Does my PSU have enough power to run the 8800gtx? - Overclock.net - An Overclocking Community
post #1 of 6 (permalink) Old 01-21-2007, 04:52 PM - Thread Starter
Rep: 12 (Unique: 12)
Hi guys
I was wondering if my OCZ 600watt psu http://www.newegg.com/Product/Produc...82E16817341001
has enough current to run the 8800gtx. The specs say it requires 28A. The psu only has 4 18A rails. Does the psu require a total of 28A across all the +12 rails?
-=R00bin=- is offline
post #2 of 6 (permalink) Old 01-21-2007, 04:56 PM
airmike532's Avatar
Rep: 23 (Unique: 21)
great question, cause I just bought the same thing and am also wondering that too.
Gmail: the 1337 Mailthumb.gif
airmike532 is offline
post #3 of 6 (permalink) Old 01-21-2007, 05:00 PM - Thread Starter
Now that I think about it, it should be ok because https://www.overclock.net/nvidia/1499...0gtx-help.html
One of the guys has the 700 watt version and also has an 8800gtx
post #4 of 6 (permalink) Old 01-21-2007, 05:20 PM
zombeeaholic's Avatar
Rep: 0
Originally Posted by -=R00bin=- View Post
Hi guys
I belive that is 28amps for a single rail power supply like my ULTRA V SERIES 500 watt ATX power supply. If you have 4 rails at 18amps each you should have PLENTY of power. I know my 8800GTS is smaller,but if my 500 watt V SERIES runs it without ANY problems your OCZ 600 watt will run your GTX fine.. Your OCZ psu is a GREAT power supply. I`ll be running a 750 watt OCZ on my new e6600 system. Hope the info helps,,,,Zombeeaholic...
zombeeaholic is offline
post #5 of 6 (permalink) Old 01-21-2007, 05:25 PM
alexisd's Avatar
Rep: 171 (Unique: 143)
Yup you going to be fine with the ocz 700 wtts.No problem.At least for 1 card.And the problem I have is no power .
alexisd is offline
post #6 of 6 (permalink) Old 01-21-2007, 05:29 PM
Retired Staff
Mootsfox's Avatar
Rep: 693 (Unique: 434)
The OCZ GXS 700w has 56A across the 12+ volt rails. The 600 watt model has 50A. You can run two 8800GTX's with the GXS 700 watt. You will have no problem with the GXS 600 watt if you want to run a 8800GTX.
Certs:
A+
ACMT
Dell ASP; Desktop, Laptop, PowerConnect, PowerEdge, PowerVault
Mootsfox is offline
