GUIDE to Enabling "Unofficial Overclocking" in MSI Afterburner - Overclock.net - An Overclocking Community
post #1 of 62 (permalink) Old 01-04-2010, 11:11 PM - Thread Starter
Rep: 121 (Unique: 96)
Hey OCNer's,
Actaully Have two things for you here.
1.) I attemped this and asked advice from some people and didn't really get a straight answer. So I indulged myself to figure it out and did so.
I also wanted to inform those of you having issues enabling the "unofficial Overclocking" feature in the MSIafterburner Program for convenience of NOT having to use Both the AMD GPU Tool (to change the frequency) AND MSI Afterburner (Just for the voltage).
Here are instructions on how to do so. Make sure that you follow step #3. Otherwise it won't work!
1.) You'll need to Open the MSIAfterburner.cfg with Notepad
2.) Change the "enable unofficial overclocking" Value of 0 to 1. Select "File" and select "Save as".
3.) When the "save as" window pops up select "All Files" in the "Save as type" box and save!
4.) It wil ask you to confirm the "Overwrite of the file" Select "yes".
5.) And finally, the result is that you can fully change the Voltage and Clock frequency of the Core and Ram on you Video Card. No more using the AMD GPU Tool and MSI Afterburner Combo. And the great thing is that you can save it to load at Startup. As well as setting individual settings for seperate tasks using "Hotkeys" on your keyboard.
You are done and should be able to Use ONLY MSI Afterburner to overclock your ATI Series Card past the max CCC Frequency!
Have fun!!!
And lastly.....
2.) Have you ever receieved this messege when trying to Launch MSI Afterburner?
"Some of MSI Afterburner components are expired, missing or corrupted!"
Well I have, among others. I was given a simple fix by OCN user "Chucklez". Thanks Buddy!!!!
Here is what he had to say.
"Ok what I had to do what I installed it on my friends rig (or spare rig) and then went to My Computer, Program Files and then found the MSI Afterburner file. Then I copied and pasted that onto a flash drive and plugged it into my computer and moved the MSI Afterburner file into my Program Files and created a shortcut and it worked."
So if you ever come across this issue, here is your solution!
Take Care Gang and we'll see ya in the threads!
Mastiffman is offline
post #2 of 62 (permalink) Old 01-04-2010, 11:49 PM
TekWarfare's Avatar
Rep: 93 (Unique: 80)
Good guide, images would be useful for those really strugglin but a brilliant walkthrough for those who understand whst they're doing.
Delete the system32 folder. Its holding you back.
My mother and I have expressed interest in buying out AMD.
TekWarfare is offline
post #3 of 62 (permalink) Old 01-04-2010, 11:57 PM
Rep: 46 (Unique: 46)
I was going to make a post about this soon but no need now.
+rep
Add me on Xbox Live: remzguy
ninja.gifThe *OFFICIAL* HAF 932/922 Case Owners Clubninja.gif
razorguy is offline
post #4 of 62 (permalink) Old 01-05-2010, 12:07 AM
Retired Staff
brettjv's Avatar
Rep: 1156 (Unique: 763)
I'll go ahead and add my two bits on this.
After you've done the above, proceed to do this in the Afterburner app:
1) Save your default clocks to profile 1
2) Figure out your max overclocks, set them, and save them as profile 2
3) Go into the Settings/Profile and set saved profile 1 as your '2d Profile', and saved profile 2 as your '3d Profile'.
This way your clocks won't get stuck on your 3D OC'd settings when you are just tooling around on your desktop.
a nudge is as good as a wink to a blind bat, eh?
xeon X5675 6c/12t @ 4.1ghz (1.29v, 20x205 +ht) Gen 1 I7 Baby!!!
rampage iii extreme
Powercolor Red Dragon Vega 56 (Samsung) Stock Bios For Now!
6 x 2gb corsair xms3 pc12800 ([email protected])
hynix 250gb ssd (boot), 2tb deskstar (apps),1tb spinpoint (bu)
Optical Drive
plextor px-712sa - still the best optical drive ever
abs sl (enermax revolution) * single 70A rail 850w
corsair h8o v2 aio
silverstone rv-03
Operating System
W10 home
LG Ultrawide QHD 21:9 Curved IPS Monitor 3440 x 1440 AMD FreeSync
Audio
XFi Titanium
brettjv is offline
post #5 of 62 (permalink) Old 01-05-2010, 04:32 PM - Thread Starter
Glad that I could help you guys out! I know that it's always good to have a Rich Knowledge base with helpful links!
post #6 of 62 (permalink) Old 01-05-2010, 04:36 PM
Rep: 92 (Unique: 84)
If you don't have access to another rig and have a thumb drive or external HD handy, you can also install MSI Afterburner on that, then move the required folder over to you main drive as stated, it should fix the corruption problem. Anyway nice guide!
Penecks is offline
post #7 of 62 (permalink) Old 01-05-2010, 05:09 PM
Bunneh's Avatar
Rep: 10 (Unique: 7)
This didn't seem to work All it did was open up rivatuner statistics server technology( it didn't switch automatically for me from 2d to 3d clocks)
Bunneh - The Jack-a-lope
Bunneh is offline
post #8 of 62 (permalink) Old 01-05-2010, 05:35 PM
GOTFrog's Avatar
Rep: 50 (Unique: 36)
Also for those with windows 7 and can't save the file.
a) right-click on the file
b) select properties
c)go to security or permission tab, can't remember of hand
c) select users and click edit
d) click on allow complete control
e) click on apply
f) resave file
OCN Headphone Club
"Because perfect hair is overrated"
My House
Q9550 @ 4590MHz 34th on the Bot
GOTFrog - Froggy went a-courtin', and he did ride
/ \ ☻This is Bob. His head falls off when he sees awesome computers
GOTFrog is offline
post #9 of 62 (permalink) Old 01-25-2010, 04:29 PM
badger6021's Avatar
Rep: 51 (Unique: 41)
e) click on apply
f) resave file
thats alot for this was having trouble saving it till i did this thanka bunch rep+ added
badger6021 is offline
post #10 of 62 (permalink) Old 01-25-2010, 05:25 PM
Chucklez's Avatar
Rep: 209 (Unique: 158)
Glad I could help out with them MSI Afterburner problems guys!
-You know, if we were really dating this would be the part where I'd be forced to kiss you goodnight.
Forced? Would it be so bad?
(smiles) I'm sure I could suffer through it.
Me too.
~Chuck, 2007-2012
Kardiac 2.0
(15 items)
Intel i7 4930K
ASUS Rampage IV Black Edition
ASUS ROG GTX 1080 Ti Poseidon
Corsair Dominator Platinum 32GB
Samsung 500GB EVO SSD
WD 2TB Black
Corsair AX1200
Bitspower Summit EF Custom Watercooling
Corsair 750D
Operating System
Windows 10
LG 34UC98
Keyboard
Corsair K70 LUX RGB
Mouse
Logitech G900
Mouse
Razer Goliathus Team Liquid Edition
Audio
Beyerdynamic DT880 Pro/KRK Rokit 5
Chucklez is offline
