Running HDMI on GTX570.. audio? - Overclock.net - An Overclocking Community
post #1 of 10 (permalink) Old 02-13-2012, 10:15 PM - Thread Starter
stephen4036's Avatar
Rep: 0
I have a P8Z68 mobo, and a GTX570 with the mini HDMI and adapter.. running to my 1920x1080 asus monitor, how do I get sound and video to run through the HDMI port? video works great.. just need to get audio to work.
stephen4036 is offline
post #2 of 10 (permalink) Old 02-13-2012, 10:17 PM
brownieapple's Avatar
Rep: 18 (Unique: 8)
fiddle with your audio settings. that is what i had to do. click the speaker icon on your taskbar assuming it is there and the first column that says 'device' there should/might be a drop down menu and select from there.
Quotes! (Click to show)
Given that I travel with a gun AND a full size tube of toothpaste, TSA isn't much of a factor.... rolleyes.gif
brownieapple is offline
post #3 of 10 (permalink) Old 02-13-2012, 10:18 PM
woot
Rep: 256 (Unique: 211)
assuming it is the same as it was for one of my previous cards with an hdmi port, the vid card has to have a spdif in where you patch the audio from the mobo (or discreet sound card) into the vid card and it simply passes it to the hdmi out port
which 570 do you have?
There are some things that smoke can come out of and still be good, for instance, a bong. Bad things for smoke to come out of, computer parts.
sli_shroom is offline
post #4 of 10 (permalink) Old 02-13-2012, 10:20 PM
Rep: 18 (Unique: 8)
this video does a better job than my post.
post #5 of 10 (permalink) Old 02-13-2012, 10:22 PM - Thread Starter
Rep: 0
evga superclock
post #6 of 10 (permalink) Old 02-13-2012, 10:23 PM - Thread Starter
Rep: 0
nice video, worked great. your the best.. didnt think it would auto pop up into output devices. thank ya sir!
post #7 of 10 (permalink) Old 02-13-2012, 10:26 PM
Rep: 18 (Unique: 8)
thanks no problem. just doing my part to help out another OCN member smile.gif
post #8 of 10 (permalink) Old 02-14-2012, 10:57 AM
Coach Mcguirk's Avatar
Rep: 20 (Unique: 17)
So if you use a discrete sound card, and play audio through HDMI, it uses the sound card for the actual device? Is my Asus Xonar passing through my video card?
Sent from my SAMSUNG Galaxy S.
Coach Mcguirk is offline
post #9 of 10 (permalink) Old 02-14-2012, 11:07 AM
Rep: 18 (Unique: 8)
i don't think so. i think you are going to have to run a SPDIF cable from the soundcard to the monitor/tv.
i'm assuming though since i don't actually have a soundcard.
post #10 of 10 (permalink) Old 02-14-2012, 03:05 PM
woot
i dont know how current vid cards do it, but the 8 series nvidia cards used a spdif jumper that took the output of the sound card (or onboard sound) and patched it through the vid card to the hdmi out port. so yes, the sound card was the actual sound device being used and the vid card was just acting as a pass thru to get the sound to the right place. it isnt like the vid card has an onboard sound processor.
