Graphics Card Issues - Overclock.net - An Overclocking Community
post #1 of 2 (permalink) Old 06-26-2014, 07:51 PM - Thread Starter
Gnarvirus's Avatar
Rep: 0
I was helping my brother build a computer and ran into some issues with the GPU. The computer would not POST so I pulled the GPU and everything worked fine. Was able to install windows and all the drivers. However once I put the card back there is no display signal either from the card or onboard. Not sure what the issue could be any help is appreciated. And I did double check all power connections to the GPU and PSU and pulled and reseated the card multiple times to make sure it wasn't a loose connection. I don't think a defective card would affect onboard video so i'm hoping its a bios setting. I flashed the MB bios to the newest version also.
The system specs are:
Asrock z97 extreme 6
EVGA GTX 770
EVGA G2 750 watts
Patriot Viper 8g
i5 4690k
Gnarvirus is offline
post #2 of 2 (permalink) Old 06-29-2014, 01:48 AM
IMKR's Avatar
Rep: 38 (Unique: 28)
Dunno if you got the problem solved but, you can (taking your word for it that you have all the connections correct)
1) try a different GPU in the same PCIE lane
2) move the same GPU to a different lane
if either 1 or 2 works )
if you try a different GPU in the same PCIE lane and it works, your current GPU is defective or you somehow damaged it
and if you use the same GPU on a different lane, the first lane is malfunctioning
IMKR is offline
