3 monitor display with 560 Ti SLI - Overclock.net - An Overclocking Community
post #1 of 15 (permalink) Old 08-19-2011, 10:36 AM - Thread Starter
Reloaded83's Avatar
Rep: 57
I've been googling around this morning, but can't quite seem to find what I'm looking for (and nvidia's site as well as the sticky up top for the SLI FAQ is HORRIBLY out of date). Perhaps my google-fu is weak this morning..
Anyway, I just recently went SLI with 2 560 Tis, and have 3 20" 1680x1050 monitors. Planning to try out some surround gaming this evening. How do I set this up? I read on one post that with the 4 series and up cards, you can still run SLI with 3 monitors? In another post it said that you have to disable SLI. Unfortunately, most of the stuff is from at least a year ago, so I'm not 100% on the setup for the 5 series cards.
Can you advise me on which monitors to hook where, and what settings I need to adjust in the control panel to make the most of 3 monitors and 2 cards? Thank you in advance.
(FYI, I won't be home to try anything out till this evening.)
Reloaded83 is offline
post #2 of 15 (permalink) Old 08-19-2011, 10:42 AM
t-ramp's Avatar
Rep: 342
I'm pretty sure SLI needs to be enabled for Surround. Here's Nvidia's requirement page.
Rest in peace, Syrillian.
t-ramp is offline
post #3 of 15 (permalink) Old 08-19-2011, 10:48 AM
Boulard83's Avatar
Rep: 37
Go to Nvidia panel.
Enable SPANNING
Set your display as you wish
Bingo !
RE_BTTB • Asus Rampage V Extreme • 4x8gb Corsair Platinum • i7 5930k • MSI GTX 1070 Gaming X
Intel 600p 512gb + Crucial M500 960gb + 2x Agility 4 256gb • EVGA 1200 P2 • BenQ XR3501 35inch 144hz 2560x1080
Serveur • Asrock EP2C602-4L/D16 • Dual Xeon E5-2670 • 2x Phanteks PH-TC14S • 32gb, 8x4gb Kingston DDR3 ECC
Plextor M5S 128gb • Agility 4 128gb • 4x 2TB Red • 1x 1TB Black • Asus GTX 650 Ti • Corsair HX850 • Rosewill RSV-R4000 RLT
Joolac • Asus P8H61-M • 2x4gb ECC • Xeon E3-1230v2 • EVGA GTX 960 • 2x Toshiba Q 256gb • Antec 550w Platinum • LG IPS 1080p
HTPC • Zotac Pico • Réseau • Linksys WRT1900ac + Linksys LGS116P • Tablette • Asus T100 32gb Win 10 • Cell • Nexus 5 stock
Boulard83 is offline
post #4 of 15 (permalink) Old 08-19-2011, 10:49 AM
Rep: 95
By three monitors do you mean Eye-infinity? I'm also interested in knowing this and might add that do you also need a Display port for SLI to add the 3 monitors?
Sodalink is offline
post #5 of 15 (permalink) Old 08-19-2011, 10:53 AM
Pascal1973's Avatar
Rep: 29
Pascal1973 is offline
post #6 of 15 (permalink) Old 08-19-2011, 10:59 AM
Boulard83's Avatar
Rep: 37
No, no need of DP.
But you need 2 cards, and the OP seems to.
Its better to use 3 identical display with identical connection ( IE 3x DVI ). But it can work with a mix match of DVI et HDMI.
Just plug 3 display, boot, nvidia panel, set sli and physX, use spanning, config, bingo !
post #7 of 15 (permalink) Old 08-19-2011, 11:00 AM
t-ramp's Avatar
Rep: 342
Eyefinity is AMD's multi-monitor system. For Nvidia it's just called Nvidia Surround.
But, yes, for Eyefinity you'll need to use DP.
t-ramp is offline
post #8 of 15 (permalink) Old 08-19-2011, 11:03 AM - Thread Starter
Reloaded83's Avatar
Rep: 57
Ok, so it doesn't matter which card I plug 2 monitors into then? Also, thank you
post #9 of 15 (permalink) Old 08-19-2011, 06:12 PM - Thread Starter
Reloaded83's Avatar
Rep: 57
Allright well I have the three monitors plugged in, all via DVI, and all the monitors are the same. I have enabled spanning, and set the displays so that they are correct. Kinda ridiculous having my start button and programs on the left monitor, the websites in the middle and the clock and stuff on the right... But anyway, I went into FEAR 3, since I knew it was a game that has 3 monitor support, and messed with the resolutions, but the top and bottom is a bit cut off no matter what res I use. I used 5040x1050 since that should be what these monitors max would be, but it doesn't feel right. And the gun/hud setup is partially spanned onto the other screen. I thought it should basically make the middle like normal, and the other two just give a bit more sight to the left and right. Still going to mess with it. I'm running the 280.26?WHQL drivers.
post #10 of 15 (permalink) Old 08-19-2011, 06:20 PM
Boulard83's Avatar
Rep: 37
Never tryed this game with my surround setup.
But yes in some games the HUD become harder to use cause its on the left and right monitor.
I personally put my taskbar in windows on the left of the left screen. So all you need is on the left.
