How does OCing work on RTX cards?
So there's the stock clock, then there's a factory OC like on mine, and there's also the boost or whatever raises the clock even more than the OC. And then there's the power limits and thermal limits. So that right, is there more on these ?
On mine stock is 1410MHz, I don't know if my card ever runs at that tho. The factory OC on my zotac "AMP Extreme Core" is 1815MHz. Yesterday I saw 1925MHz held while I played FC4.
In up-to-date Afterburner, it only shows offset clock speeds for some reason, so I set the power limit to 110%, with voltage control off, and in game it still only ran at 1925MHz. I haven't tried manual OC. And IDR what the vram has been doing. IDK anything about the BIOS of GPUs in general, I hope this is not a card thats really strict and only allows what the factory set. I bet there's next to no difference between my "AMP Extreme Core" card at 1815MHz and the top zotac "AMP Extreme" at 1860MHz.
Hey I'm real happy with this card tho, with out of the box fan profile and everything else, its never gone over 68C, and its very quiet compared to all my past cards. And THERE"S NO COIL WHINE. I had a touch of that on my 980 ti
