Possible RTX issue - Flashing/flickering lines - Overclock.net - An Overclocking Community
post #1 of 2 (permalink) Old 02-04-2019, 09:18 AM - Thread Starter
Crooksy's Avatar
Rep: 379 (Unique: 349)
Hi,
Recently built a new rig featuring a Gigabyte RTX2080 Aorus Extreme. I have 3 displays, 1x144Hz and 2x60Hz, none of which are Free-sync or G-sync compatible
I noticed an issue a few days after building where I would get white horizontal lines flickering on my non-primary displays whilst gaming. I then noticed them whilst browsing on the desktop. I'm not sure what triggers them, whether it be load, temperature or application but they seem intermittant. It can last anywhere between 2 and 15 minutes or so with a flicker happening every few seconds to 10-15 seconds.
I don't see these lines on my primary monitor whilst gaming but it is somewhat annoying/distracting.
I didn't notice these issues on my previous build with a GTX980Ti with the same monitor setup. I've seen a few other mentions of the issue but not much discussion, some people pointing towards it being another RTX issue and therefore RMA where others are suggesting it's a driver issue. I've tried 3 different drivers and each suffering the same results.
Please see video for an example of what is happening -
Anyone have any further information or suggestions?
EDIT: So, after doing a little more playing, it seems that the issue is a lot more consistent under idle clock speeds (between 300-400Mhz). If I set all three of my displays to different refresh rates (120hz, 60hz, 59hz) I've noticed that the card doesn't go down to idle clocks, instead staying at around 1300Mhz. The flickers seem to disappear for quite a period of time at these settings. Not sure if coincidence or not, probably the worst bit about intermittent issues.
Animus
(22 items)
Intel Core i7 3770K
Asus Maximus V Formula Z77
EVGA GTX980Ti SC+ ACX 2.0+
2 x 4GB Corsair Dominator GT 1866Mhz
Samsung 840 Pro 128GB
2 x WD 1TB Blue EZEX RAID0
Corsair TX750
EK Supremacy - Copper / Acetal
EK 360XTX
EK Spin Reservoir - Acetal
EK Titan X & Backplate - Copper / Acetal
Liang DDC / EK Top
EK PSC Compression Fittings
Corsair 800D
Operating System
Windows 7 Professional 64bit
3 x Samsung P2450H 24"
Keyboard
Filco Majestouch 2 - Cherry Blues
Mouse
Razer Deathadder 2013
Mouse
Razer Destructor 2
Audio
Creative Titanium HD
Audio
Fiio E9 Amplifier
Audio
Beyerdynamic DT880 Premium (600 Ohm)
Crooksy is offline
post #2 of 2 (permalink) Old 03-29-2019, 11:46 AM
Rep: 0
i have the same issue, anyone know of a fix?
rebirthflame is offline
