Driver 418.91 419.17 cuts sound after long idle! - Overclock.net - An Overclocking Community
post #1 of 5 (permalink) Old 02-25-2019, 06:31 AM - Thread Starter
crashburn162's Avatar
Rep: 1 (Unique: 1)
Hi,
So after I updated to 418.91 I had problem my sound is connected via AVR with HDMI to my 1080 Ti and so far had no problem. After I updated the drivers I saw there is a new HD Audio driver 1.3.38.13 the problem is after a long idle time my AVR shuts off or I shut it off doesn't matter after that when I start using the PC again the sound cuts for 1 second in 2-3 second intervals and my AVR is loosing connection or it so indicates. I've rolled back to the old driver which is on the 417.22 drivers and the problem is gone. So I don't know why but something is wrong with the driver. I have friend with the same setup different AVR and he has the same problem as me after he updated to one of the new drivers. I can confirm that both 418.91 and 419.17 have this problem since they both use the new HD audio driver. I hope there is a fix for this. I have also tried the new driver on my HTPC setup which is with different AVR Yamaha RX-A2050 and it's the same story there. I've also tried to rollback the audio driver only, didn't work. The other thing i've tried is going to regedit Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlS et\Control\Class\{4d36e96c-e325-11ce-bfc1-08002be10318}\0000\PowerSettings and setting the settings to start with 00 , which eleminates the cutting of signal between different audio content like switching from DTS to Stereo, but this doesn't help also. So I am open to suggestions.
Update: I've tried a Workaround is to install the previous Audio Driver which is 1.3.38.4 you have to uninstall the Nvidia driver from control panel and then after restart, manualy put in the old driver also I turned off the internet so windows doesn't update it but the problem is still there.
Mess With The Best, Die Like The Rest
Ryzen 7 1700
(15 items)
AMD Ryzen 7 1700 @ 4.0GHZ
Gigabyte X370 Gaming 5
MSI GTX 1080 Ti AERO water cooled
G-Skill 2x8GB 3200mhz 14C
Samsung 960 EVO 500GB M2
Seagate 4TB SHDD
Seasonic PRIME 1200W Platinum
EK Fluid Gaming A240G Watercooled CPU + GPU
CoolerMaster Cosmos II
Operating System
Windows 10 Fall Creators Update
ASUS PG278Q
Keyboard
Razer Blackwidow Stealth
Mouse
Logitech G502
Mouse
Func Surface 1030
Audio
Pioneer VSX-1131 Audio Receiver
crashburn162 is offline
post #2 of 5 (permalink) Old 02-25-2019, 08:43 AM
Not new to overclock.net
guitarmageddon88's Avatar
Rep: 70 (Unique: 62)
And you cant just leave the hd audio box unchecked on the new package installation process? Leave it on the last known good version?
Sandy-Capable
(14 items)
i7-8700k
ASUS Maximus X Code
MSI RTX 2080 Gaming Trio
GSkill Trident Z Rgb
970 evo
EVGA Supernova G3
H150i Pro
LianLi PC011 Air
Operating System
Windows 10
HP Omen 27"
Keyboard
Corsair K70
Mouse
Razer Abyssus
i7 2600k @ 4.5ghz
ASUS P8Z68 Deluxe Gen 3
MSI GTX 580 Lightning Xtreme
Gskill Sniper 8gb 1866mHz @ 1.35v
Samsung 840 pro
Optical Drive
Lite-On
Corsair hx 750
rs 240
OBSIDIAN 800D
Operating System
WINDOWS 7 64
Alienware aw2310
Keyboard
corsair k70
Audio
Logitech Z906
guitarmageddon88 is offline
post #3 of 5 (permalink) Old 02-25-2019, 08:56 AM - Thread Starter
Rep: 1 (Unique: 1)
Update: So the fix for now is from advanced settings if I set it to 24 bit 48000hz it's fine, before it was at 24 bit 96000hz which is the max for my speakers but changing it to 96000hz is what causes the problem. So the problem is with the HZ don't know why but I've posted it on Nvidia forums hopefully some dev looks at it.
Ryzen 7 1700
(15 items)
Seagate 4TB SHDD
Operating System
ASUS PG278Q
Keyboard
Mouse
Logitech G502
Mouse
Func Surface 1030
Audio
post #4 of 5 (permalink) Old 02-26-2019, 02:18 AM - Thread Starter
Rep: 1 (Unique: 1)
So after some more testing the method I described switching to 24bit 48000hz works sometimes it's not constant so open up for suggestions I am going to try with windows drivers and block updates see if it works that way.
UPDATE:
Ok after few hours of testing this is what I came up with.
1.Stop internet connection
2.Uninstall Nvidia HD Audio driver from control panel
3.Remove the driver from Device Manager under audio.
4.Stop windows updates through Destroy Windows 10 Spying tool so it won't update itself again. ( https://github.com/Nummer/Destroy-Wi...pying/releases )
4.Restart
After these steps you get "High Definition Audio Device" which is some kind of windows drivers so far it works after 2-3 idles with this. I've also disabled Windows updates via Destroy Windows 10 Spying tool so It won't update itself to the nvidia one. It works so far for both my machines.
Ryzen 7 1700
(15 items)
Seagate 4TB SHDD
Operating System
ASUS PG278Q
Keyboard
Mouse
Logitech G502
Mouse
Func Surface 1030
Audio
post #5 of 5 (permalink) Old 03-06-2019, 05:44 AM - Thread Starter
Rep: 1 (Unique: 1)
I can confirm that the new driver 419.35 fixes the problem after long idle you still get 2-3 seconds until the sounds is constant but it stops after that. And if you do the registry trick it's instant. So it's fixed for me.
Ryzen 7 1700
(15 items)
Seagate 4TB SHDD
Operating System
ASUS PG278Q
Keyboard
Mouse
Logitech G502
Mouse
Func Surface 1030
Audio
