GTX 580 SLI + 3 monitors PROBLEM. Thanks. - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 12-27-2011, 07:49 PM - Thread Starter
So one of my friends needs help with a problem that he has.
Since I don't have any experience with SLI I was hoping that you guys could help me.
His problem:
" when I try to use 3 monitors with sli 580s, only 2 work, only 1 580 is shown in device manager and nvidia control panel.
I have 2 monitors connected to top card via DVI and 1 on bottom (1 that don't work) connected via DVI "
Thanks,
-Frostbite-
-Frostbite- is offline
post #2 of 8 (permalink) Old 12-27-2011, 07:54 PM
wint0nic's Avatar
Rep: 60 (Unique: 56)
Did you enable SLI in nvidia control panel?
wint0nic is offline
post #3 of 8 (permalink) Old 12-27-2011, 07:55 PM - Thread Starter
He says that there is no option available.
-Frostbite-
post #4 of 8 (permalink) Old 12-27-2011, 07:59 PM
Ken1649's Avatar
Rep: 960 (Unique: 652)
Uninstall Forceware and make sure the SLI bridge mounted firmly then reinstall Forceware. Then check in Device manager if both 580s listed and no error or one of them is disabled. Then go to NV CP to select SLI.
Ken1649 is offline
post #5 of 8 (permalink) Old 12-27-2011, 08:13 PM - Thread Starter
Ok thanks, he's on it.
-Frostbite-
post #6 of 8 (permalink) Old 12-27-2011, 08:20 PM
Blue Marker's Avatar
Rep: 114 (Unique: 81)
If the 580 is anything like the 480, three monitors will not work in SLI. Unless there has been changes recently, I was not able to get 3 monitors to work with my old setup of three GTX 480s in Tri-SLI. However, I did have different sized monitors (1x 23'', 2x 20'') and it would not work.
I do remember reading that triple monitor spanned (surround gaming) will work in SLI, but all the monitors must be the same size.
Blue Marker is offline
post #7 of 8 (permalink) Old 12-27-2011, 08:28 PM - Thread Starter
He says "Still no SLI mode in control panel"
-Frostbite-
post #8 of 8 (permalink) Old 12-27-2011, 09:16 PM
I think one card is defective.
BlackandDecker is offline
