GTX 760m OC more than 135mhx, looking for vbios and guide to oc this card as much as i can - Overclock.net - An Overclocking Community
post #1 of 38 (permalink) Old 07-10-2016, 10:13 AM - Thread Starter
Devis Level 1
Devis's Avatar
Hello guys, I really need help with unlocking my vbios i have been looking everywhere asking for help no one seems to help or don't know. i just need help with unlocking my core clock on my gtx 760m so i can push this card to the limits. Thanks for your time smile.gif
Devis is offline
post #2 of 38 (permalink) Old 07-10-2016, 10:32 AM
d0mini Level 1
d0mini's Avatar
Hey, can you post the exact model of your laptop? Custom BIOSes are available for some models of laptop, but not many.
Flashing the VBIOS of a laptop is harder to do than on a desktop, as it is tied into the motherboard's BIOS. This basically means you can't get a .ROM file of your VBIOS through GPU-Z and you can't use NVFlash to flash a modded version like you would on a desktop.
Any modding has to be done through editing the laptop's stock BIOS file, and then has to be flashed in DOS or some other way that can be specific to the laptop. Unless you know what you're doing, I wouldn't try to edit one yourself. For certain laptops though, there are modded BIOSes available online. So let's start with what laptop you have smile.gif
P.S. Welcome to OCN!
Saphira Mk-III
(27 items)
[email protected], 1.36v (4.5GHz uncore)
Maximus VII Impact
MSI 980 Ti Gaming 6G
Corsair Dominator Platinum 16gb 2133 CL9
2x 840 EVO 500GB
Toshiba XG3 1TB (M.2 NVMe SSD)
MX 500 2TB
EVGA G2 850 PSU
EK Supremacy Evo & VGA
11x ML 120 PRO fans
5x Gentle Typhoons 1850rpm intake, 1x GT 1450rpm exhaust
PE-240; XT45 120; SR-2 360; XSPC RX 360; 2 x XSPC RX 480 rads
Corsair Commander Pro
Aquaero 6 LT; Splitty 9; Hubby7
2 x Ek Xres 140 pump/res
Phanteks Enthoo Elite
Operating System
windows 10
Acer Predator XB271HU
Keyboard
Corsair Strafe RGB
Mouse
Logitech G Pro Wireless
Mouse
MX Master AMZ
Mousepad
XXL neoprene mousemat goodness
Audio
Sennheiser HD 650
Audio
Senheisser Game Zero SE
Audio
Bose companion 20
Audio
GSX 1000
Audio
SMSL M6
[email protected], 1.23v (4.5GHz uncore)
Maximus VII Impact
2x 840 EVO 500GB
Corsair SF 450
2x Gentle Typhoons 1850rpm exhaust
PE-240 radiator
EK-DDC 3.2 PWM
M1 NCASE reservoir
NCASE M1
Operating System
windows 10
Acer Predator XB270HU
Keyboard
Corsair Strafe RGB
Mouse
Mouse
Audio
Sennheiser HD 650
Audio
Bose companion 20
d0mini is offline
post #3 of 38 (permalink) Old 07-10-2016, 01:31 PM - Thread Starter
Devis Level 1
Devis's Avatar
Oh, yeah i totally forgot, my notebook is msi ge60 2od-267xpl
Devis is offline
post #4 of 38 (permalink) Old 07-11-2016, 05:42 AM
d0mini Level 1
d0mini's Avatar
Hey, look what I found: http://forum.notebookreview.com/threads/msi-ge60-ge70-gpu-unlock-vbios-mod.770102/
Looks like for your particular laptop, what I said was wrong - the GPU VBIOS is separate from the motherboard's BIOS, so you can read it with GPU-Z to get your VBIOS, use Kepler Bios Tweaker to edit it, then flash it with NVFlash (looks like you have to do it in DOS).
There are tutorials on how to use all of these things here on OCN and also around the Internet, I've modded Kepler BIOSes a fair amount, so I can help you out if you have any questions about editing the VBIOS or anything else.
Saphira Mk-III
(27 items)
Maximus VII Impact
2x 840 EVO 500GB
MX 500 2TB
EVGA G2 850 PSU
11x ML 120 PRO fans
Operating System
windows 10
Keyboard
Corsair Strafe RGB
Mouse
Mouse
MX Master AMZ
Mousepad
Audio
Sennheiser HD 650
Audio
Audio
Bose companion 20
Audio
GSX 1000
Audio
SMSL M6
Maximus VII Impact
2x 840 EVO 500GB
Corsair SF 450
PE-240 radiator
EK-DDC 3.2 PWM
M1 NCASE reservoir
NCASE M1
Operating System
windows 10
Keyboard
Corsair Strafe RGB
Mouse
Mouse
Audio
Sennheiser HD 650
Audio
Bose companion 20
d0mini is offline
post #5 of 38 (permalink) Old 07-11-2016, 06:15 AM - Thread Starter
Devis Level 1
Devis's Avatar
Much thanks mate, i will post here whether i succeded or not.
Devis is offline
post #6 of 38 (permalink) Old 07-11-2016, 09:01 AM - Thread Starter
Devis Level 1
Devis's Avatar
Here is my current vbios OC.zip 86k .zip file
Devis is offline
post #7 of 38 (permalink) Old 07-11-2016, 09:57 AM
d0mini Level 1
d0mini's Avatar
Before you do anything based off of info I give you, here's a little disclaimer. This is information I know primarily from desktop GPUs. I am fairly certain that this will work for you, but I can't be sure as I can't test it myself. If something goes wrong, I'll try my best to help you out, but it's your choice to do this or not. Flashing can brick your graphics card, and it can be very difficult to get it functional again.
Alright, lets start with clockspeed. You should be able to raise your clockspeed by increasing the TDP base clock and the Boost Clock. For simplicity's sake you can make these the same like this:
When you press save it will change the greyed out value to the same speed as well.
Set it to what you want, I would set it 135mhz higher than whatever clockspeed you can get now with the slider all the way (by the looks of it, 135MHz higher than 719?). That way you can be sure it will work and that you haven't gone too far.
You'll also want to change the boost table so the value in green is the clockspeed you want the card to run at, like this:
Saphira Mk-III
(27 items)
Maximus VII Impact
2x 840 EVO 500GB
MX 500 2TB
EVGA G2 850 PSU
11x ML 120 PRO fans
Operating System
windows 10
Keyboard
Corsair Strafe RGB
Mouse
Mouse
MX Master AMZ
Mousepad
Audio
Sennheiser HD 650
Audio
Audio
Bose companion 20
Audio
GSX 1000
Audio
SMSL M6
Maximus VII Impact
2x 840 EVO 500GB
Corsair SF 450
PE-240 radiator
EK-DDC 3.2 PWM
M1 NCASE reservoir
NCASE M1
Operating System
windows 10
Keyboard
Corsair Strafe RGB
Mouse
Mouse
Audio
Sennheiser HD 650
Audio
Bose companion 20
d0mini is offline
post #8 of 38 (permalink) Old 07-11-2016, 10:36 AM - Thread Starter
Devis Level 1
Devis's Avatar
Thanks for help with preparing vbios, now im encountering very weird problems whlie trying to run dos but its probably my usb drive fault, i will look for another one i can use.
Devis is offline
post #9 of 38 (permalink) Old 07-11-2016, 10:39 AM - Thread Starter
Devis Level 1
Devis's Avatar
By weird i mean, when im in boot menu and this pendrive is plugged in it says that it has 0.00gb and when i choose it, it runs system from ssd normally.
Devis is offline
post #10 of 38 (permalink) Old 07-11-2016, 11:35 AM
d0mini Level 1
d0mini's Avatar
Hmm.. You could try a different USB stick, otherwise just make sure you've tried all the options for USB in the BIOS, sometimes it comes up twice.
If nothing works, take a screenshot of your settings for rufus and we'll mess around with that
Saphira Mk-III
(27 items)
Maximus VII Impact
2x 840 EVO 500GB
MX 500 2TB
EVGA G2 850 PSU
11x ML 120 PRO fans
Operating System
windows 10
Keyboard
Corsair Strafe RGB
Mouse
Mouse
MX Master AMZ
Mousepad
Audio
Sennheiser HD 650
Audio
Audio
Bose companion 20
Audio
GSX 1000
Audio
SMSL M6
Maximus VII Impact
2x 840 EVO 500GB
Corsair SF 450
PE-240 radiator
EK-DDC 3.2 PWM
M1 NCASE reservoir
NCASE M1
Operating System
windows 10
Keyboard
Corsair Strafe RGB
Mouse
Mouse
Audio
Sennheiser HD 650
Audio
Bose companion 20
d0mini is offline
