:48 PM
No problem. Glad you got it sorted
The Fury is offline
post #7 of 8 (permalink) Old 12-02-2009, 03:30 PM
Fractoman's Avatar
Rep: 0
Similar issue as the poster's though not as easily remedied (yes I tried unplugging and plugging back in the monitor). Viewsonic a91f+ CRT is stuck in black and white on windows load (strangely enough the bios post screen is still shown in color). I've reinstalled my drivers, fiddled with some other settings in my graphics card settings utility and in windows display settings that didn't do anything. My HDTV hooked up through a HDMI to DVI connection still shows color. All drivers are up to date and my system is stable.
Specs:
Vista Ultimate 64
Core 2 Duo 6700 2.66Ghz
BFG Geforce 260GTX
Fractoman is offline
post #8 of 8 (permalink) Old 10-11-2014, 12:16 PM
jbollinger0's Avatar
Rep: 0
I had the same problem with 14.9 drivers from ati/amd. had to use amdcleanuninstallutility and reinstall the drivers. I install the 14.9.1 beta since they fixed a bunch of stuff .
http://www.ngohq.com/?page=Files&go=giveme&dwn_id=1726
jbollinger0 is offline
